Read Signal
Use this request to get the status of a signal.
| Method URL
http://<mwsd_container_url>:<mwsd_port>/mwsd/v1/signal/read |
| HTTP Method
POST |
| Content Type
application/json |
Request Arguments
| filter |
list |
List of SRID filter strings of the format “srid=<SRID>” where SRID is the srid returned from incident/create/signal API call. |
Example Request Payload
"filter": [ "srid=000615d0-39a0-0000-0000-00fffff00004" ]
Example Response Payload
- bake_ct. Number of bakes that have run since signal created.
- expired. Set to True after three bakes have run.
- created_incident. Set to True if an incident was created as a result of this signal request
- Use the incident/read/list API with the inci_signal filter set to the <SRID> to get the list of incidents created as result of this signal request.
"data": [
"bake_ct": 1,
"create_time": "2021-10-06T04:21:32.472795Z",
"created_incident": true,
"epoch": 1633485722000,
"event_type": "zebrium_incident",
"expired": false,
"integration": "zebrium",
"local_time": "Tue Oct 5 19:02:02 PDT 2021",
"modify_time": "2021-10-06T04:22:35.043531Z",
"payload_data": "{\"zebrium\": {\"epoch_ts\": \"2021-10-06T02:02:02Z\", \"epoch_msec\": 1633485722000, \"epoch_local\": \"Tue Oct 5 19:02:02 PDT 2021\", \"deployment\": \"trial\", \"service_group\": \"ops-blue\"}, \"slack\": null}",
"service_group": "ops-blue",
"siid": "765afdaa-e85b-43e5-baa4-16214de10296",
"srid": "000615d0-39a0-0000-0000-00fffff00004",
"ssid": "a3593b9e-7858-429e-981e-2d9e50dab43a",
"ts": "2021-10-06T02:02:02Z"
"error": {
"code": 200,
"data": null,
"message": ""
"op": "create",
"softwareRelease": "20210412141334"
