Integrating Data from Other Products
This chapter covers how to integrate Skylar Advisor with Slack and Microsoft Teams, and to share conversations and import external data.
Sharing Information with Slack and Microsoft Teams Integrations
On the Integrations page ( > Account Settings > Account Access > Integrations), you can create integrations with Slack and Microsoft Teams using webhooks. These integrations let users share an Ask Skylar conversation with other users by using the Share a Conversation icon () and the Collaborate pane.
Creating an Integration with Slack or Teams
Before you can create the integration in the Skylar Advisor user interface, you will first need to locate a webhook in either Slack or Teams. To locate the webhook, see the documentation for Slack or Teams, or ask Skylar AI using the Ask Skylar feature.
To create an integration with Slack or Teams:
  1. In Skylar Advisor, go to the Integrations page ( > Account Settings > Account Access > Integrations) and click Add Integration. A drop-down appears.
  2. Select either Slack or Microsoft Teams. An integration pane appears to the right.
  • Integration Name. Type a name for this integration.
  • Enabled. To use this integration immediately, leave this option at the default (blue). To disable this integration, click the toggle to turn it white.
  • Advisor Instances. Select one or more instances in your Skylar Advisor system where you want to be able to share conversations.
  • Webhook URL. Paste the webhook URL you found for Slack or Teams.
  2. To test the connection, click the Test Connection button at the bottom of the integration pane.
Sending a Conversation to Slack or Teams
To send a conversation to a Slack or Teams channel:
  1. From the Ask Skylar prompt box for an existing conversation, click the Collaborate with others icon () at the bottom right. A Collaborate pane appears.
  2. Click the Slack or Teams button. A Send to window appears.
  • Select Channels. For Teams only, select a channel from the list.
  • Title. Type a title for the conversation.
  • Summary. Update the existing summary as needed.
  • Compact Summary. Click this button to have Skylar Advisor optimize the summary before sending it to the channel.
  1. Click Send to Slack or Send to Teams. The conversation is sent to the specified channel, with a link to return back to the Ask Skylar conversation. The conversation is also added to the Shared section on the Recent Activity tab of the Dashboards page. You might need to click the refresh icon () to see the most recent questions and answers in this conversation.
Importing ServiceNow Data into Skylar Advisor
If you use ServiceNow to track incidents, alerts, or cases, or if you want to sync your ServiceNow Knowledge Base (KB) articles, you can use the "Skylar Advisor" SyncPack to import that ServiceNow data into Skylar Advisor using Skylar Automation.
The "Skylar Advisor" SyncPack lets you retrieve the content of KB articles from ServiceNow and send those articles as PDF attachments for Skylar Advisor to ingest. You can also synchronize the following ServiceNow data types:
  • Incidents
  • Cases
  • Alerts (Event Management)
  • Change Requests
To enable these features, you need to create an access token in Skylar Settings. For more information, see Creating Access Tokens for Users.
When you have the Skylar Advisor access token, you need to add it to a configuration object in Skylar Automation along with the SyncPack. For more information, see the Skylar Advisor SyncPack manual.
Minimum Version Requirement
The "Skylar Advisor" SyncPack requires "ServiceNow Base" SyncPack 4.0.0 or later.
The SyncPack does not require a specific version of the ServiceNow release.
Supported Data Synchronization
To enable these features, you need to create an access token in Skylar Settings. For more information, see Creating Access Tokens for Users. When you have the Skylar Advisor access token, you need to add it to a configuration object in Skylar Automation along with the SyncPack. For more information, see the Skylar Advisor SyncPack manual.
The following table lists the ServiceNow data types that you can synchronize with Skylar Advisor:
Data Type Supported Direction Notes
Knowledge Base articles
Yes
Unidirectional
Includes PDF attachments under 4 MB each.
Incidents
Yes
Bidirectional
Advisories can create incidents in ServiceNow.
Cases
Yes
Unidirectional
Yes
Unidirectional
Change Requests
Yes
Unidirectional
Problems
No
Not yet available.
Knowledge Base Filtering
Skylar Advisor supports ServiceNow encoded query filters for knowledge base synchronization.
Synchronization Approach
  • Initial historical load. Pulls all existing Knowledge Base articles for onboarding and backfill scenarios.
  • Maintenance sync. Picks up records created or updated within the configured lookback period. This lightweight sync can run at a frequency you agree on with ScienceLogic.
Available Controls
Current controls are structural rather than content-based. You can scope which parts of the ServiceNow estate are ingested, but you cannot apply every filter within that scope.
Filter or Control Supported Details
Organization or business unit
Yes
Ingestion is partitioned by ServiceNow domain and company. Unmapped records default to a catch-all organization, so confirm organization mapping before onboarding.
Domains or folders
Yes
Can be used to scope ingestion.
Age
Yes
Can be used to limit content by age.
Tags
No
Not currently available.
File types
PDF only
PDF attachments must be under 4 MB each.
