Discovering Devices
This section describes how to use discovery in Skylar One to find devices on your network. You can use the Add Devices button on the Devices () page or the Discovery Sessions page (Devices > Discovery Sessions) to start a discovery process, or you can run a "Classic Discovery" from the Discovery Control Panel page (System > Manage > Classic Discovery or System > Manage > Discovery in the classic user interface).
Prerequisites for Discovering Devices
To discover all of the devices on your network:
  1. Make a note of the range of IP addresses used on your network. If your device does not have an IP address, make a note of the name of the root device. If you need help, ask your network administrator.
  2. An Organization must exist in Skylar One for the new devices. If you need to create an Organization, go to the Organizations page (Registry > Accounts > Organizations).
  3. A Collector Group must exist in Skylar One that can reach the target device using a valid network path for the needed protocol. For example, UDP 161 for SNMP and general ICMP traffic for Ping. If you are not sure of the Collector Group to use, consult a Skylar One Architecture diagram or ask your Skylar One System Administrator. You can access collector information on the Collector Group Management page (System > Settings > Collector Groups).
  4. You must create or use an existing credential. You can access credential information on the Credentials page (Manage > Credentials). Because credential problems are the most common cause for discovery failure, you can test any credential that you create on the Credential Test Management page (System > Customize > Credential Tests).
  5. If you want to use a device template with a discovery session, you must use an existing template in Skylar One. You can access device templates on the Configuration Templates page (Devices > Templates).
  6. The Grant All user needs to be used to access new discovery workflow, as the SYS_SETTINGS_LICENSES_PAGE and SYS_SETTINGS_CUGS_PAGE access keys are needed to get collector or collector group information. For more information, see the Access Keys page (System > Manage > Access Keys).
If you want to discover one of the third-party products that are available as an option when using guided discovery, you must have the corresponding PowerPack installed on your Skylar One system. For example, if you want to discover an Amazon Web Services account, you must have the Amazon Web Services PowerPack installed.
Adding Devices Using Guided Discovery
On the Devices page () or the Discovery Sessions page (Devices > Discovery Sessions), you can add or "discover" new devices for monitoring in Skylar One. You add devices by creating a discovery session, which searches for devices on the network you specify.
The guided discovery process lets you select a discovery type specific to the type of devices you want to monitor, in addition to traditional SNMP discovery. The guided discovery wizard provides a filtered list of relevant credentials, the ability to create new credentials, and a reduced set of application-specific fields to help you efficiently discover the devices you need.
The following procedure uses Amazon Web Services as an example of the discovery type. Some steps and fields will vary depending on the discovery type.
To run a guided discovery:
  2. Select the type of devices you want to discover. You can choose one of the following device types:
  • Alibaba Cloud
  • AWS
  • AWS EC2
  • AWS IAM
  • AWS Assume Role
  • Azure
  • Citrix
  • Google Cloud
  • IBM
  • Ping
  • SNMP
  • VMware
  • Windows
  • Windows WMI
  • Windows PowerShell
  • Windows Agent
Additional information about the requirements for device discovery appears in the General Information pane to the right.
If you want to discover one of the third-party products that are available as an option when using guided discovery, you must have the corresponding PowerPack installed on your Skylar One system. For example, if you want to discover an Amazon Web Services account, you must have the "Amazon Web Services" PowerPack installed. Any device types for which you do not have the corresponding PowerPack installed will be unavailable for selection for guided discovery.
When executing AWS guided workflow discoveries, executing the same workflow or workflows with similar settings can result in asset duplication. For IAM guided workflows, this will result in completely duplicated account device component trees. For other AWS workflows, this might result in duplicated virtual devices that represent the AWS organization.
If you want to do a more general discovery, you can select one of the options in the Other ways to add devices pane, such as Unguided Network Discovery. For more information, see Adding Devices Using Unguided Discovery.
  1. Click Select. The Credential Selection page appears, which is the first step in the guided discovery session.
The contents of this page might vary depending on the discovery type you selected at the start of the Guided Discovery.
  1. If the credential you want to use for discovery is already listed on the Credential Selection page and does not need to be edited, proceed to step 5. Otherwise, you can optionally do one of the following:
  • If the credential you need is not in the list, click the Create New button to open the Create Credential window, where you can specify the name and organization for the credential, the third-party username and password, and other data such as Cloud Type and Proxy information. You can also test the credential before you save using the Credential Tester panel. Click Save & Close to save the credential and return to the Credential Selection page of the guided discovery session. For more information on creating new credentials or testing credentials, see the section on Defining Credentials or Using the Credential Tester Panel.
  • To edit a credential on the Credential Selection page, click the name of the credential you would like to edit from the Name column and edit that credential as needed. You can also test the credential before you save using the Credential Tester panel. Click the Save & Close button on the Edit Credential window to save your updates.
During the guided discovery process, you cannot click Next until the required fields are filled on the page.
  1. On the Credential Selection page of the guided discovery process, select a credential to allow Skylar One to access the device that will act as the root device for the system being discovered, and then click Next. The Discovery Session Name page appears, which is the second step in the guided discovery session.
  1. Complete the following fields, as applicable:
  • Discovery Session Name. Type a name for the discovery session.
  • Root Device Name.  Type the name of the root device for the application you want to monitor.
  • Scope of Discovery. If you are discovering Google Cloud devices, select whether you are discovering them at the Organization Level or the Project Level. For more information, see the section on Monitoring Google Cloud.
  • Select the organization to add discovered devices to. Select the name of the organization to which you want to add the discovered device.
  • Collector Group Name. Select an existing collector group to communicate with the discovered device. This field is required.
When assigning devices to a collector group, Skylar One's multi-tenancy rules will validate that the collector group you select belongs to the organization you selected in the previous field. If you attempt to run a discovery session where the devices, collector group, and credentials do not all belong to the same organization, you will receive an error message and will not be able to save or execute the discovery session.
  • IP. Type the IP addresses for Skylar One to scan during discovery.
Some applications, such as VMware, require that you enter an IP address for the root device as well.
  1. Click Next. Skylar One creates a root device with the appropriate Device Class assigned to it and aligns the relevant Dynamic Applications. The Device Discovery Completed page appears, which is the third and final step of the guided discovery session. As Skylar One discovers your devices, system messages relating to the discovery appear on the page under the heading "Discovery Logs".
If Skylar One cannot determine the appropriate Device Class, it will assign the device to the Generic SNMP Device Class.
  1. When discovery has finished, click Close.
Instead of running a Discovery for a specific discovery type, you can run an "unguided" discovery to find a range of devices using core credentials such as SNMP, Database, SOAP/XML, Basic/Snippet, SSH/Key, or PowerShell credentials.
To run an unguided discovery:
  3. Click Select. The three-step discovery wizard appears, starting with the Basic Information page.
  1. Click Next. The Credential Selection page of the wizard appears.
  2. On the Credential Selection page, you can optionally do one of the following:
  • If the credential you need is not in the list, click the Create New button and select the credential type you want to create to open the Create Credential window, where you can specify the name and organization for the credential, the third-party username and password, and other data such as Cloud Type and Proxy information. You can also test the credential before you save using the Credential Tester panel. Click Save & Close to save the credential and return to the Credential Selection page of the guided discovery session. For more information on creating new credentials or testing credentials, see the section on Defining Credentials or Using the Credential Tester Panel.
  1. On the Credential Selection page of the Add Devices wizard, select one or more credentials to allow Skylar One to access a device's SNMP data and click Next. The Discovery Session Details page of the Add Devices wizard appears.
  • List of IPs/Hostnames. Provide a list of IP addresses, hostnames, or fully-qualified domain names for Skylar One to scan during discovery. This field is required. In this field, you can enter a combination of one or more of the following:
  • Which collector will discover these devices?. Select an existing collector group to monitor the discovered devices. Required.
  • System Default (recommended). Use the value defined in the Behavior Settings page (System > Settings > Behavior) in the classic user interface of Skylar One.
  • 1. Model Device Only. Discovery will discover if the device is up and running and if so, collect the make and model of the device. Skylar One will then generate a device ID for the device so it can be managed by Skylar One.
  • System Default (recommended). Use the value defined in the Behavior Settings page (System > Settings > Behavior) in the classic user interface for Skylar One.
  • Port Scan All IPs. For the initial discovery session only, specifies whether Skylar One should scan all IP addresses on a device for open ports. The choices are:
  • Enabled. Skylar One will scan all discovered IP addresses for open ports.
  • Disabled. Skylar One will scan only the primary IP address (the one used to communicate with Skylar One) for open ports.
  • Port Scan Timeout. For the initial discovery session only, specifies the length of time, in milliseconds, after which Skylar One should stop trying to scan an IP address for open ports and begin scanning the next IP address (if applicable). Choices are:
  • Interface Inventory Timeout (ms). Specifies the maximum amount of time that the discovery processes will spend polling a device for the list of interfaces. After the specified time, Skylar One will stop polling the device, will not model the device, and will continue with discovery. The default value is 600,000 ms (10 minutes).
  • During the execution of this discovery session, Skylar One uses the value in this field first. If you delete the default values and do not specify another value in this field, Skylar One uses the value in the Global Threshold Settings page (System > Settings > Thresholds).
  • If you specify a value in this field and do not apply a device template to this discovery session, the Interface Inventory Timeout setting in the Device Thresholds page (Devices > Classic Devices > wrench icon > Thresholds, or Registry > Devices > Device Manager > wrench icon > Thresholds in the classic user interface) is set to this value for each discovered device. If there is no device template applied to the discovery session and no value is supplied in this field, Skylar One uses the value in the Global Threshold Settings page (System > Settings > Thresholds).
  • Maximum Allowed Interfaces. Specifies the maximum number of interfaces per devices. If a device exceeds this number of interfaces, Skylar One will stop scanning the device, will not model the device, and will continue with discovery. The default value is 10,000.
  • During the execution of this discovery session, Skylar One uses the value in this field first. If you delete the default values and do not specify another value in this field, Skylar One uses the value in the Global Threshold Settings page.
  • If you specify a value in this field and do not apply a device template to this discovery session, the Maximum Allowed Interfaces setting in the Device Thresholds page is set to this value for each discovered device. If there is no device template applied to the discovery session and no value is supplied in this field, Skylar One uses the value in the Global Threshold Settings page.
  • Selected. Skylar One will not attempt to discover interfaces for each device in the discovery session. For each discovered device, the Bypass Interface Inventory checkbox on the Device Investigator Settings tab will be selected.
  • Not Selected. Skylar One will attempt to discover network interfaces, using the Interface Inventory Timeout value and Maximum Allowed Interfaces value.
  • Discover non-SNMP. Specifies whether or not Skylar One should discover devices that don't respond to SNMP requests.
  • Selected. Skylar One will discover devices that don't respond to the SNMP credentials selected in the SNMP Credentials field. These devices will be discovered as "pingable" devices.
  • Not Selected. Skylar One will not discover devices that don't respond to the SNMP credentials selected in the SNMP Credentials fields.
You must either select a credential for the discovery session or select the Discover Non-SNMP option. Skylar One will prevent you from proceeding with discovery if you have not met those conditions.
  • Model Devices. Determines whether or not the devices that are discovered with this discovery session can be managed through Skylar One. Choices are:
  • Selected. When a device is modeled, Skylar One creates a device ID for the device; you can then access the device through the Device Manager page and manage the device in Skylar One.
  • Not Selected. If a device is not modeled, you cannot access the device through the Device Manager page, and you cannot manage the device in Skylar One. However, each discovered device will still appear in the Discovery Session logs. For each discovered device, the discovery logs will display the IP address and device class for the device. This option is useful when performing an initial discovery of your network, to determine which devices you want to monitor and manage with Skylar One. For the amount of time specified in the Device Model Cache TTL (h) field, a user can manually model the device from the Discovery Session window.
  • Selected. Skylar One will perform a DNS lookup for the device during discovery and each time Skylar One retrieves information from the device.
  • Not Selected. Skylar One will perform normal discovery.
  • Device Model Cache TTL (h). Amount of time, in hours, that Skylar One stores information about devices that are discovered but not modeled, either because the Model Devices option is not enabled or because Skylar One cannot determine whether a duplicate device already exists. The cached data can be used to manually model the device from the Discovery Session window.
  • Log All. Specifies whether or not the discovery session should use verbose logging. When you select verbose logging, Skylar One logs details about each IP address or hostname specified in the IP Address/Hostname Discovery List field, even if the results are "No device found at this address."
  • Select Device Template. As Skylar One discovers a device in the IP discovery list, that device is configured with the selected device template. You can select from a list of all device templates in Skylar One. For more information on device templates, see the Device Groups and Device Templates section.
Working with Discovery Sessions
The Discovery Sessions page (Devices > Discovery Sessions) displays a list of all the existing discovery sessions, which are previous attempts to add devices using discovery.
On this page you can click the Actions button () for a session and select one of the following actions:
  • Edit. Run the Add Device wizard again so you can make changes to the selected discovery session.
  • Delete. Delete the selected discovery session. You do not get a confirmation window after you click Delete; the session is immediately deleted.
  • Start. Run the selected discovery session again. The Discovery Logs page appears when discovery completes.
  • Show Logs. The Discovery Logs page for the selected discovery session displays data about the most recent run of a discovery session.
You can adjust the size of the rows and the size of the row text on this inventory page. For more information, see the section on Adjusting the Row Density in the Introduction to Skylar One manual.
From the Discovery Sessions page, you can also add devices using guided or unguided discovery by clicking the Add Devices button. For instructions on using guided discovery, see the section on Adding Devices Using Guided Discovery. For instructions on using unguided discovery, see the section on Adding Devices Using Unguided Discovery.
Managing Classic Discovery Sessions
The following sections describe how to view, create, and manage classic discovery sessions in Skylar One.
Viewing Information about a Classic Discovery Session
The Session Register pane in the Discovery Control Panel (System > Manage > Classic Discovery) page displays information about all discovery sessions defined in Skylar One.
To sort the list of discovery sessions, click on a column heading. The list will be sorted by the column value, in ascending order. To sort by descending order, click the column heading again. The Last Edit column sorts by descending order on the first click; to sort by ascending order, click the column heading again.
For each session, the Session Register displays:
  • Session Name. Name of the discovery session. This field is optional.
  • IP/Hostname List. The range of IP addresses and/or hostnames for Skylar One to scan during discovery. This field can contain a combination of one or more of the following:
  • One or more single IPv4 addresses separated by commas. Each IP address must be in standard IP notation and cannot exceed 15 characters. For example, "10.20.30.1, 10.20.30.2, 10.20.30.3".
  • One or more fully-qualified domain names or hostnames.
NOTE: The following types of notation are not supported: IPv4 netmask with comma notation (192.168.168.0,24); a list of single IPv6 addresses, separated by comma.
  • Collector. Data Collector used for the discovery session.
  • Organization. The organization to which devices discovered during the discovery session will be assigned.
  • Pings. This field specifies whether or not Skylar One should discover devices that don't respond to the selected SNMP credentials. The possible values are:
  • Yes. Skylar One will discover devices that don't respond to the SNMP credentials selected in the SNMP Credentials field for the discovery session. These devices will be discovered as "pingable" devices.
  • No. Skylar One will not discover devices that don't respond to the SNMP credentials selected in the SNMP Credentials field for this discovery session.
  • Rediscovery. Specifies whether or not Skylar One is scheduled to run this discovery session, and if so, the frequency and time specified in the schedule.
  • User Edit. Name of user who created or last edited the discovery session.
  • Last Edit. Date and time discovery session was created or last edited.
To filter the list of discovery sessions in the Session Register, use the search fields at the top of each column. The search fields are find-as-you-type filters; as you type, the page is filtered to match the text in the search field, including partial matches. Text matches are not case-sensitive. Additionally, you can use the following special characters in each filter:
Running a Classic Discovery Session
  • IP Address/Hostname Discovery List. Provide a list of IP addresses or fully-qualified domain names for Skylar One to scan during discovery. In this field, you can enter a combination of one or more of the following:
If you enter both the hostname and IP address of the same devices, Skylar One will discover two duplicate devices.
Skylar One will display an error if your discovery session exceeds the maximum size for optimum performance. Skylar One will display a warning message if your discovery session includes 100 or more IP addresses. The warning message will tell you that discovery with more than 100 IP addresses might "take a long time to discover".
  • SNMP Credentials. A community string that allows Skylar One to access a device's SNMP data. SNMP credentials are defined in the Credential Management page (System > Manage > Credentials). If you want to retrieve SNMP data from one or more devices, you must select one or more working SNMP credentials in this field. You can select multiple credentials from this field. Skylar One will try each selected credential when discovering devices and retrieving device data.
  • Other Credentials. A username and password pair (among other fields) that allows Skylar One to access a device's database data, SOAP data, XML data, WMI data, WBEM data, or data that is monitored with a Snippet Dynamic Application. These credentials are defined in the Credential Management page (System > Manage > Credentials). You can select multiple credentials from this field. Skylar One will try each selected credential when searching for Dynamic Applications to align with each discovered device.
  • 0. Model Device Only. Discovery will discover if the device is up and running and if so, collect the make and model of the device. Skylar One will then generate a device ID for the device so it can be managed by Skylar One.
  • 0. Disabled. Skylar One will scan only the primary IP address (the one used to communicate with Skylar One) for open ports.
  • 1. Enabled. Skylar One will scan all discovered IP addresses for open ports.
  • Detection Method & Port. During discovery, Skylar One will scan the list of ports selected in this field to determine if the range of devices is up and running and which ports are open on each discovered device. If a device does not respond to SNMP or ICMP, Skylar One uses an open port to collect availability data for that device. If you are not sure which ports are used by the range of devices, select the entry Default Method. Skylar One will check ICMP (ping), FTP, SSH, Telnet, SMTP, and HTTP ports.
  • Selected. Skylar One will not attempt to discover interfaces for each device in the discovery session. For each discovered device, the Bypass Interface Inventory checkbox in the Device Properties page will be selected.
  • Discover Non-SNMP Devices. Specifies whether or not Skylar One should discover devices that don't respond to SNMP requests.
  • Enabled. When a device is modeled, Skylar One creates a device ID for the device; you can then access the device through the Device Manager page and manage the device in Skylar One.
  • Disabled. If a device is not modeled, you cannot access the device through the Device Manager page, and you cannot manage the device in Skylar One. However, each discovered device will still appear in the Discovery Session logs. For each discovered device, the discovery logs will display the IP address and device class for the device. This option is useful when performing an initial discovery of your network, to determine which devices you want to monitor and manage with Skylar One. For the amount of time specified in the Device Model Cache TTL (h) field, a user can manually model the device from the Discovery Session window.
  • For Skylar One appliances, only the name of the appliance will appear in this field.
  • Organization. This field contains a list of all organizations defined in Skylar One. Devices discovered during the discovery session will be assigned to the selected organization.
  • Add Devices to Device Group(s). When Skylar One discovers a device in the IP discovery list, that device is added to each selected device group. You can select one or more device groups from a list of device groups in Skylar One that have "Discovery" selected in the Visibility field. For more information on device groups, see the Device Groups and Device Templates section.
  • Apply Device Template. As Skylar One discovers a device in the IP discovery list, that device is configured with the selected device template. You can select from a list of all device templates in Skylar One. For more information on device templates, see the Device Groups and Device Templates section.
Viewing Information about Classic Discovery
To view information about a discovery session that has already run:
  2. In the Discovery Control Panel page, in the Session Register, find the discovery session you are interested in. Click its magnifying glass icon ().
  3. The Discovery Session modal page appears. This page provides details on the discovery session.
  4. The Discovery Session page includes an entry for each action performed during the discovery session. Each entry in the Discovery Session page contains:
  • Date Time. Date and time the action was executed.
  • Discovery Log Message. When applicable, starts with the IP address of the discovered device. Also includes a description of the action that was executed by the discovery session.
NOTE: If you did not select Auto-Update in the Device Properties page for one or more devices, when the discovery process tries to discover one of those devices, the log will display the message "Auto-Update is disabled and prevents discovery from updating any device properties."
  • Class Type. The device class for each discovered device. Skylar One will determine the device class for each device, even if a device will not be modeled by Skylar One.
  • Checkbox. If a device was discovered but not modeled, you can select this checkbox and click the Model button to model the device. If this device is a potential duplicate, the Discovery Sessionpage displays the message "Not modeled, potential duplicate device". If you are certain that the device is not a duplicate, you can choose to model the device.
  1. To save the log to the local computer, go to the Discovery Control Panel page (System > Manage > Classic Discovery), and click the Export icon () for the session.
Creating a New Classic Discovery Session with the "Save As" Button
You can edit an existing discovery session, make one or more changes, and then save the edited discovery session as a new session. The previous session still exists, unedited. To do this:
  1. In the Discovery Control Panelpage (System > Manage > Classic Discovery), in theSession Registry pane, find the discovery session you want to edit. Click its wrench icon (). The Discovery Session Editor page appears.
  2. On the Discovery Session Editor page, you can edit one or more values listed in the Running a Discovery Session section.
  3. Click the Save As button to save the discovery session as a new session. The new session appears in the Discovery Control Panelpage (System > Manage > Classic Discovery).
Editing a Classic Discovery Session
You can edit the parameters of a discovery session in the Discovery Control Panel page. To do this:
  2. Find the discovery session you want to edit. Click its wrench icon ().
  3. The Discovery Session Editor page appears with the values from the previous discovery session. You can edit any of the fields described in the section Running a Discovery Session.
  4. Click the Save button to save your changes. To save the edited discovery session as a new session (the previous session will still exist), click the Save As button. Close the Discovery Session Editor page.
  5. To manually run discovery using the edited session, find the edited session in the Session Register pane and click its Queue this Session icon (). If no other discovery sessions are currently running, the session will be executed immediately. If another discovery session is currently running, your discovery session will be queued for execution.
Scheduling a Classic Discovery Session
You can schedule one-time and recurring re-execution of a selected discovery session. You can use the Schedule Manager page (System > Manage > Classic Discovery > calendar icon) to:
  • Specify regularly recurring discovery of a specific IP range. This is helpful when you want to monitor an IP range where new devices are frequently added.
  • Specify one-time re-discovery of a specific IP range. This is helpful when you are aware of hardware or software changes within that IP range that you want Skylar One to monitor.
NOTE: Scheduled re-execution of a discovery session is slightly different tha Skylar One's automatic, nightly rediscovery. Nightly rediscovery is applied only to already discovered devices and uses the policies and configuration applied to each device. Re-execution of a discovery session can discover new devices within an IP range and uses only the settings specified in the Discovery Control Panel page.
Viewing the Schedule Manager
The Schedule Manager page (System > Manage > Classic Discovery > calendar icon) displays the following information about each scheduled or recurring discovery session:
  • Event ID. Displays a unique, numeric ID for the scheduled process. Skylar One automatically creates this ID for each scheduled process.
  • sch id. Displays a unique, numeric ID for the schedule. Skylar One automatically creates this ID for each schedule.
  • Context. Displays the area of Skylar One upon which the schedule works.
To edit a scheduled or recurring discovery session, click its wrench icon () and update the discovery session as needed on the Schedule Editor modal page. (For more information, see the section Defining a Scheduled or Recurring Discovery Session.)
You can schedule a discovery session in Skylar One from the Schedule Manager page. Skylar One will automatically run the discovery session at the scheduled time.
To define a scheduled or recurring discovery session:
  1. Go to the Schedule Manager page (System > Manage > Classic Discovery > calendar icon).
  2. Click Create. The Schedule Editor modal page appears.
  3. On the Schedule Editor modal page, make entries in the following fields:
Basic Settings
Time Settings
If you want Skylar One to automatically adjust for daylight savings time (if applicable), then you must select a named region (such as America/New York) in the Time Zone field. If you select a specific time zone (such as EST) or a specific time offset (such as GMT-5), then Skylar One will not automatically adjust for daylight savings time.
  • If you specify "6 Hours", then the scheduled process recurs every six hours from the time listed in the Start Date field.
  • If you specify "10 Days", then the scheduled process recurs every 10 days from the date listed in the Start Date field.
  • If you specify "2 Weeks", then the scheduled process recurs every two weeks, on the same day of the week as the Start Date.
  • If you specify "3 Months" the ticket recurs every three months, on the same day of the month as the Start Date.
  • Specified Date. The scheduled process recurs until a specific date and time. If you select Specified Date, you must enter a date and time in the Last Recurrence field.
Enabling or Disabling One or More Scheduled Discovery Sessions
You can enable or disable one or more scheduled or recurring discovery sessions from the Schedule Manager page (System > Manage > Classic Discovery > calendar icon). To do this:
  3. Click the Go button.
Deleting One or More Scheduled Discovery Sessions
You can delete one or more scheduled or recurring discovery sessions from the Schedule Manager page (System > Manage > Discovery > calendar icon). To do this:
Manually Re-Running Classic Discovery for a Dynamic Application
From the Dynamic Applications Manager page, you can manually run the Dynamic Application alignment portion of discovery for all existing devices in the system. That is, you can ask Skylar One to check each Dynamic Application and each existing device and align each device with each appropriate Dynamic Application.
For each Dynamic Application you select for re-discovery, Skylar One tries to connect to each existing device using the credentials already aligned with each device. If Skylar One is able to connect to a device with one of the credentials and can then retrieve the discovery object associated with the Dynamic Application, Skylar One will align the Dynamic Application with the device.
To manually run discovery for a single Dynamic Application:
  2. In the Dynamic Applications Manager page, find the Dynamic Application you want to use for network-wide discovery. Click its lightning bolt icon ().
  3. If no other discovery tasks are currently running, Skylar One will immediately perform discovery of the entire network, using the selected Dynamic Application.
  4. If other discovery tasks are currently running, Skylar One will add the request to the discovery queue.
To manually run discovery for multiple Dynamic Applications:
  2. In the Dynamic Applications Manager page, find the Dynamic Applications you want to use for network-wide discovery. Select the checkbox for each Dynamic Application.
  3. In the Select Actions menu (in the lower right of the page), select DISCOVER Applications.
  4. Click the Go button.
  5. If no other discovery tasks are currently running, Skylar One will immediately perform discovery of the entire network, using the selected Dynamic Application.
  6. If other discovery tasks are currently running, Skylar One will add the request to the discovery queue.
Manually Re-Running Classic Discovery for a Device
You can manually re-discover a device, using the settings and configuration in the Device Properties page for the device.
Remember that the credentials and settings defined in the Device Properties page override:
  • Settings in the Behavior Settings page (System > Settings > Behavior).
  • Credentials and settings in the Discovery Control Panel page (System > Manage > Classic Discovery) from the initial discovery of the device.
Skylar One will update the device with the data from the discovery session. The discovery session does not change, overwrite, or affect the existing, historical data associated with the device.
To re-discover a device:
  2. In the Device Manager page, find the device you want to re-discover. Click its wrench icon ().
  3. In the Device Properties page, click the Rediscover icon ().
  4. If no other discovery tasks are currently running, Skylar One will immediately perform discovery of the selected device.
  5. If other discovery tasks are currently running, Skylar One will add the request to the discovery queue.
