This PowerPack contains the run book automation policies and a run book action policy that you use with the "ServiceNow Cases" SyncPack, the "ServiceNow Events" SyncPack, or the "ServiceNow Incident" SyncPack.
What Does the ServiceNow Base Pack PowerPack Monitor?
The "ServiceNow Base Pack" PowerPack enables you to model and collect data about ServiceNow Incident and CMDB tables so that you can sync SL1 Events with ServiceNow Incidents, and you can sync SL1 Devices with ServiceNow Configuration Items (CIs). You can also use this PowerPack to sync Events or Cases between SL1 and ServiceNow.
The "ServiceNow Base Pack" PowerPack monitors the ServiceNow Incident and CMDB tables, and it returns information about Incident types, priorities, and states, displaying the information in an easy-to-consume dashboard. The PowerPack also returns information about the CI records that are actively being synced between SL1 and ServiceNow via SL1 PowerFlow, including basic CI metadata as well as an overall count.
This PowerPack contains Run Book Automation policies and a Run Book Action policy that you can use with the "ServiceNow Incident" SyncPack, the "ServiceNow Cases" SyncPack, or the "ServiceNow Events" SyncPack in SL1 PowerFlow.
The "ServiceNow Base Pack" PowerPack includes:
- The "REST: Performance Metrics Monitor (ServiceNow)" Dynamic Application, which collects performance data such as connection errors, latency, SSL errors, and timeouts
- The "ServiceNow: CMDB Configuration" Dynamic Application, which provides data for PowerFlow systems communicating with ServiceNow
- The "ServiceNow: Incident Metrics" Dynamic Application, which collects information about the types, statuses, and properties of ServiceNow Incidents
- The "ServiceNow CMDB: Un-Mapped Device Classes" event policy and additional "REST: Error count" policies
- A "ServiceNow" device class for ServiceNow instances
- The following run book automation policies to automate adding, updating, and clearing cases, events, or incidents, and to automate creating ServiceNow cases, events, or incidents in SL1:
- ServiceNow: [Cases] - Add/Update
- ServiceNow: [Cases] - Click to Create
- ServiceNow: [Cases] - Event Cleared
- ServiceNow: [Events] - Add/Update
- ServiceNow: [Events] - Click to Create
- ServiceNow: [Events] - Event Acknowledged
- ServiceNow: [Events] - Event Cleared
- ServiceNow: [Incidents] - Add/Update
- ServiceNow: [Incidents] - Click to Create
- ServiceNow: [Incidents] - Event Acknowledged
- ServiceNow: [Incidents] - Event Cleared
The following run book action policies:
- ServiceNow: Add/Update/Clear Case
- ServiceNow: Add/Update/Clear Event
- ServiceNow: Add/Update/Clear Incident
- The "ServiceNow: Create, Update, Clear Incident or Event" and the "ServiceNow: Send to PowerFlow" run book action types
- Two Sample SOAP/XML Credentials:
- "The ServiceNow DA - Example" credential, which connects Dynamic Applications to a ServiceNow instance
- "The ServiceNow RBA - Example" credential, which sends event payload information to PowerFlow using the run book automations
- The "ServiceNow Open Incidents" Dashboard, which displays information about ServiceNow incident statuses and types
Installing the ServiceNow Base Pack PowerPack
By default, installing a new version of a PowerPack overwrites all content in that PowerPack that has already been installed on the target system. You can use the Enable Selective PowerPack Field Protection setting in the Behavior Settings page (System > Settings > Behavior) to prevent new PowerPacks from overwriting local changes for some commonly customized fields. For more information, see
To install the "ServiceNow Base Pack" PowerPack:
- Search for and download the "ServiceNow Base Pack" PowerPack from the PowerPacks page (Product Downloads > PowerPacks & SyncPacks) at https://support.sciencelogic.com/s/.
- Click the Actions menu and choose Import PowerPack. The Import PowerPack modal appears.
- Click PowerPack file from step 1. and navigate to the "ServiceNow Base Pack"
- Select the PowerPack file and click . The PowerPack Installer modal page displays a list of the PowerPack contents.
- Click PowerPack appears on the PowerPacks page. . After the installation is complete, the "ServiceNow Base Pack"
