Configuring Applications for the Webex SyncPack
This section describes how to set up the run book automations in Skylar One and how to configure the Skylar Automation applications in the "Webex" SyncPack.
The following workflows describe how to configure Skylar One and Skylar Automation to work with the "Webex" SyncPack.
Configuring Webex
  1. Create a bot in Webex
  2. Create a Webhook
Configuring Skylar One
  1. Create a SOAP/XML credential to access Skylar Automation
  2. Edit the Webex run book actions
  3. Enable the Webex run book automations
Configuring Skylar Automation
  2. Align the configuration object and configure the Webex Skylar Automation applications
Configuring Webex
The following topics cover how to set up Webex to work with the SyncPack.
Creating a Bot in Webex
Create a bot in Webex:
  1. Log in to developer.webex.com.
  2. Select your profile, and then select My Webex Apps.
  3. Select Create a New App, and then select Create a Bot.
  4. When you have created the bot, save the access token from the bot. This will be used for posting messages and creating rooms.
  5. Add the bot that you created to the appropriate team.
Creating a Webhook
Next, you will need to create an API Key in Skylar Automation and a webhook in Webex:
  1. In PowerFlow, go to the API Keys page.
  2. Select Create API Key and copy the key when it is generated.
  3. Create the following URL, inserting your PowerFlow IP address and the API key from step 2 where indicated:
  4. https://<Your PowerFlow IP Address>/api/v1/applications/sync_event_status_from_webex_to_sl1/run?PF-APIKEY=<API Key>
  5. Go to Webhooks - Create a Webhook | Webex for Developers.
  6. Use the Bot token in Authorization while creating the webhook using the API.
  7. Add the following parameter values:
  • targetUrl. Use the URL you created using your API key.
  • resource. attachmentActions
  • event. created
The following topics cover how to set up your Skylar One instance to work with the "Webex" SyncPack.
Creating a SOAP/XML Credential to Access Skylar Automation
You will need to create a SOAP/XML credential so that the automation actions included in the "Webex Automations" PowerPack can access your  Skylar Automation system. The "Webex Automations" PowerPack includes the "PowerFlow Webex Teams" credential, which you can use as a template for the SOAP/XML credential.
  2. Click the wrench icon () for the "PowerFlow WebexTeams" credential. The Credential Editor modal window appears:
  • HTTP Auth User. Type the username for your Skylar Automation system.
  • HTTP Auth Password. Type the password for your Skylar Automation system.
Editing the Webex Run Book Actions
The "Webex Automations" PowerPack includes run book actions that use the "Run Integration Service Application" action type to trigger the Skylar Automation applications that send and receive data to and from Webex. You can specify the credential ID in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
  2. Locate the action policy that you want to use, and then click its wrench icon (). The Editing Action page appears.
Enabling the Webex Run Book Automations
The "Webex Automations" PowerPack includes six standard automation policies that you will need to enable. These policies create Webex channels, acknowledge or clear Webex room notifications, and update Skylar One events created from Webex.
The following table shows the run book automation policy, its aligned events, and the run book action that runs in response to the events.
Webex: Create Channel
All Events
Webex: Create Room
Webex: Created Room Notification - Acknowledge
All Events
Webex: Created Room Notification - Clear
All Events
Webex: [Events] - Acknowledge
All Events
Webex: Acknowledge
Webex: [Events] - Add/Update
All Events
Webex: Add/Update
Webex: [Events] - Cleared
All Events
Webex: Clear
  2. Locate a Webex run book automation policy and click its wrench icon (). The Automation Policy Editor page appears.
  • Available Actions. If it is not already selected, select the "Run Integration Service Application: <name>" action that corresponds with the Webex automation policy you selected in step 2, and click the arrows to move it to Aligned Actions.
  2. Repeat steps 2-4 for the remaining Webex run book automation policies.
The following topics cover how to set up your Skylar Automation instance to work with the "Webex" SyncPack.
For this SyncPack, you can make a copy of the " Config" configuration object, which is the sample configuration file that was installed with the Webex SyncPack. Then you need to align that configuration object to the relevant applications.
The "Sample Webex Config" configuration object contains all of the required variables. Simply update the variables from that object to match your Skylar One and Webex settings.
To create a configuration object based on the "Sample Webex Config" configuration object:
  2. Click the Actions button () for the "Sample Webex Config" configuration object and select Edit. The Configuration pane appears.
  1. In the Configuration Data field, update the default variable definitions to match your Skylar Automation configuration:
  • sl1_host. The hostname or IP address of the Skylar One system the alerts will synchronize to.
  • token. Webex bot token.
  • default_ack_user. The default user to acknowledge events and alerts.
  • team_id. ID of the team to create the channel for.
  • users. Comma-separted list of Webex user emails to invite to the created channel.
  • room_id. ID of the room to post messages in.
With this SyncPack, any status changes made to a Skylar One event is sent to Webex to update the corresponding alert. Any status changes to the Webex alert are synced back to the corresponding Skylar One event.
To run this SyncPack, you must "align" the configuration object to run with the following Skylar Automation applications:
  • Create Room For Event"
  • "Created Room Event Notification"
  • "Major Event Notification"
  • "Sync Event Status From Webex To Skylar One"
  1. On the Applications page of the Skylar Automation user interface, open one of the Skylar Automation applications listed above and click Configure. The Configurations pane for that application appears.
    The values for proxy_host and the other parameters that appear in the Configuration pane with a padlock icon () are populated either by the configuration object you aligned with the application or by the run book action. Do not modify these values. If you encounter an error, make sure your run book action is configured properly.
  2. Click Save.
  3. Repeat this process for the other Skylar Automation applications.
To create a schedule:
When either multiple Skylar One instance or multiple Webex instances are involved with Skylar Automation, you should create an individual configuration object for each Skylar One or Webex instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single Skylar One or Webex instance. Creating copies of a Skylar Automation application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
