Configuring Skylar Automation Applications for the Opsgenie SyncPack
This section describes how to set up the run book automations in Skylar One and how to configure the Skylar Automation applications in the "Opsgenie" SyncPack.
The following workflows describe how to configure Skylar One and Skylar Automation to work with the "Opsgenie" SyncPack.
Configuring Skylar One
  1. Create a SOAP/XML credential to access Skylar Automation
  2. Edit the Opsgenie run book actions
  3. Enable the Opsgenie run book automations
  1. Create and align a Skylar Automation configuration object
  2. Configure the Opsgenie Skylar Automation applications
The following topics cover how to set up your Skylar One instance to work with the "Opsgenie" SyncPack.
Creating a SOAP/XML Credential to Access Skylar Automation
You will need to create a SOAP/XML credential so that the action policies included in the "Opsgenie Incident Integration" PowerPack can access your Skylar Automation system.
The "Opsgenie Incident Integration" PowerPack includes the "Skylar Automation Opsgenie" credential, which you can use as a template for a SOAP/XML credential.
  2. Click the wrench icon () for the "Skylar Automation Opsgenie" credential. The Credential Editor modal window appears.
  • HTTP Auth User. Type the username for your Skylar Automation system.
  • HTTP Auth Password. Type the password for your Skylar Automation system.
Editing the Opsgenie Run Book Actions
The "Opsgenie Incident Integration" PowerPack includes five automation action policies. These action policies use the "Run Integration Service Application" action type to trigger the Skylar Automation application that sends and receives data to Opsgenie. You can specify the credential ID in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
  2. Locate the "Opsgenie automation action that you want to use and click its wrench icon (). The Editing Action page appears.
Enabling the Opsgenie Run Book Automations
The "Opsgenie Incident Integration" PowerPack includes five standard automation policies that you will need to enable.
These policies update the Opsgenie alert or Skylar One events with the state of the associated event or alert, create a maintenance object, or populates Skylar One with on-call details. When the event is first detected in Skylar One or Opsgenie, the "triggered" state is sent. When the event is acknowledged in Skylar One or Opsgenie, the "acknowledged" state is sent. When the event is cleared in Skylar One or Opsgenie, the "resolved" state is sent. When the on-call policy is triggered, on-call details are added to the Skylar One event notes. When a maintenance object is required, a maintenance object is created in Opsgenie.
If you enable the "Opsgenie: Acknowledge Alert", "Opsgenie: Resolve Alert", and "Opsgenie: Trigger Alert" automation policies, it is best practice to align the same devices for all three policies.
Opsgenie: Acknowledge Alert All events Opsgenie: Acknowledge Alert
Opsgenie: Maintenance All events Opsgenie: Maintenance Alert
Opsgenie: Oncall Trigger All events Opsgenie: Oncall
Opsgenie: Resolve Alert All events Opsgenie: Resolve Alert
Opsgenie: Trigger Alert All events Opsgenie: Trigger Alert
  2. Locate an "Opsgenie" automation policy and click its wrench icon (). The Automation Policy Editor page appears.
  • Available Actions. If it is not already selected, select the "Run Integration Service Application: <name>" action that corresponds with the Ansible automation policy you selected in step 2, and click the arrows to move it to Aligned Actions.
  2. Repeat steps 2-4 for the remaining "Opsgenie run book automation policies.
Configuring PowerFlow
The following topics cover how to set up your Skylar Automation instance to work with the "Opsgenie" SyncPack.
For this SyncPack, you can make a copy of the "Opsgenie Config" configuration object, which is the sample configuration file that was installed with the "Opsgenie" SyncPack.
The "Opsgenie Config" configuration object contains all of the required variables. Simply update the variables from that object to match your Skylar One and Opsgenie settings.
To create a configuration object based on the "Opsgenie Config" configuration object:
  2. Click the Actions button () for the "Opsgenie Config" configuration object and select Edit. The Configuration pane appears.
  1. In the Configuration Data field, update the default variable definitions to match your Skylar Automation configuration:
  • opsgenie_api_key. The API key for the Opsgenie Team that you want to send alerts to. You can generate an API key for Skylar One to use in the Integrations page of the Opsgenie user interface.
  • opsgenie_univ_api_key. The universal API key for Opsgenie. For information on adding an API key in Opsgenie, see https://support.atlassian.com/opsgenie/docs/api-key-management/.
  • proxy_host. The hostname or IP address of the HTTP proxy that will be used when making an API request to Opsgenie.
  • proxy_protocol. The protocol of the HTTP proxy. Enter either 'HTTP' or 'HTTPS'.
  • sl1_host. The hostname or IP address of the Skylar One system the alerts will synchronize to.
  • schedule_name. The name of the on-call schedule on Opsgenie to query when collection the current on-call user(s).
  • maintenance_description. The description of your Opsgenie maintenance.
  • maintenance_policy_id. The ID of your Opsgenie maintenance.
  • maintenance_time_length. The time configuration of your Opsgenie maintenance.
  • maintenance_state. The state rule defined in maintenance.
  • device_id. The Skylar One device ID that the Opsgenie Heartbeat application will use when sending alerts. Typically, this is a device that represents the Opsgenie service.
  • heartbeat_name. The name of your Heartbeat URL.
  • opsgenie_base_url. The base URL of the Alert Rest API.
  • opsgenie_private_instance_url. The URL to use for links to the Opsgenie user interface. Enter the base URL you navigate to. This URL will be displayed in Skylar One and will open your Opsgenie instance in a browser.
  • resolve_from_org. The option to resolve events from Opsgenie
  • default_ack_user. The default user to acknowledge events and alerts.
  • populate_external_url. The option to add an Opsgenie incident URL to the corresponding Skylar One event.
With this SyncPack, any status changes made to a Skylar One event is sent to Opsgenie to update the corresponding alert. Any status changes to the Opsgenie alert are synced back to the corresponding Skylar One event. You will need to align the Opsgenie applications with the relevant configuration object in Skylar Automation, and, if needed, update any other fields on the Configuration pane for the applications.
To run this SyncPack, you must "align" the configuration object to run with the following Skylar Automation applications:
  • "Bulk Clear Skylar One Events"
  • "Create Opsgenie Maintenance"
  • "Get Oncall Details From Opsgenie and Send to Skylar One"
  • "Opsgenie Heartbeat"
  • "Pass Acknowledgment details from Opsgenie to Skylar One"
  • "Close Opsgenie Alert"
  • "Save Accounts To Cache"
  • "Create Alert in Opsgenie from a received Skylar One event"
  1. On the Applications page of the Skylar Automation user interface, open one of the Skylar Automation applications listed above and click Configure. The Configurations pane for that application appears.
  2. Click Save.
  3. Repeat this process for the other Skylar Automation applications.
To trigger some applications in this SyncPack, you must schedule the application. If you want to use the following applications, you must schedule the application. ScienceLogic recommends that you schedule the following Skylar Automation applications:
  • "Bulk Clear Skylar One": Every minute
  • "Opsgenie Heartbeat": Every 5 minutes
  • "Pass Acknowledged Alerts from Opsgenie to Skylar One": Every minute
  • "Save Accounts To Cache": Every hour
To create a schedule:
When either multiple Skylar One instance or multiple Opsgenie instances are involved with Skylar Automation, you should create an individual configuration object for each Skylar One or Opsgenie instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single Skylar One or Opsgenie instance. Creating copies of a Skylar Automation application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
