The "LayerX Appliance Monitoring" PowerPack has been rebranded as the "VOSS Insights: Appliance Monitoring" PowerPack.
What Does the VOSS Insights: Appliance Monitoring PowerPack Monitor?
The "VOSS Insights: Appliance Monitoring" PowerPack enables you to discover, model, and collect data about VOSS Insights appliances.
The "VOSS Insights: Appliance Monitoring" PowerPack includes the following features:
- Dynamic Applications that discover and monitor VOSS Insights appliances
- Device classes for each type of VOSS Insights appliance monitored
- Device templates for monitoring VOSS Insights Arbitrator devices and VOSS Insights Reporter devices
- Event policies and corresponding alerts that are triggered when VOSS Insights appliances meet certain status criteria
- A sample credential for discovering VOSS Insights appliances
- A credential test to validate credentials
- Run book actions and automation policies to create the device, test collection, check the credential, and apply a device template
Installing the VOSS Insights: Appliance Monitoring PowerPack
