Configuring Applications for the Slack SyncPack
This section describes how to set up the Skylar Automation applications for the "Slack" SyncPack.
The following workflows describe how to configure Slack, Skylar One, and Skylar Automation to work with the "Slack" SyncPack.
Configuring Slack
  1. Create an app in Slack
  2. Enable Incoming Webhooks
  3. Add and Configure Bots
  4. Add Slash commands for your app
  5. Activate Interactivity for your app
  6. Install your app
Configuring Skylar One
  1. Create a credential for the action policies in the "Slack Integration" PowerPack
  2. Align the Skylar One action policies
Configuring Skylar Automation
  1. Create a Skylar Automation configuration object
  2. Align the configuration object and configure Skylar Automation applications
Configuring Slack
The following topics cover how to set up Slack to work with this SyncPack.
  1. Go to https://api.slack.com/apps and click Create New App.
  2. The Create an app dialog appears.
  3. Select From scratch.
  4. The Name app & choose workspace dialog appears.
  5. Enter a name for the application in the App Name field.
  6. In the drop-down menu under Pick a workspace to develop your app in, select the appropriate workspace.
  7. Click the Create App button.
  8. The Basic Information page appears, with the new app available in the drop-down menu at the top left.
Enable Incoming Webhooks for your app
  1. On the Basic Information page, click Incoming Webhooks from the Add features and functionality section.
  2. Toggle on (green) Activate Incoming Webhooks.
You may need to first request permission to add a webhook from your Slack Administrator.
  1. Click the Add New Webhook to Workspace button under the Webhook URLs for Your Workspace section.
  2. Select the channel you want to receive messages to from the Where should <app_name> post? field.
  3. Click the Allow button.
Be sure to add the channel in Slack where you want to receive messages to, if you do not want messages to post to an existing channel. If you want to receive messages in multiple channels, you can add multiple webhook urls for different channels in your workspace.
Enable Bots for your app
  1. Click App Home from the Features menu on the left.
  2. Click the Edit button under Your App's Presence in Slack.
  3. On the Edit App Display Name dialog, edit the name of the bot in the Display Name (Bot Name) field, if needed.
  4. Edit the username of the bot in the Default username field, if needed.
  5. Click the Save button.
  6. Click OAuth & Permissions from the Features menu on the left.
  7. Configure the permissions that the bot has in your app:
    •  On the OAuth & Permissions page, click the Add an OAuth Scope button under Scopes and select one of the following scopes from the drop-down menu as needed:
      • channels:join. Join public channels in a workspace.
      • channels:manage. Manage public channels that your bot has been added to and create new ones.
      • channels:read. View basic information about public channels in a workspace.
      • chat:write. Send messages as @<bot_username>.
      • chat:write.public. Send messages to channels that @<bot_username> isn't a member of.
      • commands. Add shortcuts and/or slash commands that people can use.
      • groups:read. View basic information about private channels that your bot has been added to.
      • im:read. View basic information about direct messages that your bot has been added to.
      • incoming-webhook. Post messages to specific channels in Slack.
      • mpim:read. View basic information about group direct messages that your bot has been added to.
      • team:read. View the name, email domain, and icon for workspaces your bot is connected to.
      • users.profile:read. View profile details about people in a workspace.
      • users:read. View people in a workspace.
  1. Click the Request to Install button under OAuth Tokens for Your Workspace.
  2. In the window that appears, enter a message for your Slack administrator, if needed, and click the Submit Request button.
Your Slack administrator must approve this request in order to move forward. Once they do, be sure to save the Bot OAuth token, as you will need it when setting up your configuration object in Skylar Automation later.
  1. In Skylar Automation, create an API key to use when adding Slash commands in Slack.
  2. Be sure to copy the API Key once it is generated, as you will need it to add Slash Commands for your app. After you close the modal in Skylar Automation, you will only be able to see the first five characters of the key on the API Keys page.
  3. Click Slash Commands from the Features menu on the left. The Slash Commands page appears.
  4. Click the Create New Command button.
  5. Enter /service in the Command field.
  6. Enter https://<PowerFlowserver>/api/v1/applications/query_sl1_service_and_device_details/run?PF-APIKEY=<PF token> in the Request URL field.
In the URL above, replace <PF token> with the API Key you created in PowerFlow.
