The following sections describe how to configure and discover IBM AIX devices for monitoring by Skylar One using the "IBM: AIX Monitoring" PowerPack:
Supported Operating Systems
Versions 7.X of AIX are supported by the PowerPack. Older versions of IBM AIX will work if the commands in this document will work with that version.
Prerequisites
To configure the Skylar One system to monitor IBM AIX devices using the "IBM: AIX Monitoring" PowerPack, you must have the following information about your devices:
<username> ALL=(ALL) NOPASSWD:/usr/sbin/sar
<username> ALL=(ALL) NOPASSWD:/usr/sbin/bootinfo
To monitor CLI-SSH authentication events or alerts, you must first install the "Linux Base Pack" PowerPack. The "Linux Base Pack" PowerPack contains the following API-type event policies, which trigger events for any device that uses SSH authentication:
Configuring IBM AIX Devices to Collect Data
The following tables list the collection objects included in IBM AIX Dynamic Applications and the AIX commands used by each of those collection objects. You can use these commands to grant or restrict access to certain data types in your IBM AIX user account that you will use to monitor your IBM AIX devices.
Dynamic Application Collection Object(s) AIX Command(s) Used
IBM: AIX Device Class Configuration OS Level oslevel -s
OS Version oslevel | sed 's/\./ /g' | awk '{ if (NF>=2) print "AIX "$1"."$2; else print "AIX "$1}'
IBM: AIX Disks Active Disk % lspv;iostat -D
Disk Service Queue Full
Failed Read requests per sec
Failed Write requests per sec
Physical Volume Name
IBM: AIX Error Report TimeStamp errpt -s <start_time> | head -n 1000
IBM: AIX ICDA Cache Filesystem df -kP
Filesystem Characteristics lsfs
Processes ps auxww
uptime uptime
IBM: AIX Inodes Inodes Used Percentage df -i
Mount Directory
IBM: AIX LPAR CPU Configuration Maximum Memory (MB) lparstat -i
Maximum Physical CPUs in system
Maximum Virtual CPUs
Minimum Memory (MB)
Minimum Virtual CPUs
Mode
Node Name
Online Memory
Partition Name
Partition Type
IBM: AIX LPAR CPU Stats Active CPUs in Pool lparstat -i
Active Physical CPUs in system
Entitled Capacity (%entc) lparstat
Entitled Capacity (units) lparstat -i
LPAR Overall CPU Utilization % lparstat
LPAR Type
Maximum Physical CPUs in system lparstat -i
Node Name
IBM: AIX Memory Stats Available Memory svmon -G -O summary=basic,unit=MB
Free Memory
Memory Size
Pinned memory consumption
Real Memory Consumption
Virtual Memory Consumption
Paging (Swap) Space Inuse
Paging (Swap) Space Size
IBM: AIX Network Stats Packet Errors netstat
IBM: AIX Page Space Read Write Page Space Pages Read per Sec vmstat 1 1
Page Space Pages Written per Sec
IBM: AIX Path Status Path Status lspath | uniq
IBM: AIX Processor States Processor Name lsdev -Cc processor
Processor Status lsdev -Cc processor; lsattr -El <processorname>
IBM: AIX System Configuration CPU type prtconf
Default Gateway
Domain Name
Firmware Version
FQDN
Host Name
IP Address
Logical CPU Cores mpstat -s 1 1
Manufacturer prtconf
Name Server
Netmask
OS Level oslevel
OS Version oslevel | sed 's/\./ /g' | awk '{ if (NF>=2) print "AIX V"$1"."$2; else print "AIX V"$1}'
Paging Space (MB) prtconf
Physical Memory (MB)
Physical Processors
Processor Speed (MHz)
Processor Type
Processor Version
Product Name
Serial Number
System Type
Time Zone date
Uptime (days) uptime
IBM: AIX Uptime & Load Average CPU Core Count lsdev -Cc processor
Load Average (15 min) uptime
Load Average (1 min)
Load Average (5 min)
Total Uptime Minutes
IBM: AIX Volumes Free Partition Size lspv
Logical Volume Name lsvg
Logical Volume State
Logical Volume Type
Physical Volume Name lspv
Physical Volume State
Stale Partitions Count
Total Partition Size
Used Partition Size
IBM: AIX Zombie Process Count Zombie Process Count ps -eo "status" | grep -c Z
The following table lists internal collection inventory and internal collection performance Dynamic Applications (ICDA) in the PowerPack:
Dynamic Application Metrics AIX Command(s) Used
IBM: AIX IC Detail uptime uptime
IBM: AIX IC Filesystem Inventory Filesystem df -kP
IBM: AIX IC Filesystem Performance
IBM: AIX IC Process Inventory Processes ps auxww
IBM: AIX IC Process Performance
The following table lists Dynamic Applications that are disabled by default and not included as part of the "IBM: AIX Dynamic Applications Template" device template. These Dynamic Applications can be enabled as needed by manually adding them to your devices or the device template:
IBM: AIX CPU Utilization (mpstat) CPU Utilization % mpstat
IBM: AIX CPU Utilization (sar) CPU Utilization % sudo sar -u 1 3
