Introduction to the Cherwell Integration PowerPack
This section describes how to sync SL1 Events with Cherwell Service Management (CSM) Incidents using the Cherwell Integration PowerPack. This PowerPack contains the three Run Book Automation policies and the Run Book Action policy that you use to sync SL1 Events with CSM Incidents.
The following topics describe how to use the Cherwell Integration PowerPack:
What Does the Cherwell Integration PowerPack Monitor?
The Cherwell Integration PowerPack includes:
  • A Sample Credential, "SL1 IS4 API Creds"
    "IS4" is a now-deprecated name for SL1 PowerFlow.
  • The "Cherwell Event IS4 Integration" Run Book Action, which you can use to automate adding, updating, and clearing SL1 events
  • The following Run Book Automation policies to automate adding, updating, and clearing events:
  • Cherwell Create Event IS4
  • Cherwell Update Ticket on Acknowledge
  • Cherwell Clear Event IS4
Installing the Cherwell Integration PowerPack
After you have configured CSM to work with the SyncPack, you will need to install and configure the Cherwell Integration PowerPack in SL1.
Downloading and Installing the PowerPack in SL1
  1. Download the PowerPack from the ScienceLogic Support Site.
  1. In SL1, go to the PowerPack Manager page (System > Manage > PowerPacks).
  2. In the PowerPack Manager page, click the Actions button, then select Import PowerPack.
  1. The Import PowerPack dialog box appears:
  1. Click the [Browse] button and navigate to the PowerPack file.
  2. When the PowerPack Installer modal appears, click the Install button to install the PowerPack.
