What Does the IBM: AIX Monitoring PowerPack Monitor?
The "IBM: AIX Monitoring" PowerPack includes:
- Dynamic Applications that discover and collect configuration and performance data for IBM AIX devices
- Event Policies and corresponding alerts that are triggered when IBM AIX devices meet certain status criteria
- Device Classes for each type of IBM AIX device monitored
- A Device Template for aligning Dynamic Applications
- A Run Book Action and an Automation policy to assign the proper device classes to IBM AIX devices
- A Dashboard that displays information about your IBM AIX server
Installing the IBM: AIX Monitoring PowerPack