IBM: AIX Filesystem Filesystem df -kP
IBM: AIX Total Allocated Storage Value (Bootinfo) Total Allocated Storage (GB) TOTAL=0; for DISK in $(lspv | awk '{ print $1 }');do SIZE=$(sudo bootinfo -s $DISK); TOTAL=$(echo "$TOTAL + $SIZE"|bc); done; echo "$TOTAL / 1024" | bc
The "IBM: AIX ICDA Cache" Dynamic Application acts as a cache producer for the following Dynamic Applications:
  • IBM: AIX Filesystem
  • IBM: AIX IC Detail
  • IBM: AIX IC Filesystem Inventory
  • IBM: AIX IC FIlesystem Performance
  • IBM: AIX IC Process Inventory
  • IBM: AIX IC Process Performance
Creating an SSH/Key Credential for IBM AIX
To configure Skylar One to monitor IBM AIX devices using SSH, you must first create an SSH/Key credential. This credential allows the Dynamic Applications in the "IBM: AIX Monitoring" PowerPack to connect with an IBM AIX device.
  2. Locate the "IBM: AIX Example Credential" and click on it. The Edit Credential modal page appears:
The private key must include the lines "BEGIN RSA PRIVATE KEY" and "END RSA PRIVATE KEY", as well as all preceding and following dashes on those lines.
The Private Key (PEM Format) field is only required in the current Skylar One user interface. The Private Key (PEM Format) field is not required if you are using the classic Skylar One user interface to define a credential.
Creating an SSH/Key Credential for IBM AIX in the Skylar One Classic User Interface
To define an SSH/Key credential:
  1. Collect the information you need to create each credential (usually username and password).
  3. In the Credential Management page, located the "IBM: AIX Example Credential" and click its wrench icon (). The Credential Editor appears.
  1. In the Credential Editor, supply values in the following fields:
  1. Click the Save button to save the new SSH/Key credential.
Configuring the AIX Device Template
A device template allows you to save a device configuration and apply it to multiple devices. The Dynamic Applications in the "IBM: AIX MonitoringPowerPack do not align automatically. Configuring and applying the "IBM: AIX Dynamic Applications Template" device template when you discover your IBM AIX device will align the appropriate Dynamic Applications.
To configure the IBM AIX device template:
  1. Go to the Configuration Templates page (Devices > Templates or Devices > Templates, or Registry > Devices > Templates in the classic user interface).
  1. Locate the "IBM: AIX Dynamic Applications Template", or if the target host is a VIOS type, the "IBM: VIOS Dynamic Applications Template", and click its wrench icon (). The Device Template Editor page appears.
  1. Click the next Dynamic Application listed in the Subtemplate Selection section on the left side of the page and then select the AIX SSH/Key credential in the Credentials field.
  2. Repeat step 5 until the you have selected the IBM AIX SSH/Key credential in the Credentials field for all of the Dynamic Applications listed in the Subtemplate Selection section.
  3. Click Save As.
 Do not click the Save button, as it will save over the "IBM: AIX Dynamic Applications Template", which you may need for future use.
Preventing IBM AIX Devices from Dynamically Aligning Unwanted Dynamic Applications
As the Dynamic Applications in this PowerPack do not get automatically aligned during discovery, you can choose to disable the "Dynamic Discovery" flag on your IBM AIX device to ensure that other Dynamic Applications do not automatically align to your IBM AIX device and cause increased scale on your Skylar One system.
To disable the "Dynamic Discovery" flag from the Device Investigator:
  1. In the Devices page, locate your IBM AIX device and click on it.
  2. In the Device Investigator page, click the Settings tab.
  3. Locate the Dynamic Discovery checkbox and deselect it.
  4. Click the Save button.
To disable "Dynamic Discovery" from the device template:
  1. In the Configuration Templates page (Devices > Templates, or Registry > Devices > Templates in the classic user interface), locate your IBM AIX device and click on its wrench icon ().
  2. In the Device Template Editor, in the Device Preferences pane of the Config tab, click on Dynamic Discovery to enable the option.
  3. Deselect the Dynamic Discovery checkbox.
Discovering IBM AIX Devices
To create and run a discovery session that will discover IBM AIX devices, perform the following steps:
  1. Click the Unguided Network Discovery Workflow button. Additional information about the requirements for discovery appears in the General Information pane to the right.
