Introduction
This section describes how to monitor Juniper Mist devices in Skylar One using the Dynamic Applications in the "Juniper: Mist" PowerPack.
What Does the Juniper: Mist PowerPack Monitor?
To monitor Juniper Mist devices using Skylar One, you can install the "Juniper: Mist" PowerPack. This PowerPack enables you to align Dynamic Applications to Juniper Mist devices to collect data.
The "Juniper: Mist" PowerPack includes:
  • Dynamic Applications that enable Skylar One to align to and monitor Juniper Mist devices
  • Device Classes for each type of Juniper Mist component device Skylar One monitors
  • Event Policies that are triggered when Juniper Mist devices meet certain status criteria
  • Sample universal ("Juniper Mist UCF Example") and SOAP/XML ("Juniper Mist Example") credentials that you can use to create your own Juniper Mist credential
Installing the Juniper: Mist PowerPack
Before completing the steps in this section, you must import and install the latest version of the "Juniper: Mist" PowerPack.