  1. Enter a short description of what the command does in the Short Description field.
  2. Enter any hint you want users to see when trying to enter the command in the Usage Hint field.
  3. Click the Save button.
  4. Repeat this process to add the /device command.
  1. Click Interactivity & Shortcuts from the Features menu on the left. The Interactivity & Shortcuts page appears.
  2. Toggle on (green) Interactivity.
  3. Enter https://<PowerFlowserver>/api/v1/applications/sync_sl1_event_status_from_slack/run?PF-APIKEY=<PF token> in the Request URL field.
  4. Click the Save Changes button.
Install your app
  1. Click OAuth & Permissions from the Features menu on the left. The OAuth & Permissions page appears.
  2. Confirm that your app has been approved and installed under OAuth Tokens for Your Workspace.
The following topics cover how to set up your Skylar One instance to work with this SyncPack.
Creating a SOAP/XML Credential to Access Skylar OneSkylar Automation
After you have integrated your Slack and Skylar OneSkylar Automation systems, you must create a SOAP/XML credential so that the automation actions included in the "Slack Integration" PowerPack can access your Skylar OneSkylar Automation system.
The "Slack Integration" PowerPack includes a sample SOAP/XML credential named "Skylar Automation Slack" This credential lets you send event payload data from Skylar One to PowerFlow and then to Slack. Use this credential to integrate with the Slack SyncPack by aligning this credential to the "Slack: Add/Update" run book action.
To define a SOAP/XML credential using the "Skylar Automation Slack" credential:
  • Go to the Credentials page (Manage > Credentials).
  • Search for the "Skylar Automation Slack" credential and click its name. The Edit Credential page appears.
  • Name. Type a new name for the Slack credential.
  • Timeout (ms). Set to 5000.
  • Method. Select POST.
  • HTTP Version. Select HTTP/1.1.
  • URL. Type the host name for Skylar Automation.
  • HTTP Auth User. Type the username for your Skylar OneSkylar Automation user account.
  • HTTP Auth Password. Type the password for your Skylar OneSkylar Automation user account.
  • Click Save & Close to save the new SOAP/XML credential. Skylar One adds the credential to the Credentials page and assigns the new credential an ID number.
  • On the Credentials page, make a note of the number in the ID column for the new credential. You will need this when editing the input parameters of the automation actions included in theSlack IntegrationPowerPack.
Aligning a Slack Credential to the Slack Automation Actions
After you have created a Slack credential, you must align the credential to the run book action policies included in this PowerPack. The aligned credential will work with the automation policy that is installed by default in this PowerPack to provide a working configuration.
The "Slack Integration" PowerPack includes six standard automation policies that you will need to enable. These policies update the Skylar One events with the state of the associated event or alert, create a channel, or create channel notifications. When the event is first detected in Skylar One or Slack, the "triggered" state is sent. When the event is acknowledged in Skylar One or Slack, the "acknowledged" state is sent. When the event is cleared in Skylar One or Slack, the "cleared" state is sent. When a channel is created, details are added to the Skylar One event notes.
Automation Policy Name Aligned Events Automation Action
Slack: Create Channel
Major: Slack
Slack: Events - Acknowledge
All events
Slack: Acknowledge
Slack: Events - Add
Major: Slack
Slack: Add/Update
Slack: Event - Cleared
All events
Slack: Clear
Slack: Channel Notification - Acknowledge Slack: Channel Notification - Acknowledge
Slack: Channel Notification - Clear Slack: Channel Notification - Clear
To align the credential to the automation actions:
  1. Navigate to the Actions page (Registry > Run Book > Actions).
  2. Locate each of the Slack automation actions and click the wrench icon (). The Editing Action modal appears.
  3. In the Input Parameters field, change the values of the following parameter:
  • credential_id. Change the value to the credential ID that you noted earlier when creating a credential for your Skylar OneSkylar Automation system. This field is required.
Do not change the values of the other Input Parameters.
  2. Repeat steps 2-4 for the remaining Slack action policies.
The following topics cover how to set up your Skylar Automation instance to work with this SyncPack.
Creating and Aligning a Configuration Object in Skylar Automation
To use this SyncPack, you will need to use an existing configuration object in the Skylar Automation user interface or create a new configuration object. Next, you need to align that configuration object to the relevant applications.
For this SyncPack, you can make a copy of the "Sample Slack Config" configuration object, which is the sample configuration file that was installed with the Slack SyncPack.
The "Sample Slack Config" configuration object contains all of the required variables. Simply update the variables from that object to match your Skylar One and Slack settings.
To create a configuration object based on the "Sample Slack Config" configuration object:
  2. Click the Actions button () for the "Sample Slack Config" configuration object and select Edit. The Configuration pane appears.
