Credentials
The following section describes how to create credentials for monitoring SNMP-enabled devices:
Creating Credentials for Monitoring SNMP-Enabled Devices
To monitor SNMP-enabled devices with SL1, you must first create an SNMP credential. SNMP Credentials allow SL1 to access SNMP data on a managed device. SL1 uses SNMP credentials to perform discovery, run auto-discovery, and gather information from SNMP Dynamic Applications.
To create SNMP credentials:
  1. Go to theCredentials page (Manage > Credentials).
  2. Click the Create New button and select Create SNMP Credential from the drop-down list that appears.
  4. Create SNMP Credential for Cisco Unity Express
  • Timeout (ms). Enter the time, in milliseconds, after which SL1 will stop trying to communicate with the Cisco Unity Express device. The default value is 1500. This field is required.
  • SNMP Version. Select the version of SNMP that you want to create from the drop-down list. The default value is SNMP V2.
  • SNMP Retries. Keep the default. The default value is "1".
  • Port. Keep the default. The default port is "161".
SNMP V1/V2 Settings
SNMP V3 Settings
  • SHA
  • SHA-224
  • SHA-256
  • SHA-384
  • SHA-512
The SHA option is SHA-128.
  • AES-128
  • AES-192
  • AES-256
  2. Repeat steps 1-4 for each SNMP-enabled device in your network that you want to monitor with SL1.
NOTE: When you define an SNMP Credential, SL1 automatically aligns the credential with all organizations of which you are a member.
Creating Credentials for Monitoring SNMP-Enabled Devices in the SL1 Classic User Interface
To monitor SNMP-enabled devices in the SL1 classic user interface, you must first create an SNMP credential.
  2. Click the Actions button and select Create SNMP Credential. The Credential Editor page appears.
  • Port. The port SL1 will use to communicate with the external device or application. The default value is 161. This field is required.
  • Timeout (ms). Time, in milliseconds, after which SL1 will stop trying to communicate with the SNMP device. The default value is 1500.
  • Retries. Number of times SL1 will try to authenticate and communicate with the external device. The default value is 1.
SNMP V1/V2 Settings
SNMP V3 Settings
  • SHA
  • SHA-224
  • SHA-256
  • SHA-384
  • SHA-512
  • AES-128
  • AES-192
  • AES-256
