The following workflows describe how to configure Skylar One and Skylar Automation to work with the "Ansible" SyncPack.
Configuring Skylar One
- Enable the Ansible event policies
- Create a SOAP/XML credential to access Skylar Automation
- Edit the Ansible run book actions
- Enable the Ansible run book automations
Configuring Skylar Automation
- Align the configuration object and configure the Ansible Skylar Automation applications
- Schedule the Skylar Automation applications
The following topics cover how to set up your Skylar One instance to work with the "Ansible" SyncPack.
Enabling the Ansible Event Policies
The "Ansible Automation" PowerPack includes the following event policies that you can enable to trigger the events detected by the applications included in the "Ansible" SyncPack:
- "Ansible-Command"
- "Ansible-Tower"
To enable the event policies:
- In Skylar One, go to the Event Policies page (Events > Event Policies, or Registry > Events > Event Manager in the classic SL1 user interface).
- Click the check boxes for the "Ansible-Command" and "Ansible-Tower" event policies. A row of buttons appear at the top of the list.
- Click . The Status for both policies is updated to "Enabled".
Creating a SOAP/XML Credential to Access Skylar Automation
You will need to create a SOAP/XML credential so that the action policies included in the "Ansible Automation" PowerPack can access your Skylar Automation system.
- In Skylar One, go to the Credentials page (Manage > Credentials).
- Click and select Create SOAP/XML Credential. The Create Credential window appears.
- URL. Type the URL for your Skylar Automation system.
- HTTP Auth User. Type the username for your Skylar Automation system.
- HTTP Auth Password. Type the password for your Skylar Automation system.
- Take note of the Skylar One-assigned ID number for the new credential on the Credentials page, in the ID column. You will need the ID number when editing the input parameters of the run book actions included in the PowerPack, below.
Editing the Ansible Run Book Actions
The "Ansible Automation" PowerPack includes the following run book action policies:
- Ansible: Command (triggers the "Call Playbook from Ansible CLI" application in Skylar Automation)
- Ansible: Tower (triggers the "Call Playbook from Ansible Tower" application in Skylar Automation)
These action policies use the "Run Integration Service Application" action type to trigger the corresponding Skylar Automation application that collects data from Ansible. You can specify the credential ID in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
- In Skylar One, go to the Actions page (Registry > Run Book > Actions).
- Locate the action policy that you want to use ("Ansible: Command" or "Ansible: Tower"), and then click its wrench icon (
Enabling the Ansible Run Book Automations
The "Ansible Automation" PowerPack includes the following run book automation policies that you will need to enable, depending on which Ansible application you are monitoring:
- "Ansible:Command"
- "Ansible:Tower"
These policies update the Skylar One event with the state of the associated Ansible Command or Ansible Tower.
- In Skylar One, go to the Automation page (Registry > Run Book > Automation).
- Locate the "Ansible:Command" run book automation policy and click its wrench icon (
- Policy Priority. Select High to ensure that this Skylar Automation automation policy is added to the top of the queue.
- Repeat steps 2-4 for the "Ansible:Tower" run book automation policy.
Configuring PowerFlow
The following topics cover how to set up your Skylar Automation instance to work with the "Ansible" SyncPack.
A configuration object supplies the login credentials and other required information needed to execute the steps for a Skylar Automation application. The Configurations page () of the Skylar Automation user interface lists all available configuration objects for that system.
You can create as many configuration objects as you need. A Skylar Automation application can only use one configuration object at a time, but you can use (or "align") the same configuration object with multiple applications.
For this SyncPack, you should make a copy of the "Sample Ansible Configuration" configuration object, which is the sample configuration file that was installed with the "Ansible" SyncPack.
The "Sample Ansible Configuration" configuration object contains all of the required variables. Simply update the variables from that object to match your Skylar One and Ansible settings.
To create a configuration object based on the "Sample Ansible Configuration" configuration object:
- In the Skylar Automation user interface, go to the Configurations page (
Click the button (
) for the "Sample Ansible Configuration" configuration object and select Edit. The Configuration pane appears.
- In the Configuration Data field, update the default variable definitions to match your Skylar Automation configuration:
- sl1_host. Type the hostname or IP address of the Skylar One system the alerts will synchronize with.
- ansible_url. Enter the URL for your Ansible system.
- ansible_username. Type the username for your Ansible system.
- ansible_password. Type the password for your Ansible system.
- template_id. Type the Ansible Tower template ID. This field is only required if you are monitoring an Ansible Tower.
- host_name. Type the host name for your Ansible system.
- playbook. Type the name of your Ansible playbook.
- inventory_id. Type the Ansible Tower inventory ID. This field is only required if you are monitoring an Ansible Tower.
- credential_id. Type the Ansible Tower credential ID. This field is only required if you are monitoring an Ansible Tower.
- ssh_username. Type your SSH username.
- ssh_password. Type your SSH password.
- host_name_status. Toggle on (blue) to enter the host name status from the event details.
- ssh_pem_status. Toggle on (blue) to enter the SSH status from the event details.
- ssh_pem. Enter the RSA key for SSH connection and type "\n" before and after your RSA key.
- ssh_host. Type your SSH host name.
- add_template. Toggle the JSON editor to define a message for the description field in the Skylar One event.
For more information about the Ansible terms and concepts in this section, see the Ansible documentation.
Aligning a Configuration Object and Configuring Skylar Automation Applications
In Skylar Automation, you will need to align the "Ansible" SyncPack applications with the relevant configuration object, and, if needed, update any other fields on the Configuration pane for the applications.
To align the configuration object with the relevant Skylar Automation applications:
- On the Applications page of the Skylar Automation user interface, open one of the Ansible Skylar Automation applications and click . The Configurations pane for that application appears.
- Repeat this process for the other Skylar Automation applications.
Scheduling Skylar Automation Applications
If you want to use the following Skylar Automation applications, you must schedule them. ScienceLogic recommends that you schedule the following Skylar Automation applications:
- "Ansible Tower Job Status Update": Every five minutes
- "Clear Skylar One Events": Every 10 minutes
You can create one or more schedules for a single application in the Skylar Automation user interface. When creating each schedule, you can specify the queue and the configuration file for that application.
To create a schedule:
- On the Applications page (
- Click the down arrow icon (
) and select.
On the Scheduler window for a Skylar Automation application, you can click the button from the Schedule List pane to make a copy of an existing schedule.
When either multiple Skylar One instances or multiple Ansible instances are involved with Skylar Automation, you should create an individual configuration object for each Skylar One or Ansible instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single Skylar One or Ansible instance. Creating copies of a Skylar Automation application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
