Contents of the ServiceNow Base SyncPack
The contents of the ServiceNow Base SyncPack can be used by all of the ServiceNow SyncPacks.
This section lists the contents of the "ServiceNow Base" SyncPack.
Skylar Automation Applications
Organization Sync. The "Sync Organizations from Skylar One to ServiceNow" application syncs organizations from Skylar One with ServiceNow companies. In this context, sync means that if you update a company in ServiceNow, the Organization Sync process will update the Skylar One organization with that information, and vice versa.
Cache ServiceNow Companies, CIs and Skylar One Orgs, Device Classes. Reads all existing Skylar One Organizations, Skylar One Device Classes, ServiceNow Companies, and ServiceNow CIs and writes them to a cache. To perform a Device Sync in the "ServiceNow CMDB" SyncPack, you must run this application before you run the "Sync Devices from Skylar One to ServiceNow" application. Before version 3.5.0 of this SyncPack, this application was named "Cache ServiceNow CIs and Skylar One Device Classes".
Post Data to ServiceNow Import Table. Posts data to the ServiceNow import table to be processed.
Bulk Clear Skylar One Events. Bulk clears Skylar One events.
Bulk Update Skylar One Events. Bulk updates Skylar One events with a given payload.
Configuration Object
- ServiceNow SyncPack. Contains a set of required variables. As a best practice, use the button to make a copy of the configuration object, and then update the variables from that object to match your Skylar One and ServiceNow settings. Do not use the original version of the configuration to run Skylar Automation applications.
Steps
Clear SL1 Events
Compare Organizations
Fetch Parent Devices from SL1
Merge and Chunk Payloads For ServiceNow
MySQL Multiple
Optional GQLRequest Call
Optional QueryGQL Call
Posts Batches to ServiceNow
Post company payloads to ServiceNow
Post Event Details to SL1Update SL1 Event With ServiceNow Ticket Data
Post Attribute Rest Calls to SL1
Process IS Configs
Process Event Data for Clear
Process SL1 RBA for Incident of Case
Parse ServiceNow Cases and Incidents
Pull and Process ServiceNow Company Domains
Pull and Process SL1 Events
Pull and Process SL1 Organizations
Pull and Process ServiceNow CI tables
Pull and Process ServiceNow Rel Types
Pull Tickets from ServiceNow
Query and Cache SL1 Device Class info
Query and ServiceNow CI info
Parse SL1 Event Details
Post ServiceNow Ticket Details to SL1
ServiceNow DELETE with OAuth Option
ServiceNow GQL Request with OAuth Option
ServiceNow GET with OAuth Option
ServiceNow POST with OAuth Option
ServiceNow POST with paging