  1. In the Configuration Data field, update the default variable definitions to match your Skylar Automation configuration:
  • sl1_host. The hostname or IP address of the Skylar One system the alerts will synchronize to.
  • token. Bot user OAuth token from Slack.
  • default_ack_user. The default user to acknowledge events and alerts. This should be a Skylar One user account, for example, /api/account/1.
  • slack_webhook_url. Incoming webhook URL configured in the Slack App. This can be found under the Webhook URLs for Your Workspace heading on the Incoming Webhooks page.
  • team_id. ID of the team to create the Slack channel in. This value is in the Slack webhook URL: https://hooks.slack.com/services/<team_id>/
  • users. Comma-separated Slack user IDs to invite to your created channel. The user Id should be formatted as "@<slack_username>".
  • region. The region value is a user-defined variable that identifies your Skylar One instance within Slack.
In Skylar Automation, you will need to align the "Slack" SyncPack applications with your new configuration object in Skylar Automation, and, if needed, update any other fields on the Configuration pane for the applications.
"Slack" SyncPackSkylar Automation applications:
  • Create Slack channel For Skylar One Event. This application creates a channel in Slack based on the event severity configured in Skylar One and will post the event to the created channel.
  • Notify Skylar One Event to new Slack Channel. This application creates a notification in a Slack channel from a Skylar One event.
  • Notify Skylar One Event to existing Slack Channel. This application sends a notification to Slack of a "Major" event in Skylar One
  • Query Skylar One Service and Device details. This application allows you to query Skylar One for service and device details from the Slack channel that ships with the SyncPack.
  • Sync Skylar One Event status from Slack. This application synchronizes an event update made in Slack with the event status in Skylar One.
  1. On the Applications page of the Skylar Automation user interface, search for Slack. Click on the name of one of the Skylar Automation applications listed above to open the application.
  2. Click Configure. The Configurations pane for that application appears.
  2. Repeat this process for the other Slack applications in Skylar Automation.
Using Slack to Trigger Commands and Respond to Event Messages
There are two direct ways to use the integration between Skylar One and Slack. In Slack, you can use specific commands called "slash commands" to trigger certain actions to occur. You can also respond to an event notification in Slack, to be updated in Skylar One by adding a note, acknowledging the event, or resolving it.
Triggering Slack Commands
You can use specific commands to request information from Skylar One to display directly in Slack. To use the commands in Slack, type a slash (/) followed by the command, with no space between them.There are two primary command types configured to work with the integration between Skylar One and Slack:
Command:/service
Give the name of the specific business service as the text argument of the command. Optionally, you can request supplemental information by adding "devices" or "events". Separate the supplemental information text from the resource name by a colon. For example:
/service <business_service_name>
To find the name of the business service you want to query, navigate to the Service Investigator page for that service in Skylar One and use the name that displays after /services/ in the URL. Alternatively, you can use the name of the business service as it displays in the Name field in Skylar One.
This command will return and display the Name, Health, Availability, and Risk of the queried business service. You can also click a link to navigate directly to the business service in Skylar One.
/service <business_service_name> : devices
This command will return and display a list of devices within the queried business service, along with the Name, IP, and State of the devices.
/service <business_service_name> : events
This command will return and display a list of events associated with the queried business service, along with the Severity, event Message, and Aligned Entity Name.
Command:/device
Give the name of the specific device as the text argument of the command. Optionally, you can request supplemental information by adding "interfaces" or "events". Separate the supplemental information text from the resource name by a colon. For example:
/device <device_name>
To find the name of the device you want to query, navigate to the Device Investigator page for that device in Skylar One and use the value that displays in the Name field in Skylar One.
This command will return and display the Name, State, Availability, Latency, IP, Message associated with the highest severity event on the device, and Latency of the queried device. You can also click a link to navigate directly to the Device Investigator in Skylar One.
/device <device_name> : interfaces
This command will return and display a list of the interfaces for the queried device, along with the Name, Utilization In, and Utilization Out.
/device <device_name> : events
This command will return and display a list of events associated with the queried device, along with a link to view the event in the Device Investigator in Skylar One.
Responding to Event Messages
When an event is posted in Slack, you can view details of the event, such as the Event ID, Event Severity, Affected Device, and more. You can respond to the event in Slack, to be updated in Skylar One by adding a note, acknowledging the event, or resolving it:
  • Add Note to Skylar One Event: Type the note you want to add to the event and press Enter. The note will be added to the event in Skylar One.
  • Acknowledge: Click this button to acknowledge the event in Skylar One.
  • Resolve: Click this button to resolve the event in Skylar One.
