Root Cause Report Incoming Webhook
Features
- This section provides detailed information on webhook support provided by Skylar Automated RCA so you can build your own custom integrations.
- Root Cause report incoming webhooks provide a generic mechanism for requesting Root Cause analysis for a specific time. This can be useful for integrating with third-party of custom solutions for which a specific integration is not currently available from Skylar Automated RCA.
STEP 1: Create a Root Cause Report Incoming Webhook Integration in Skylar Automated RCA
- In the Skylar Automated RCA user interface, go to the Integrations & Collectors page (Settings (
) > Integrations & Collectors). - In the Webhooks section, click the button.
- Click button. The Create Incoming RCA Webhook dialog appears.
- On the tab, enter an Integration Name for this integration.
- In the Deployment drop-down, select a deployment for the integration.
- In the Service Group(s) drop-down, select a service group for the integration. You can select Any to see suggestions for all Service Groups.
- On the tab, click .
- Copy and save the contents of the Your URL text box for use in STEP 2, below.
STEP 2: Request a Root Cause Report from Skylar Automated RCA
Send a POST request to the URL created in STEP 1 with the required payload:
curl -X POST -H 'Content-type: application/json' --data '<REQUEST_JSON_PAYLOAD>' <URL_FROM_STEP_1>
Webhook Payload Format
See Root Cause Report Incoming Webhook Payload, below, for a detailed description of the webhook payload.
| Method URL | URL created for this integration |
| HTTP Method | POST |
| Content Type | application/json |
Payload
| Name | Type | Description | Required |
| zebrium.incident_ts | string | UTC Timestamp to perform RC Analysis, such as "2022-03-15T08:23:05Z" | Yes |
| zebrium.service_group | string | Service group to perform RC Analysis or ‘All’ | Yes |
Example Payload
"zebrium" : {
"incident_ts" : "2022-03-15T08:23:05Z",
"service_group" : "production"
}curl -X POST -H 'Content-type: application/json' --data '{ "zebrium" : { "incident_ts" : "2022-03-15T08:23:05Z",
"service_group" : "production" } }' https://cloud.zebrium.com/api/v2/signal/E0D2C20624779984FADBE0D22E4125860A37299B
