Introduction to the ServiceNow Change Management SyncPack
This section describes the "ServiceNow Change Management" SyncPack, which is the ScienceLogic integration with the ServiceNow Change Management Module. You can use this SyncPack to place Skylar One devices into and out of maintenance mode.
You do not need the ServiceNow Events Module to use this SyncPack. However, you will need to install and run the "ServiceNow CMDB" SyncPack on the same Skylar Automation system as this SyncPack.
The "ServiceNow Change Management" SyncPack is the ScienceLogic integration with the ServiceNow Change Management Module. You can use this SyncPack to place Skylar One devices into and out of maintenance mode.
You can configure Skylar Automation to generate a Skylar One event when a maintenance-related change occurs. The Skylar One event contains data about the change request from ServiceNow, including a hyperlink to the ServiceNow change record. The event is aligned with a device in Skylar One, and if the device is part of a Business Service in Skylar One version 11.1.0 or later, the event displays on the Change Events tab for that Business Service. This sync of proposed ServiceNow change requests to Skylar One events requires the ServiceNow MID Server.
(missing or bad snippet)
Contents of the SyncPack
This section lists the contents of the "ServiceNow Change Management" SyncPack.
The following Skylar Automation applications are included with the "ServiceNow Change Management" SyncPack:
  • Create or Update Maintenance Schedule from ServiceNow Trigger. Handles scheduling and canceling maintenance schedules in Skylar One using a trigger from a ServiceNow Management, Instrumentation, and Discovery (MID) Server. When triggered, the application gathers data about the change request in ServiceNow and generates a Skylar One Event with a severity of Notice. For more information, see Syncing Device Maintenance from ServiceNow to Skylar One.
  • Sync Change Management Requirements. Sends configuration data from Skylar Automation to ServiceNow to use with change management and other processes. For more information, see Configuring and Running the "Sync Change Management Requirements" Application in PowerFlow.
  • Sync Maintenance Schedules from ServiceNow to Skylar One. Syncs maintenance windows from ServiceNow change requests (CHG)s to Skylar One devices to place the synced devices into maintenance mode for the scheduled change window. If you are scheduling this application, ScienceLogic recommends that you schedule it to run every hour or so, depending on your environment. This process does not require the use of a ServiceNow MID Server. For more information, see Scheduling Device Maintenance (No MID Server).
  • Trigger Device Maintenance Updates via MID Server. Lets you sync maintenance windows from ServiceNow to Skylar One using a ServiceNow Management, Instrumentation, and Discovery (MID) Server. For more information, see Using a MID Server to Place a Device Directly in Maintenance or Schedule a Maintenance Window.
Skylar Automation Applications (Internal)
To view the internal Skylar Automation applications, click the Filter icon () on the Applications page and select Show Hidden Applications. Internal applications are hidden by default. The following applications are "internal" applications that should not be run directly, but are automatically run by applications from the previous list:
  • Cancel Maintenance. Cancels a scheduled maintenance in Skylar One.
  • Create Maintenance. Creates a scheduled maintenance in Skylar One.
  • Modify Maintenance. Updates a scheduled maintenance in Skylar One.
  • Process Create Schedule Requests. Schedules and posts maintenance tasks in ServiceNow.
  • Remove Maintenance. Removes a scheduled maintenance in Skylar One.
  • Schedule Maintenance. Creates a scheduled maintenance in Skylar One.
