What Does the HPE: Aruba Networking Central PowerPack Monitor?
This PowerPack enables you to align Dynamic Applications to HPE: Aruba Networking Central devices to collect data. To monitor HPE: Aruba Networking Central devices using Skylar One, you can install the "HPE: Aruba Networking Central" PowerPack.
The "HPE: Aruba Networking Central" PowerPack includes:
- Dynamic Applications that discover and collect data from HPE: Aruba Networking Central access points, SD-WAN gateways, and switches.
- Event policies and corresponding alerts that are triggered when HPE: Aruba Networking Central devices meet certain status criteria.
- A universal credential and guided discovery workflow for discovering HPE: Aruba Networking Central devices.
Installing the HPE: Aruba Networking Central PowerPack
