Introduction
This section describes how to monitor IBM WebSphere Application Servers with performance monitoring infrastructure (PMI) in Skylar One using the "IBM: WebSphere Application ServerPowerPack.
What is IBM WebSphere Application Server?
The IBM WebSphere Application Server is a Java server runtime environment for enterprise applications. WebSphere supports microservices and standards-based programming models.
What Does the IBM: WebSphere Application Server PowerPack Monitor?
To monitor IBM WebSphere Application Servers using Skylar One, you must installthe "IBM: WebSphere Application ServerPowerPack. This PowerPack enables you to discover, model, and collect data about IBM WebSphere application servers.
The "IBM: WebSphere Application ServerPowerPack includes:
  • Dynamic Applications to discover, model, and monitor performance metrics and collect configuration data for IBM WebSphere Application Servers
  • Event Policies that are triggered when IBM WebSphere Application Servers meet certain status criteria
  • An Example Credential that you can use to connect to IBM WebSphere Application Servers
  • Run Book Actions and Run Book Automation policies for classifying the root device and aligning the "IBM: WebSphere System Stats" Dynamic Application to the WebSphere node agent
  • Device Classes for each of the IBM WebSphere components that the IBM: WebSphere Application Server PowerPack can monitor
  • A Device Dashboard that you can use to view information about IBM WebSphere Application Server components
Installing the IBM: WebSphere Application Server PowerPack
Before completing the steps in this section, you must import and install the latest version of the "IBM: WebSphere Application ServerPowerPack.
