The following sections describe how to configure and discover Oracle Solaris devices for monitoring by SL1 using the Oracle: Solaris Monitoring PowerPack:
Supported Operating Systems
Version 5.11 of Solaris is supported by the PowerPack. Older versions of Solaris will work if the commands in this document will work with that version.
Prerequisites
To configure the SL1 system to monitor Oracle Solaris devices using the Oracle: Solaris Monitoring PowerPack, you must have the following information about your devices:
  • IP addresses/hostnames of the devices you want to monitor.
  • A service account with the appropriate privileges:
  • Username/Password, OR
  • Username/SSH private keys
  • Port 22 (default SSH port) open from the SL1 Data Collector to the end device. Custom ports are supported if they are specified in the credential.
If you are already using an older version of the Solaris Community PowerPack, this pack will not upgrade the existing community PowerPack to this version.
Configuring Oracle Solaris Devices to Collect Data
The following tables list the collection objects included in Oracle Solaris Dynamic Applications and the Solaris commands used by each of those collection objects. You can use these commands to grant or restrict access to certain data types in your Solaris user account that you will use to monitor your devices.
Dynamic Application Collection Object(s) Solaris Command(s) Used
Oracle: Solaris Configuration Discovery System OS Name uname -a
Memory size (MB) sudo /usr/sbin/prtconf | head -3 | grep "Memory"
System Capability (bit) isainfo -b
OS Level uname -r
OS Version
uname -r | sed 's/\./ /g' | awk '{ if (NF>=2)print "SunOS "$1"."$2; else print "SunOS "$1}'
Oracle: Solaris CPU Utilization Logical CPU Utilization % sar -u 1 3
Oracle: Solaris ICDA Cache Filesystem df -k
Processes ps -elf -o pid,s,osz,user,time,args
Uptime uptime
Oracle: Solaris Memory Stats Memory Size sudo /usr/sbin/prtconf | head -3 | grep "Memory"
Free Physical Memory vmstat 1 1
Available Paging Memory sudo /usr/sbin/swap -s
Used Paging Memory sudo /usr/sbin/swap -s
Oracle: Solaris System Configuration Application Architecture uname -p
Domain domainname
Hardware Provider showrev
Host ID hostid
Host Name hostname
Kernel Architecture uname -m
CPU Model kstat -m cpu_info
CPU Name kstat -m cpu_info
CPU type kstat -m cpu_info
Number of Virtual Processors kstat -m cpu_info
Number of Cores kstat -m cpu_info
Processor Speed (MHz) kstat -m cpu_info
Total Physical Processors kstat -m cpu_info
Kernel Version uname -a
Machine uname -a
Release uname -a
Solars: Uptime & Load Average CPU Core Count
Load average 1 min uptime
Load average 5 min
Load average 15 min
Total Uptime Minutes
All Solaris commands listed in this table can be executed with a standard Solaris user account except the "swap -s" and "prtconf" commands. You will need to grant passwordless sudo permissions for accounts to use these commands. For example, add this command in the /etc/sudoers file: username ALL=(ALL)NOPASSWD: <command>.
The "Showrev" command only works for version 10 of Solaris.
The following table lists internal collection Dynamic Applications (ICDA) in the PowerPack:
Dynamic Application Metrics Solaris Command(s) Used
Oracle: Solaris IC Detail System Uptime uptime
Oracle: Solaris IC Filesystem Inventory Filesystem df -k
Oracle: Solaris IC Filesystem Performance
Oracle: Solaris Process Inventory Processes ps -elf -o pid,s,osz,user,time,args
Oracle: Solaris Process Performance
The following Dynamic Application is disabled by default and not included as part of the "Oracle: Solaris Dynamic Applications Template" device template. ThisDynamic Application can be enabled as needed by manually adding it to your devices or the device template:
Oracle: Solaris Filesystem Filesystem df -k
"The Oracle: Solaris IC Filesystem Inventory" and "Oracle: Solaris IC File System Performance" Dynamic Applications collect data for use in the standard, internal, file system collections. If you wish to define additional alerts or collection objects, you should do so in the "Oracle: Solaris File" System Dynamic Application
Creating an SSH/Key Credential for Oracle Solaris
To configure SL1 to monitor Oracle Solaris devices using SSH, you must first create an SSH/Key credential. This credential allows the Dynamic Applications in the Oracle: Solaris Monitoring PowerPack to connect with an Oracle Solaris device.
  2. Locate the "Solaris Example Credential" and click on it. The Edit Credential modal page appears:
  • Timeout (ms). Time, in milliseconds, after which SL1 will stop trying to communicate with the device from which you want to retrieve data.
  • Hostname/IP. Type the hostname or IP address of the Oracle Solaris device you want to monitor. Alternatively, you can use the following variables:
  • You can include the variable %D in this field. SL1 will replace the variable with the IP address of the current device (device that is currently using the credential).
  • You can include the variable %N in this field. SL1 will replace the variable with hostname of the current device (device that is currently using the credential). If SL1 cannot determine the hostname, SL1 will replace the variable with the primary, management IP address for the current device.
  • Port. Port number associated with the data you want to retrieve. This field is required.
  • Private Key (PEM Format). Type or paste the SSH private key that you want SL1 to use, in PEM format.
