Introduction
This section describes how to collect and analyze metrics from vector Language Learning Model (vLLM ) deployments in SL1 using the Dynamic Applications in the "vLLM Monitoring" PowerPack.
The following sections provide an overview of vLLM and the "vLLM Monitoring" PowerPack:
What Does the vLLM Monitoring PowerPack Monitor?
To monitor vLLM deployments using SL1, you can install the vLLM MonitoringPowerPack. This PowerPack enables you to align Dynamic Applications to vLLM deployments to collect data.
The vLLM MonitoringPowerPack includes:
  • Dynamic Applications that discover and collect data from vLLM.
Installing the vLLM Monitoring PowerPack
Before completing the steps in this section, you must import and install the latest version of the vLLM Monitoring PowerPack.
