This section describes how to configure VMware NSX resources for monitoring by Skylar One using the "VMware: NSXPowerPack.
Prerequisites for Monitoring VMware NSX
To configure Skylar One to monitor VMware NSX using the "VMware: NSXPowerPack, you must first configure an NSX Manager user account to handle RESTful API requests. You will need this account's username and password when creating the Basic/Snippet credential to communicate with the NSX Manager for monitoring.
This API-only user account must be configured in the NSX Manager configuration terminal and have web interface privileges. After you create the user account, perform an API request to give the user account the appropriate role.
To use the Dynamic Applications in the "VMware: NSX" PowerPack, you must create a Basic/Snippet credential for the NSX Manager. The "VMware: NSX" PowerPack includes an example Basic/Snippet credential that you can edit for use with NSX Manager.
An example Basic/Snippet credential that you can clone for your own use is included in the PowerPack.
  2. Locate the "VMware: NSX Credential - Example" credential, then click its Actions icon () and select Duplicate from the drop-down field. The "VMware: NSX Credential - Example copy" credential appears.
  3. Click the Action icon () for the"VMware: NSX Credential - Example copy" credential, then select Edit. The Edit Credential page appears.
  4. Edit the VMware NSX Basic/Snippet credential
  • Timeout. Enter the time, in milliseconds, after which Skylar One will stop trying to communicate with the VMware NSX device. The default value is 30000. This field is required.
  • Hostname/IP.Keep the default. The default is "%D".
  • Port. Keep the default port. The default is "443".
  • Username. Enter the username associated with the VMware NSX administrator account.
  • Password. Enter the password associated with the VMware NSX administrator account.
Creating a Basic/Snippet Credential in the Skylar One Classic User Interface
To use the Dynamic Applications in the "VMware: NSX" PowerPack in the Skylar One classic user interface, you must create a Basic/Snippet credential for the NSX Manager. The "VMware: NSX" PowerPack includes an example Basic/Snippet credential that you can edit for use with NSX Manager.
To modify the template credential, perform the following steps:
  2. Click the wrench icon () for the "VMware: NSX Credential - Example" credential. The Credential Editor modal page appears.
  • Hostname/IP. Type "https://%D".
  • Port. Type "443".
  • Timeout(ms). Keep the default value.
  • Username. Type the username of the NSX API-only administrative user.
  • Password. Type the NSX API-only user's password.
  1. Click the Save As button to save your changes as a new credential.
Discovering a VMware NSX Manager
To monitor your VMware NSX system, you must run a discovery session to discover the server on which VMware NSX is installed.
To create and run a discovery session that will discover a VMware NSX appliance:
  2. On the Credential Selection tab, locate and select the Basic/Snippet credential you created for VMware NSX appliances.
  • List of IP/Hostnames. Type the IP address for the VMware NSX appliance.
    • Select Device Template. If you configured a JMX device template, select it here. Otherwise, leave the default selection.
Discovering a VMware NSX Manager in the Skylar One Classic User Interface
To create and run a discovery session that will discover an NSX Manager, perform the following steps:
  2. Click the Create button to create a new discovery session. The Discovery Session Editor modal page appears.
  • IP Address Discovery List. Type the IP address for the NSX Manager.
  • Other Credentials. Select the Basic/Snippet credential you created.
  1. Optionally, you can enter values in the other fields on this page. For more information about the other fields on this page, see the section on Discovery and Credentials.
  2. Click the Save button and then close the Discovery Session Editor modal page.
  4. The Discovery Session window appears. After Skylar One discovers the NSX Manager, click its device icon () to view the Device Properties page for the NSX Manager.
Viewing Component Devices
In addition to the Device Manager page (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface), you can view the VMware NSX Manager and all associated component devices in the following places in the user interface:
  • The Device Components page (Devices > Device Components) displays a list of all root devices and component devices discovered by Skylar One in an indented view, so you can easily view the hierarchy and relationships between child devices, parent devices, and root devices. To view the component devices associated with the NSX Manager, find the NSX Manager device and click its plus icon (+).
  • The Component Map page (Classic Maps > Device Maps > Components) allows you to view devices by root node and view the relationships between root nodes, parent components, and child components in a map. This makes it easy to visualize and manage root nodes and their components. Skylar One automatically updates the Component Map as new component devices are discovered. Skylar One also updates each map with the latest status and event information. To view the map for NSX devices, go to the Component Map page and select the map from the list in the left NavBar. To learn more about the Component Map page, see the section on Views.
