What are Cisco UC VOS Applications?
The following Cisco UC applications and devices share the Cisco Voice Operating System (VOS):
- Cisco Contact Center Express (CCX)
- Cisco Unity Connection (CUC) servers
- Cisco Hosted Collaboration Mediation for Fulfillment (HCM-F)
- Cisco HCS Intelligent Loader
- Cisco IM & Presence (IM&P) servers
- Cisco Prime License Manager (PLM)
- Cisco Emergency Responder
- Cisco Prime Collaboration Deployment (PCD) servers
- Cisco SocialMiner
NOTE: In the past, Cisco labeled VOS as "Cisco Unified Communications Operating System" and "Cisco Unified Operating System."
What Does the Cisco: UC VOS Applications PowerPack Monitor?
To monitor Cisco VOS applications using Skylar One, you must install the "Cisco: UC VOS Applications" PowerPack. This PowerPack enables you to discover, model, and collect data about VOS applications.
The "Cisco: UC VOS Applications" PowerPack includes:
- Three example credentials you can use as templates to create SOAP/XML and/or Basic/Snippet credentials to connect to the VOS applications you want to monitor
- Dynamic Applications and run book actions to discover, model, and monitor performance metrics and/or collect configuration data for VOS applications and devices.
- Device classes for each of the VOS applications and devices Skylar One monitors
- Event policies and corresponding alerts that are triggered when VOS devices meet certain status criteria
- Run book action and automation policies that do the following:
- Align the correct device class to Cisco VOS systems based on the GUID passed in an event.
- Align the appropriate "Cluster Status" Dynamic Applications to VOS Cluster virtual root devices.
- Verify that component devices remain aligned to the same collector as the root device.
- Move the physical devices discovered using the "Cisco: UC VOS Applications" PowerPack to the same collector as their component devices when merging physical and component devices.
Installing the Cisco: UC VOS Applications PowerPack
Upgrading to version 14.0 of the Cisco: Unified Communications Manager application may break the integration with the "Cisco: UC VOS Applications" PowerPack and require a snippet change for Dynamic Applications to function. To add support for this version, see the following article: https://support.sciencelogic.com/s/article/14487