The private key must include the lines "BEGIN RSA PRIVATE KEY" and "END RSA PRIVATE KEY", as well as all preceding and following dashes on those lines.
The Private Key (PEM Format) field is only required in the current SL1 user interface. The Private Key (PEM Format) field is not required if you are using the classic SL1 user interface to define a credential.
The private key can have a maximum of 64 characters per line. Therefore, you cannot use keys in the OpenSSH format, because that format uses 70 characters per line. When you attempt to save the credential, SL1 will validate that the private key entered is in the correct format. You will be able to save the credential only if the private key is correctly formatted.
Creating an SSH/Key Credential for Oracle Solaris in the SL1 Classic User Interface
To define an SSH/Key credential:
  1. Collect the information you need to create each credential (usually username and password).
  3. In the Credential Management page, located the "Solaris Example Credential" and click its wrench icon (). The Credential Editor appears:
  1. In the Credential Editor, supply values in the following fields:
  • Timeout (ms). Time, in milliseconds, after which SL1 will stop trying to communicate with the authenticating server.
  • Password. Password for an SSH user account on the device to be monitored. (Optional if using a PEM key.)
The PowerPack has been tested with the following ciphers (Host-key algorithms): ssh-ed25519,ecdsa-sha2-nistp521, ecdsa-sha2-nistp384, ecdsa-sha2-nistp256, rsa-sha2-512, rsa-sha2-256. SSH-RSA and SSH-DSS are not supported.
  1. Click the Save As button to save the new SSH/Key credential.
Configuring the Oracle Solaris Device Template
A device template allows you to save a device configuration and apply it to multiple devices. The Dynamic Applications in the Oracle: Solaris Monitoring PowerPack do not align automatically. Configuring and applying the "Oracle: Solaris Dynamic Applications Template" device template when you discover your Oracle Solaris device will align the appropriate Dynamic Applications.
To configure the Oracle Solaris device template:
  1. Go to the Configuration Templates page (Devices > Templates or Devices > Templates, or Registry > Devices > Templates in the classic SL1 user interface in the SL1 classic user interface).
  1. Locate the "Oracle: Solaris Dynamic Applications Template" and click its wrench icon (). The Device Template Editor page appears.
  • Credentials. Select the SSH/Key credential that you created for Oracle Solaris.
  1. Click the next Dynamic Application listed in the Subtemplate Selection section on the left side of the page and then select the Oracle Solaris SSH/Key credential in the Credentials field.
  2. Repeat step 5 until the you have selected the Oracle Solaris SSH/Key credential in the Credentials field for all of the Dynamic Applications listed in the Subtemplate Selection section.
  3. Click Save As.
 Do not click the Save button, as it will save over the "Oracle: Solaris Dynamic Applications Template", which you may need for future use.
Preventing Oracle Solaris Devices from Dynamically Aligning Unwanted Dynamic Applications
As the Dynamic Applications in this PowerPack do not get automatically aligned during discovery, you can choose to disable the "Dynamic Discovery" flag on your Oracle Solaris device to ensure that other Dynamic Applications do not automatically align to your device and cause increased scale on your SL1 system.
To disable the "Dynamic Discovery" flag from the Device Investigator:
  1. In the Devices page, locate your Oracle Solaris device and click on it.
  2. In the Device Investigator page, click the Settings tab.
  3. Locate the Dynamic Discovery checkbox and deselect it.
  4. Click the Save button.
To disable "Dynamic Discovery" from the device template:
  1. In the Configuration Templates page (Devices > Templates, or Registry > Devices > Templates in the classic SL1 user interface), the "Oracle: Solaris Dynamic Applications Template" and click on its wrench icon ().
  2. In the Device Template Editor, in the Device Preferences pane of the Config tab, click on Dynamic Discovery to enable the option.
  3. Deselect the Dynamic Discovery checkbox.
Discovering Oracle Solaris Devices
To create and run a discovery session that will discover Oracle Solaris devices, perform the following steps:
  1. Click the Unguided Network Discovery Workflow button. Additional information about the requirements for discovery appears in the General Information pane to the right.
  1. Click Select. The Basic Information page appears:
  1. Click Next. The Credential Selection page of the Add Devices wizard appears:
  1. On the Credentials page, locate and select the SSH/Key credential you created.
  1. Click Next. The Discovery Session Details page of the Add Devices wizard appears.
  • List of IPs/Hostnames. Type the IP addresses for the Solaris devices you want to monitor, separated by a comma.
  • Apply Device Template. Select the device template that you created for Solaris.
Discovering Oracle Solaris Component Devices in the SL1 Classic User Interface
  2. Click the Create button to create a new discovery session. The Discovery Session Editor modal page appears:
  • IP Address Discovery List. Type the IP addresses for the Solaris devices you want to monitor, separated by a comma.
  • Other Credentials. Select the SSH/Key credential that you created for Solaris.
  1. Optionally, you can enter values in the other fields on this page. For more information about the other fields on this page, see the Discovery & Credentials manual.
  2. Click the Save button and then close the Discovery Session Editor modal page.
  4. The Discovery Session window appears. When the Solaris device is discovered, click its device icon () to view the Device Properties page for the Solaris device.
