What is IBM DataPower Gateway?
IBM DataPower Gateway is IBM's platform for delivering integration and security capabilities to web, mobile, cloud, API, service-oriented architecture, and business-to-business solutions in a single, multichannel gateway. It can be delivered as physical, virtual, cloud, Linux, and Docker deployments.
What Does the IBM: DataPower PowerPack Monitor?
To monitor IBM DataPower Gateways using Skylar One, you must install the "IBM: DataPower" PowerPack. This PowerPack enables you to discover, model, and collect data about DataPower Gateways.
The "IBM: DataPower" PowerPack includes:
- Dynamic Applications to discover, model, and monitor performance metrics and collect configuration data for IBM DataPower devices
- Device Classes for the IBM DataPower devices that Skylar One monitors
- Event Policies and corresponding alerts that are triggered when IBM DataPower devices meet certain status criteria
- An "IBM: DataPower" device dashboard that is assigned as the default dashboard for IBM DataPower devices
Installing the IBM: DataPower PowerPack
