What is VMware NSX?
NSX is VMware's software-defined network virtualization and security platform. NSX enables users to create virtual networks, including firewalls, switches, routers, ports, and other networking components, which are embedded in a hypervisor rather than a physical environment.
What Does the VMware: NSX PowerPack Monitor?
To monitor NSX virtual networks using Skylar One, you must install the "VMware: NSX" PowerPack. This PowerPack enables you to discover, model, and collect data about NSX virtual network devices.
The "VMware: NSX" PowerPack includes:
- An example credential you can use as a template to create Basic/Snippet credentials to connect to the NSX devices you want to monitor
- Dynamic Applications to discover, model, and monitor performance metrics and collect configuration data for NSX devices
- Device classes for each of the NSX devices Skylar One monitors
- Event policies and corresponding alerts that are triggered when NSX devices meet certain status criteria
- A run book action that automatically classifies the device classes for NSX devices
Installing the VMware: NSX PowerPack
