What is Dell EMC XtremIO?
Dell EMC XtremIO storage arrays use all flash technology and a scale-out design to provide high performance and consistent low latency. XtremIO provides enterprise features for data reduction, high availability, snapshots, and clones.
What Does the Dell EMC: XtremIO PowerPack Monitor?
To monitor Dell EMC XtremIO storage devices with Skylar One, you must install the "Dell EMC: XtremIO" PowerPack. This PowerPack lets you discover, model, and collect data about XtremIO storage devices.
The "Dell EMC: XtremIO" PowerPack includes:
- An example credential you can use as a template to create a SOAP/XML credential to connect to the XtremIO storage devices you want to monitor
- Dynamic Applications to discover, model, and monitor performance metrics and collect configuration data for XtremIO storage devices
- Device classes for each of the XtremIO storage devices that Skylar One monitors
- Event policies and corresponding alerts that are triggered when XtremIO storage devices meet certain status criteria
Installing the Dell EMC: XtremIO PowerPack
- Search for and download the PowerPack from the PowerPacks page on the ScienceLogic Support Site (Skylar One > PowerPacks).
