The following sections describe how to configure and discover IBM DataPower gateways for monitoring by SL1 using the "IBM: DataPowerPowerPack:
Prerequisites for Monitoring IBM DataPower Gateways
Before you can monitor IBM DataPower gateways in SL1 using the "IBM: DataPowerPowerPack, you must first enable SNMP and configure SNMP community strings in each of the DataPower gateways that you will monitor with SL1
Creating an SNMP Credential for IBM DataPower Gateway
To configure SL1 to monitor IBM DataPower gateways, you must first create an SNMP credential. This credential allows the Dynamic Applications in the "IBM: DataPower" PowerPack to connect with a DataPower gateway.
  1. Go to theCredentials page (Manage > Credentials).
  2. Click the Create New button and select Create SNMP Credential from the drop-down list that appears.
  4. Create SNMP Credential for Cisco Unity Express
  • Timeout (ms). Enter the time, in milliseconds, after which SL1 will stop trying to communicate with the IBM: DataPower device. The default value is 1500. This field is required.
  • SNMP Version. Select SNMP V2 from the drop-down list.
  • SNMP Retries. Keep the default. The default value is "1".
  • Port. Keep the default. The default port is "161".
  • SNMP Community (Read Only). Enter the community string for the IBM: DataPower voice mailbox you want to monitor.
  • SNMP Community (Read/Write). Optional. Enter the community string for the IBM: DataPower to grant Read/Write permissions.
  1. Click Close.
Creating an SNMP Credential for IBM: DataPower Gateway in the SL1 Classic User Interface
To configure SL1 to monitor IBM DataPower gateways in the classic user interface, you must first create an SNMP credential. This credential allows the Dynamic Applications in the IBM: DataPower PowerPack to connect with a DataPower gateway.
To configure an SNMP credential to connect with a DataPower gateway in the classic user interface:
  1. Click the Create button.
  1. In the drop-down list that appears, select SNMP Credential. The Credential Editor page appears:
  1. In the Profile Name field, enter a name for the credential.
  2. In the SNMP Version field, select SNMP V2.
  3. In the SNMP Community (Read Only) field, enter the community string for the DataPower gateway.
  4. Optionally, supply values in the other fields in this page. In most cases, you can use the default values for the other fields.
  5. Click the Save button.
Discovering IBM DataPower Gateways
To monitor your IBM: DataPower Gateways system, you must run a discovery session to discover the server on which IBM: DataPower Gateways is installed.
To create and run a discovery session that will discover an IBM: DataPower Gateways appliance:
  2. On the Credential Selection tab, locate and select the SNMP credential you created for IBM: DataPower Gateways appliances.
  • List of IP/Hostnames. Type the IP address for the IBM: DataPower Gateways appliance.
    • Select Device Template. If you configured an IBM: DataPower Gateways device template, select it here. Otherwise, leave the default selection.
Discovering IBM DataPower Gateways in the SL1 Classic User Interface
To discover an IBM DataPower gateway:
  1. In the Discovery Control Panel, click the Create button. The Discovery Session Editor page appears.
  1. In the Discovery Session Editor page, complete the following fields:
  • IP Address/Hostname Discovery List. Type the IP address for the DataPower gateway.
  • SNMP Credentials. Select the SNMP credential that you created for the DataPower gateway.
  4. The Discovery Session window appears. When the gateway device is discovered, click the device icon () to view the Device Properties page for the gateway device.
