Version 1.0.0 of the "Jira Service Management" SyncPack provides a bidirectional integration between Skylar One events and Jira issues.
This SyncPack uses the "Jira Service Management Automation Policies" PowerPack.
Features Included in this Release
The following Skylar Automation applications are included in this SyncPack:
- Acknowledge SL1 Event. This application adds a comment to the associated Jira issue when an event is acknowledged in Skylar One.
Create Incident/Change Request in Jira from SL1 Event. This application creates an incident (issue) or change request in Jira when an event is triggered in Skylar One.
- Resolve SL1 Event from Jira. This application resolves an Skylar One event when an associated Jira issue is closed.
- Show Jira Change Log in SL1 Event Notes. This application collects a summary of Jira issue data and adds it to the event notes of an associated Skylar One event.
The following configuration object is included in the SyncPack:
- Jira ITSM Configuration. This configuration object can be used as a template after the SyncPack is installed on the Skylar Automation system. The configuration object includes the following:
- Details for connecting to the Skylar One, including the host, username, and password.
- Details for connecting to Jira, including the URL, username, password, and API token.
- Details for adding Skylar One events to Jira issues including project, event URL, severity, account, and request type ID. Other details include issue type, project key, priority, ticket descriptions, and impact.
- Details for severity mapping.
- Get Closed Issues and Clear the SL1 Events
- Create Jira Incident
- Read Event Id and Jira Key
- Get Jira Issue
- Get Jira Log
- Post Update To SL1
- Update Incident Details To SL1
- Update SL1 Note
To view the latest manuals for the Skylar Automation Platform, see the Skylar Automation page. To view the latest release notes for Skylar Automation, see Skylar Automation Release Notes.
System Requirements
This release of the SyncPack requires:
- SL1 Skylar Automation platform version 2.4.0 or later.
- Skylar One version 11.2.0 or later. For details on upgrading Skylar One, see the relevant SL1 Platform Release Notes.
- "Base Steps" SyncPack version 1.3.2 or later.
- "Jira Service Management Automation Policies" PowerPack version 100 or later.
- "SL1 Notifications Base" SyncPack version 1.0.1 or later.
- Administrator access to Jira.
- An IT Service Management Jira project to integrate with Skylar One.
The following table lists the port access required by the Skylar Automation platform and this SyncPack:
| Source IP | Skylar Automation Destination | Skylar Automation Source Port | Destination Port | Requirement |
| Skylar Automation | Skylar One API | Any | TCP 443 | Skylar One API Access |
| Skylar Automation | Jira API | Any | TCP 443 | Jira API Access |
| Skylar Automation | Skylar One Database | Any | TCP 7706 | Skylar One Database Access |
Installing the SyncPack
A SyncPack file has the .whl file extension type. You can download the SyncPack file from the ScienceLogic Support Center.
- Go to the ScienceLogic Support Center at https://support.sciencelogic.com/s/.
- Click the tab and select SyncPacks.
- In the Search field, type the name of this SyncPack and select it from the search results. The Release Version page appears.
- On the tab, click the down arrow next to the SyncPack version that you want to install, and select Show File Details. The Release File Details page appears.
- Click the button to download the SyncPack.
After you download a SyncPack, you can import it to the Skylar Automation (formerly PowerFlow) platform using the Skylar Automation user interface.
- On the SyncPacks page, click . The Import SyncPack page appears.
- Click and select the .whl file for the SyncPack you want to install. You can also drag and drop a .whl file to the Import SyncPack page.
- Click . Skylar Automation registers and uploads the SyncPack. The SyncPack is added to the SyncPacks page.
- On the SyncPacks page, click the button (
) for the SyncPack you want to install and select Activate & Install. The Activate & Install SyncPack modal appears.If you try to activate and install a SyncPack that is already activated and installed, you can choose to "force" installation across all the nodes in the Skylar Automation system.
If you do not see the SyncPack that you want to install, click the Filter icon (
) on the SyncPacks page and select Toggle Inactive SyncPacks to see a list of the imported SyncPacks.
- Click to confirm the activation and installation. When the SyncPack is activated, the SyncPacks page displays a green check mark icon for that SyncPack. If the activation or installation failed, then a red exclamation mark icon appears.
- For more information about the activation and installation process, click the check mark icon or the exclamation mark icon in the Activated column for that SyncPack. For a successful installation, the "Activate & Install SyncPack" Skylar Automation application appears, and you can view the Step Log for the steps. For a failed installation, the Error Logs window appears.
- If you have other versions of the same SyncPack on your Skylar Automation system, you can click the button (
