The following sections provide an overview of IBM Tivoli Storage Manager and the " IBM: Tivoli Storage Manager" PowerPack:
What is IBM Tivoli Storage Manager?
IBM Tivoli Storage Manager is a data protection platform that gives enterprises a single point of control and administration for backup and recovery, providing centralized, automated data protection that can help reduce the risks that are associated with data loss and help manage compliance with data retention and availability requirements.
What Does the IBM: Tivoli Storage Manager PowerPack Monitor?
To monitor IBM Tivoli Storage Manager environments using Skylar One, you must install the "IBM: Tivoli Storage Manager" PowerPack. This PowerPack enables you to discover, model, and collect data from IBM Tivoli Storage Manager environments.
Skylar One uses SSH to connect to the Tivoli Storage Manager server or proxy server. The administrative utility "dsmadmc" is then used to query the TSM inventory.
The "IBM: Tivoli Storage Manager" PowerPack includes:
- Example credentials you can use as templates to create a SOAP/XML credential and an SSH/Key credential to connect to the IBM Tivoli Storage Manager environments you want to monitor
- Dynamic Applications to discover, model, and monitor performance metrics and collect configuration data for IBM Tivoli Storage Manager environments
- Device classes for the Tivoli Storage Manager devices that Skylar One monitors
- Event policies and corresponding alerts that are triggered when IBM Tivoli Storage Manger devices meet certain status criteria
- A run book action and a run book automation policy that align the root device class
Installing the IBM: Tivoli Storage Manager PowerPack
