Introduction
This section describes how to monitor Oracle Solaris devices in Skylar One using the Dynamic Applications in the "Oracle: Solaris MonitoringPowerPack.
What Does the Oracle: Solaris Monitoring PowerPack Monitor?
The "Oracle: Solaris MonitoringPowerPack includes:
  • Dynamic Applications to collect configuration and performance data about Oracle Solaris systems
  • Device classes for each of the Oracle devices monitored
  • A device template for aligning Oracle Solaris Dynamic Applications
  • A run book automation policy and action for classifying Oracle Solaris devices
  • A sample credential for discovering Oracle Solaris devices
  • Event policies and corresponding alerts that are triggered when Oracle Solaris devices meet certain status criteria
Installing the Oracle: Solaris Monitoring PowerPack
Before completing the steps in this section, you must import and install the latest version of the "Oracle: Solaris MonitoringPowerPack.
