Introduction
This section describes how to monitor NetApp devices in Skylar One using the "NetApp: ONTAP REST" PowerPack.
What is NetApp ONTAP?
ONTAP data management software offers unified storage for applications that read and write block or file data. Options in storage configurations range from high-speed flash to lower-priced spinning media to cloud-based object storage.
What Does the NetApp: ONTAP REST PowerPack Monitor?
The "NetApp: ONTAP REST" PowerPack uses REST API to monitor NetApp ONTAP devices on version 9.14.1 and later and includes the following features:
  • Dynamic Applications that discover, model, and collect data from NetApp ONTAP devices using REST API.
  • Device classes for each of the NetApp component devices monitored.
  • An event policy and a corresponding alert that trigger when NetApp component devices meet certain status criteria.
  • A run book action policy and a run book automation policy for aligning a Dynamic Application.
  • Sample credentials and guided discovery for discovering NetApp component devices.
  • Alerts that trigger when NetApp metrics are above defined thresholds for Aggregates and Volumes.
Installing the NetApp: ONTAP REST PowerPack
Before completing the steps in this section, you must import and install the latest version of the "NetApp: ONTAP REST" PowerPack.
