Introduction to the ScienceLogic: Skylar Automation PowerPack
This section describes how to monitor Skylar Automation (formerly PowerFlow) in Skylar One (formerly SL1) using the "ScienceLogic: Skylar Automation" PowerPack.
What Does this PowerPack Monitor?
This PowerPack lets you configure Skylar One to create an alert if a Skylar Automation application fails.
The "ScienceLogic: Skylar Automation" PowerPack includes the following features:
  • The "ScienceLogic: Skylar Automation Healthcheck Configuration" Dynamic Application includes an Event Policy that generates a Major event when the state returned by the healthcheck action is "not okay" or "not skipped". This Dynamic Application runs every six hours by default and it does not work for single-node Skylar Automation systems
  • The "ScienceLogic: Skylar Automation Queue Configuration" Dynamic Application, which monitors the status of the Skylar Automation RabbitMQ service
  • The "ScienceLogic: Skylar Automation Workers Configuration" Dynamic Application, which monitors the status of the Skylar Automation RabbitMQ workers
  • Event Policies and corresponding alerts that are triggered when an application in Skylar Automation fails
  • A Device Class and a Device Template for Skylar Automation
  • Sample SOAP/XML and SSH/Key Credentials for connecting to Skylar Automation
Installing the PowerPack
Before completing the steps in this section, you must import and install the latest version of the "ScienceLogic: Skylar Automation" PowerPack.
  2. In Skylar One, go to the PowerPack Manager page (System > Manage > PowerPacks).
Upgrading the PowerPack to Version 107 or Later
As of version 107 of this PowerPack, several items were removed from the pack and may no longer function. If you are upgrading from a previous release to version 107 or later, ScienceLogic recommends manually deleting them from your Skylar One system.
  • The following items were removed from the PowerPack:
    • Dashboards:
      • REST Discovery Initiation
    • Dashboard widgets:
      • REST Discovery Log Widget
    • Run book action policies:
      • REST Discovery: Phase 0 - Device Creation
      • REST Discovery: Phase I - Collection Test Lookup
      • REST Discovery: Phase II Credential Check
      • REST Discovery: Phase III - Apply template
    • Run book automation policies:
      • REST Discovery - Application Alignment
      • REST Discovery - Device Creation
    • Execution environments:
      • silo_rba_discovery
      • silo_logs
    • Event policies:
      • REST Device Discovery
    • Dynamic Applications:
      • REST: Performance Metrics Monitor
      • REST: Performance Metrics Monitor (PowerFlow)