  1. Click Select. The Basic Information page appears:
  1. Click Next. The Credential Selection page of the Add Devices wizard appears:
  1. On the Credentials page, locate and select the SSH/Key credential you created.
Discovering IBM AIX Component Devices in the Skylar One Classic User Interface
  2. Click the Create button to create a new discovery session. The Discovery Session Editor modal page appears.
  1. Optionally, you can enter values in the other fields on this page. For more information about the other fields on this page, see the Discovery & Credentials manual.
  2. Click the Save button and then close the Discovery Session Editor modal page.
  4. The Discovery Session window appears. When the IBM AIX device is discovered, click its device icon () to view the Device Properties page for the IBM AIX device.
Enabling More Than Two Thresholds for Filesystem
The "IBM: AIX IC Filesystem Inventory" and "IBM: AIX IC Filesystem Performance" Dynamic Applications provide two thresholds - Major and Critical. If you need more than two thresholds for Filesystem, you will need to disable the IC Filesystem Dynamic Applications and enable the "IBM: AIX Filesystem" Dynamic Application.
To disable the "IBM: AIX IC Filesystem Inventory" and "IBM: AIX IC Filesystem Performance" Dynamic Applications:
  1. Locate your IBM AIX device in the Devices page and click on it.
  2. In the Device Investigator page for the IBM AIX device, go to the Collections tab.
  3. In the Collections tab, click the Edit button.
  4. Locate the "IBM: AIX IC Filesystem Inventory" Dynamic Application, click its Actions icon (), and select Disable Collection.
  5. Click the Save button.
  6. Repeat these steps to disable the "IBM: AIX IC Filesystem Performance" Dynamic Application.
Next, you will need to enable the "IBM: AIX ICDA Cache" and "IBM: AIX Filesystem" Dynamic Applications:
  1. In the Device Investigator page for the IBM AIX device, go to the Collections tab.
  1. In the Collections tab, click the Edit button.
  2. Locate the "IBM: AIX ICDA Cache" Dynamic Application, click its Actions icon (), and select Enable Collection.
  3. Click the Save button.
  4. Repeat these steps to enable the "IBM: AIX Filesystem" Dynamic Application.
Disabling the "IBM: AIX IC Filesystem Inventory" and "IBM: AIX IC Filesystem Performance" Dynamic Applications will result in no filesystem data collection in the Hardware page and hiding the filesystem option will not be available.
Enabling both ICDA and non-ICDA Dynamic Applications will result in duplicate filesystem alerts.
Changing the Collection Commands for CPU Utilization
Some IBM AIX administrators prefer to calculate CPU utilization using the SAR command as opposed to the MPSTAT command. Skylar One administrators can chose to use the approach that best fits their use case.
There are two CPU utilization Dynamic Applications in the PowerPack:
The "IBM: AIX CPU Utilization (sar)" and "IBM: AIX CPU Utilization (mpstat) Dynamic Applications and their alerts are disabled by default and cannot be aligned using the device template. To enable the "IBM: AIX CPU Utilization (sar)" and "IBM: AIX CPU Utilization (mpstat)" Dynamic Applications:
  1. Ensure that the user has the proper privileges to run the SAR command.
  2. Go to the Dynamic Applications Manager page (System > Manage > Dynamic Applications).
  3. Locate the "IBM: AIX CPU Utilization (sar)"/"IBM: AIX CPU Utilization (mpstat)" Dynamic Application and click its wrench icon ().
  4. In the Operational State dropdown field, select Enabled. Click Save.
  5. Go to the Event Policies page (Events > Event Policies, or Registry > Events > Event Manager in the classic user interface) and enable the following events:
  1. Go to the Alerts tab for both Dynamic Applications and enable their alerts.
  2. The "IBM: AIX CPU Utilization (sar)" and "IBM: AIX CPU Utilization (mpstat)"  Dynamic Applications can now be manually aligned to individual devices.
Updating Virtual Memory Alerts
The "IBM: AIX Memory Stats" Dynamic Application has virtual memory events enabled by default. You must ensure that there are no other previously built custom PowerPacks with virtual memory events running to use these events.
If you are using the "AIX Virtual Memory Utilization Monitoring" PowerPack, you must disable the alerts and events in that PowerPack or disable the alerts in the "IBM: AIX Memory Stats" Dynamic Application in the "IBM: AIX Monitoring" PowerPack.
To disable these events:
  1. Go to the Dynamic Applications Manager page (System > Manage > Dynamic Applications) .
  2. Locate the "IBM: AIX Memory Stats" Dynamic Application and click its wrench icon ().
  3. Click the Alerts tab and locate the "IBM: AIX Virtual Memory Utilization Critical" alert and click its wrench icon ().
  4. In the Active State dropdown, select Disabled. Click Save.
  5. Repeat the above steps for the following event policies:
