Users and User Roles
This chapter describes how you can use the Users page (Administration > Users) to add administrators to Skylar Compliance and configure administrator roles.
Skylar Compliance supports three levels of user access:
  • Admin. Super User who has full access (can create/modify/delete devices and users, initiate backups/restores and change the appliance configuration). Admins also have an encryption password that allows Skylar Compliance to transition from the locked state to the normal state.
  • Backup. Backup Operator who can perform device backups and restores, but cannot modify devices, users, or appliance settings.
  • View Only. Monitor Operator who can only view existing backups, access logs, and verify that the system is operating normally.
Listing Logged-in Users
You can view a list of currently logged in users in the Logged-in Users tab (Administration > Users > Logged-in Users). The number of Logged-in users is also displayed on the Dashboard (Info > Status).
Adding a New User
To add or modify administrators, navigate to the Users page (Administration > Users). Administrator passwords and encryption passwords, by default, must be at least 8 characters long. For more information, see Password Policies.
To add a new user:
  1. Navigate to the Users page (Administration > Users). The User Management page appears.
  2. Click Add User. The New User page appears:
    Image of the Restorepoint Add User page
  1. Complete the following fields on the Details tab:
  • Full Name. Type the full name of the user.
  • Email. Type the user email address.
  • Disabled. Select this checkbox to prevent the user from logging in.
  • Allowed Networks. If set, this field allows the user to connect to Skylar Compliance only from certain subnets. Enter an IP range in CIDR format in the IP Address/Mask box, and click Add.
  1. Complete the following fields on the Auth tab.
  • Username. Type the new username. Usernames may be up to 16 characters long.
  • Password. Enter the password for the new user. By default, passwords must be between 8 and 24 characters long. The field color will range from red to green to indicate the password strength, according to the policy set in the Password Policies page. For more information, see Password Policies.
  • Encryption Password. This field appears if an Admin-level administrator is selected. The encryption password must be between 8 and 24 characters long, and must be different from the administrator password. The field color will range from red to green to indicate the password strength.
  • Email Activation Link. This field allows you to set up a user without specifying a password. The user will receive an activation email to let them set their own password.
  • Expire Password. This field allows you to override the global password expiry rules for this user. See Timeouts for the global password expiry settings.
  • Use RADIUS. Select this checkbox if you want the user to authenticate against an external RADIUS server. See RADIUS Authentication on how to configure a RADIUS server.
  1. Complete the following fields in the Domains tab.
  • Role. Assign a role to one or more domains. Choose between No Role, View Only, Back Up, or Admin.
  • Domain. Assign a domain to each role. Choose from Global, Domain 1, Domain 2, Domain 3.
When a new administrator first logs in, they will be prompted to configure a password recovery question and answer. Skylar Compliance suggests that administrators assign an email and recovery question and answer in case you need to reset your password. For more information, see Password Reset.
Broadcasting to Users
You can use Skylar Compliance to send a notification message to a user or group of users. Select the checkbox next to the users you want to message and click Broadcast. This opens the Broadcast Message dialog, where you can enter the message. When finished, click the OK button to send the message.
A message type appears as a pop-up in the user’s session while logged into Skylar Compliance. If the user is not currently logged in, the message will appear when they log in to the appliance until the Persist time is reached. An Email message type will send the notification to the user’s email address registered on the appliance.
Editing an Existing User
To edit the details of an existing user:
  2. Click on the name of the user that you want to edit.
  3. Edit the user as needed and then click Save.
  4. Image of the Restorepoint Edit User page
  5. When editing an administrator's user details, there are two additional fields in the Auth tab:
  • Recovery Question/Answer. Type a Recovery Question / Answer for password recovery.
  • New Token. Generates and emails a new recovery token to the user. This allows the user to recover their encryption password, if forgotten. For more information, see Password Reset.
A new token is generated any time an administrator's recovery details are updated. Take note of the new token as this token will be used later if you forget your password.
Deleting a User
To delete one or more existing users:
  1. Select the checkbox of the user you want to remove. You can remove multiple users at a time.
  2. Click Delete.
Password Reset
Skylar Compliance provides a password reset mechanism based on two-factor authentication.
Password Recovery Configuration
During the initial configuration procedure, or when an administrator logs in for the first time, the following information must be set:
  • A password recovery question and related answer. For security reasons, only an administrator should know these.
  • The administrator’s email address.
    Image of the Restorepoint Recovery page
Skylar Compliance will then email a recovery token, which can be used by the administrator to reset their password and encryption password, if the administrator knows the recovery question and answer.
Recovery Procedure
When logging on with an incorrect password for the given account, the Forgotten password link displays:
Image of the Restorepoint Login page
To reset your password:
  1. Click the Forgotten password? link and the Reset Password pane displays.
  • Username. Type your Skylar Compliance username.
  • Recovery Token. Enter your recovery token. This field only displays and is only required for administrators.
  • Recovery Question. Administrators should have entered a recovery question when you set up your Skylar Compliance account. Your recovery question displays then type your recovery question answer. This field only displays and is only required for administrators.
  • New Password. Type a new password.
  • Confirm Password. Type the same password you entered above.
  • New Encryption Password. Type a new encryption password. This field is only required for administrators.
  • Confirm New Encryption Password. Type the same password you entered above. This field is only required for administrators.
  1. Click Reset Password and if your reset is successful, a notification appears.
Users with specific permissions can change another user's password.
Custom User Roles
In addition to the standard built-in administrator roles ( Admin, Backup, and View Only), which cannot be edited, it is possible to define custom roles that define which product elements are accessible to the user. This feature is only available with an Enterprise license.
In order to define a custom role:
  1. Navigate to the User Roles page (Administration > User Roles).
  2. Click Add Role, and enter a name for the role.
  3. Select the allowed actions for this role on the Permissions tab. Scroll down for a the full range of choices.
  4. Image of the Restorepoint Add Role page
After you add a role, it is immediately available in the list on the User Roles page. Note that any changes to custom roles take effect immediately upon save.
For example, you can create a user role called Compliance Officer that can only create and modify compliance rules, and apply those to devices.
In addition to the global View (read-only) and Modify (read-write) permissions, you can allow the following actions:
Reports
Backup
Allows backup reports
Config
Allows configuration reports
Assets
Allows assets reports
Compliance
Allows compliance reports
Admin
Allows administration reports
Monitor
Allows monitoring reports
Dashboard
Allows dashboard reports
Modify
Allows users to modify and schedule reports
Logs
View Logs
Allows users to view the system log
View Syslogs
Allows users to view the device syslogs
Devices
View
Allows users to view the device list and device details (excluding authentication details)
View Auth
Allows users to view device authentication details
Backup
Allows device backup operations
Command
Allows device remote control
Configurations
List
Allows users to view the device configuration list
Export
Allows users to export device configurations
Restore
Allows users to restore a configuration to a device
Templates
List
Allows users to view the template list
Push
Allows users to push templates to devices
Firmware
Push
Allows users to push firmware images to devices
Assets
List
Allows users to view custom asset fields
Compliance Rules
Apply
Allows users to apply compliance rules to devices
System
Archive
Allows system archive operations
Users
View
Allows user to view the user list and user details (excluding authentication details)
View Auth
Allows users to view user authentication details
