What is Pure Storage?
Pure Storage is a Flash-based storage solution provider. Its FlashArray solution provides multi-level cell, high-performance Flash memory for applications such as server virtualization, desktop virtualization, database systems, and cloud computing.
What Does the Pure Storage PowerPack Monitor?
The "Pure Storage" PowerPack includes:
- Dynamic Applications to discover and collect configuration and performance data for Pure Storage FlashArrays and component devices
- Device classes for each of the Pure Storage devices monitored
- Event policies and corresponding alerts that are triggered when Pure Storage devices meet certain status criteria
- A sample credential for discovering Pure Storage devices
- Dashboards that display information about Pure Storage devices
Installing the Pure Storage PowerPack
