What is Citrix: NetScaler ADC?
Citrix: NetScaler ADC is a network appliance that improves application performance, reliability, and security via high-speed load balancing and direction of traffic to different servers.
What Does the Citrix: NetScaler ADC Base Pack PowerPack Monitor?
To monitor Citrix NetScaler ACD systems and devices using Skylar One, you must install the "Citrix: NetScaler ADC Base Pack" PowerPack. This PowerPack enables you to discover, model, and collect data about Citrix NetScaler ADC systems and devices.
The "Citrix: NetScaler ADC Base Pack" PowerPack includes:
- An example credential you can use as a template to create an SNMP credential to connect to the NetScaler system you want to monitor
- Dynamic Applications to discover, model, and monitor performance metrics and/or collect configuration data for NetScaler systems and devices
- Device classes for each of the NetScaler systems and devices Skylar One monitors
- Event policies and corresponding alerts that are triggered when NetScaler systems and devices meet certain status criteria
Installing the Citrix: NetScaler ADC Base PackPowerPack
Ensure you are running Skylar One version 12.3.1 or later before installing the "Citrix: NetScaler ADC Base Pack" PowerPack.
