What are Cisco Wireless LAN Controllers?
Cisco wireless LAN controllers (WLC) play a central role in Cisco unified wireless networks. WLCs collect management and data packets from the network's access points (AP) and then switch those packets between wireless clients and the wired portion of the network. The WLC also controls the network configuration and passes this configuration data to the access points, which act as wireless client interfaces.
What Does the Cisco: Wireless PowerPack Monitor?
The "Cisco: Wireless" PowerPack enables you to monitor Cisco WLCs and APs using the AIRESPACE-WIRELESS-MIB and CISCO-LWAPP-MIB. The PowerPack includes the following features:
- Dynamic Applications that discover and collect data from all Cisco WLC component devices monitored
- Event policies and corresponding alerts that are triggered when Cisco WLC component devices meet certain status criteria
- Device classes for each of the Cisco WLC component devices monitored
- Device dashboards that display information about Cisco WLC component devices
Installing the Cisco: Wireless PowerPack
