Introduction to the F5 BIG-IP PowerPack
This section describes how to monitor F5 Networks' BIG-IP Local Traffic Manager (LTM) devices in Skylar One (formerly SL1) using the "F5 BIG-IPPowerPack.
What is F5 BIG-IP LTM?
F5 Networks' BIG-IP Local Traffic Manager (LTM) devices manage local system traffic to ensure optimal network and application performance and increase the system's operational efficiency. BIG-IP LTM solutions include BIG-IP appliances, the VIPRION application delivery controller, and software-based BIG-IP Virtual Editions.
What Does the F5 BIG-IP PowerPack Monitor?
The "F5 BIG-IPPowerPack enables you to monitor LTM configuration and performance metrics for virtual servers, pools, and member nodes, as well as other chassis and asset information.
The "F5 BIG-IPPowerPack includes the following features:
  • Dynamic Applications that discover and monitor F5 BIG-IP LTM devices
  • Device classes for each of the F5 BIG-IP LTM devices that the "F5 BIG-IPPowerPack can monitor
  • Event policies and corresponding alerts that are triggered when F5 BIG-IP LTM devices meet certain status criteria
Installing the F5 BIG-IP PowerPack
Before completing the steps in this section, you must import and install the latest version of the "F5 BIG-IPPowerPack.
