The following workflows describe how to configure Skylar One and Skylar Automation to work with the "CrowdStrike Falcon" SyncPack.
Configuring Skylar One
- Enable the CrowdStrike event policy
- Create a SOAP/XML credential to access Skylar Automation
- Edit the CrowdStrike run book action
- Enable the CrowdStrike run book automation
Configuring Skylar Automation
- Align the configuration object and configure the Skylar Automation applications
- Schedule the Skylar Automation applications
The following topics cover how to set up your Skylar One instance to work with the "CrowdStrike Falcon" SyncPack.
Enabling the CrowdStrike Event Policy
The "CrowdStrike Falcon Automation" PowerPack includes one standard API event policy, "CrowdStrike: Alert to Event", which triggers the events detected by the Skylar Automation applications included in the "CrowdStrike Falcon" SyncPack and the associated automation action policy.
To enable the event policy:
- Go to the Event Policies page (Events > Event Policies, or Registry > Events > Event Manager in the classic SL1 user interface).
- Click the Actions menu for the "CrowdStrike: Alert to Event" event policy and select Edit. The Event Policy Editor page appears.
- Click the Enable Event Policy toggle to enable the event policy and click .
Creating a SOAP/XML Credential to Access Skylar Automation
You must create a SOAP/XML credential so that the action policies included in the PowerPack can access your Skylar Automation system. The "CrowdStrike Falcon Automation" PowerPack includes the "PowerFlow CrowdStrike" sample credential that you can edit to use with your Skylar Automation system.
- Locate the "PowerFlow CrowdStrike" sample credential, click its icon (
), and select Duplicate. A copy of the credential, called PowerFlow CrowdStrike copy appears.
- URL. Type the host name for your Skylar Automation system.
- HTTP Auth User. Type the administrator username for your Skylar Automation
- HTTP Auth Password. Type the administrator password for your Skylar Automation system.
- Take note of the Skylar One-assigned ID number for the new credential on the Credentials page, in the ID column. You will need the ID number when editing the input parameters of the automation actions included in the PowerPack, below.
Editing the CrowdStrike Run Book Action
The "CrowdStrike Falcon Automation" PowerPack includes one action policy that uses the "Run Integration Service Application" action type to trigger the Skylar Automation application that collects data from CrowdStrike. You can specify the credential ID in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
- credential_id. Change the value to the credential ID that you noted earlier whencreating a credential for your PowerFlow system in the previous procedure. This parameter is required.
Enabling the CrowdStrike Run Book Automation
The "CrowdStrike Falcon Automation" PowerPack includes the "Crowdstrike: Clear Detection ID" automation policy that updates the Skylar One event with the state of the associated CrowdStrike job. When a node is offline, a failure occurs, or a major event is detected in CrowdStrike, a Skylar One event is created and the associated event is updated with any job details.
To enable the run book automation:
- In Skylar One, go to the Automations page (Registry > Run Book > Automation).
- Locate the "Crowdstrike: Clear Detection ID" automation policy and click its wrench icon (
- Policy Priority. Select High to ensure that this Skylar Automation automation policy is added to the top of the queue.
- Available Actions. If it is not already selected, select "Run Integration Service Application: CrowdStrike: Clear Detection ID" and click the arrows to move it to Aligned Actions.
The following topics cover how to set up your Skylar Automation instance to work with the "AWS Incident Manager" SyncPack.
A configuration object supplies the login credentials and other required information needed to execute the steps for a Skylar Automation application. The Configurations page () of the Skylar Automation user interface lists all available configuration objects for that system.
You can create as many configuration objects as you need. A Skylar Automation application can only use one configuration object at a time, but you can use (or "align") the same configuration object with multiple applications.
For this SyncPack, you should make a copy of the "CrowdStrike Sample Configuration" configuration object, which is the sample configuration file that was installed with the "CrowdStrike Falcon" SyncPack.
The "CrowdStrike Sample Configuration" configuration object contains all of the required variables. Simply update the variables from that object to match your Skylar One and CrowdStrike settings.
To create a configuration object based on the "CrowdStrike Sample Configuration" configuration object:
- In the Skylar Automation user interface, go to the Configurations page (
Click the button (
) for the "CrowdStrike Sample Configuration" configuration object and select Edit. The Configuration pane appears.
- In the Configuration Data field, update the default variable definitions to match your Skylar Automation configuration:
- sl1_host. Type the hostname or IP address of the Skylar One system the alerts will synchronize with.
- crowdstrike_url. Enter the URL for your CrowdStrike system.
- crowdstrike_username. Type the username for your CrowdStrike system.
- crowdstrike_password. Type the password for your CrowdStrike system.
- job_name. Type the name for your CrowdStrike job.
- receiver_mail. Type the email address that you want to receive updates on Skylar One events and your CrowdStrike jobs.
- sender_mail. Type the email address that you want updates on Skylar One events and your CrowdStrike jobs to send from.
- sender_mail_password. Type the password for the sender email address that you entered.
- mailserver. Type the server for your sender email.
- mailserverport. Type the port for your sender email.
The following fields are required only if you choose to manually create a virtual device for your CrowdStrike instance:
- device_class_id. Type the device class ID for your CrowdStrike instance.
- collector_group_id. Type the collector group ID for your CrowdStrike instance.
- device_id.Type the device ID for your CrowdStrike instance.
For more information about the CrowdStrike terms and concepts in this section, see the CrowdStrike documentation.
Aligning a Configuration Object and Configuring Skylar Automation Applications
You will need to align the following "CrowdStrike Falcon" SyncPack applications with the configuration object you just created in Skylar Automation:
- "Fetch Detections from CrowdStrike and Send Alert to Skylar One"
- "Clear Detection from Cache"
To align the configuration object with the relevant Skylar Automation applications:
- On the Applications page of the Skylar Automation user interface, open one of the Skylar Automation applications listed above and click . The Configurations pane for that application appears.
- Update any other fields on the Configuration pane for the application as needed.
- Repeat this process for the remaining Skylar Automation application.
Scheduling Skylar Automation Applications
ScienceLogic recommends that you schedule the following Skylar Automation applications:
- "Fetch Detections from CrowdStrike and Send Alert to Skylar One": every 60 seconds
- "Clear Detection from Cache": at least once a week
You can create one or more schedules for a single application in the Skylar Automation user interface. When creating each schedule, you can specify the queue and the configuration file for that application.
To create a schedule:
- On the Applications page (
- Click the down arrow icon (
) and select.
On the Scheduler window for a Skylar Automation application, you can click the button from the Schedule List pane to make a copy of an existing schedule.
When either multiple Skylar One instances or multiple CrowdStrike instances are involved with Skylar Automation, you should create an individual configuration object for each Skylar One or CrowdStrike instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single Skylar One or CrowdStrike instance. Creating copies of a Skylar Automation application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
