Introduction to the VMware NSX-T PowerPack
This section describes how to monitor VMware NSX-T in SL1 using the VMware: NSX-T PowerPack.
The following sections provide an overview of VMware NSX-T and the VMware: NSX-T PowerPack:
What Does the VMware: NSX-T PowerPack Monitor?
To monitor VMware NSX-T applications using SL1, you must install the VMware: NSX-T PowerPack. This PowerPack enables you to discover, model, and collect data about VMware NSX-T applications.
The VMware: NSX-T PowerPack includes:
  • A sample credential that you can use as a template to connect to the VMware NSX-T devices you want to monitor
  • Dynamic Applications and Run Book Actions to discover, model, and monitor performance metrics and/or collect configuration data for VMware NSX-T devices
  • Device Classes for each of the VMware NSX-T devices SL1 monitors
  • Event Policies and corresponding alerts that are triggered when VMware NSX-T devices meet certain status criteria
  • A Device Template that enables you to easily align multiple Dynamic Applications to VMware NSX-T devices
Installing the VMware: NSX-T PowerPack
Before completing the steps in this section, you must import and install the minimum SL1 version 11.3.0 then install the latest version of the VMware: NSX-T PowerPack.
Requirements and Limitations
The following limitations and requirements apply to specific functionality in the VMware: NSX-T PowerPack:
  • A new execution environment is available in this version of the PowerPack. However, the old environment will not be deleted. Users should remove the old executions environment after upgrading from VMware: NSX-T v100. To do this, go to System > Customize > ScienceLogic Libraries > Actions > Execution Environments and filter on 'VMware: NSX-T'. There will be two environments shown. Delete the environment that has an Env GUID of "48C1B924812A1C56783FDD0864F7D229".
