Device Classes and Device Categories
This section describes how to manage device classes and device categories in Skylar One.
Device Classes
Device classes determine:
  • How devices are represented in the user interface
  • Whether the device is a physical device or a virtual device
  • How managed devices are discovered with the discovery tool
Administrators can define new or legacy device classes and customize properties of existing device classes on the Device Classes page (Devices > Device Classes), or on the Device Class Editor page (System > Customize > Device Classes) in the classic Skylar One user interface.
Most TCP/IP-compliant devices have an internally defined class ID, called the System Object ID and abbreviated as SysObjectID. This SysObjectID is an SNMP object identifier (OID) defined by the manufacturer. Each manufacturer specifies a SysObjectID for each different hardware model. In Skylar One, each SNMP device class is associated with a SysObjectID. During initial discovery, Skylar One searches each device for the SysObjectID and assigns each device to the appropriate device class.
Skylar One also includes device classes for devices that do not support SNMP. These device classes are associated with values returned by nmap. Skylar One runs nmap against each device during discovery.
The following sections describe the types of device classes used in Skylar One.
Generic | SNMP Device Class
Skylar One includes a default device class for devices that include a SysObjectID but for which Skylar One does not have an aligned device class. This device class is Generic | SNMP.
For each device with a device class of Generic | SNMP, you can use Skylar One to view the SysObjectID for the device and then define a new device class using that SysObjectID.
Non-SNMP Device Classes
Skylar One also includes device classes for devices that do not support SNMP. Devices that do not support SNMP are sometimes called "pingable". Devices that have a device category of "pingable" are devices that meet one of the following criteria:
  • The device does not support SNMP.
  • SNMP has been disabled on the device.
  • An incorrect credential was provided during discovery, and you selected the "Discover Non-SNMP" checkbox for the discovery session.
Skylar One can use nmap to match a "pingable" device to an appropriate "pingable" device class.
Component Device Classes
Skylar One includes device classes for component devices. Skylar One discovers management systems and the component devices they manage. Skylar One uses Dynamic Applications to retrieve data from a management system and discover each component device managed by that management system. Device classes for components are aligned with the Dynamic Applications that discover component devices.
Agent-Only Device Classes
Skylar One includes device classes for devices that are monitored by the Skylar One agent and are not monitored via SNMP.
During initial discovery, the agent returns operating system type and version information to Skylar One.
Based on this information, Skylar One assigns the corresponding device classes to a device monitored only by an agent.
If a device is monitored by an agent and via SNMP, the device class assigned by SNMP discovery takes precedence.
Legacy ICMP Device Classes
Skylar One includes legacy SNMP Enabled device classes for "pingable" devices (that is, for devices that do not support SNMP). Skylar One includes the following legacy, SNMP Enabled device classes for "pingable" devices:
  • Cisco Systems | ICMP
  • FreeBSD | ICMP
  • Linux | ICMP
  • Microsoft | ICMP
  • Novell | ICMP
  • Ping | ICMP
  • Sun Microsystems | ICMP
  • Tektronix, Inc. | ICMP
Best practice is to define "pingable" devices as those that do not support SNMP. For "pingable" devices that do not support SNMP, ScienceLogic recommends you use the new "deep discovery" feature and then create "pingable" device classes.
Viewing the List of Device Classes
On the Device Classes page (Devices > Device Classes), you can view a list of existing device classes in Skylar One.
Image of the the Device Class settings page
If you are looking for a very specific set of device classes, click the gear icon () to the right of the Search field and select Advanced. In this mode you can create an advanced search using "AND" or "OR" for multiple search criteria. For more information, see Performing an Advanced Search.
For each device class, the Device Classes page displays the following information:
  • Device Class. The name of the device class.
  • Type. The device type. Can be "physical", "virtual", or "component".
  • Device Category. The device category. A device category is a way to categorize devices by primary function. Skylar One uses device categories to group related devices in reports and views. The list of device categories is defined on the Device Category Editor page (System > Customize > Device Categories).
  • Model. The device model.
  • Vendor. The device manufacturer.
You can rearrange the columns in the list by clicking and dragging the column to a new location. You can adjust a column's width by clicking and dragging the right edge of the column. For more information on editing and adding columns, see the topic on Editing the Settings for an Inventory Page.
Viewing the List of Device Classes in the Classic Skylar One User Interface
The Device Class page displays a list of existing device classes in the Device Class Register pane.
To view the list of device classes:
  1. Go to the Device Class page (System > Customize > Device Classes).
  2. For each device class, the Device Class Register pane displays:
  • Device Class. Name of the device class.
  • Description. Description of the device class. If the device class is for an entire manufacturer, rather than for a specific product, the description contains the value "OEM".
    If you see a device class of Ping | ICMP or a device with a device category of pingable, this means that the device does not support SNMP, that SNMP has been disabled on the device, or that the wrong SNMP credential was provided during discovery.
    If you see a device class of Generic | SNMP, this means that Skylar One discovered a SysObjectID for the device, but Skylar One does not include a device class that aligns with that SysObjectID.
  • Device Class Tier. This field is no longer used for subscription billing. For more information on billing, see Viewing and Managing Subscription Data.
    If you create a custom device class, contact ScienceLogic Customer Support to define the Device Class Tier for the new device class. If you do not contact ScienceLogic Customer Support, the device remains in the default bucket and ScienceLogic bills it at the full rate. ScienceLogic recommends that you include the PowerPack name that includes the new devices. For more information, see Custom Device Class Process.
  • Class ID. Unique numeric ID, automatically assigned to the device class by Skylar One.
  • Collection Type. Device type. Can be "physical", "virtual", or "component".
  • Process Collection. Specifies the application that maintains process information for the device. Skylar One polls this application for information on the system processes. Choices are:
  • n/a. Do not monitor processes.
  • Host Resource. MIB that provides information on processes.
  • HP/UX. Specifies that HP agents provide information on processes.
  • Solaris (prior to Solaris 10). Specifies that Solaris agents provide information on processes.
  • Extended User Information. Specifies that ScienceLogic's custom extension to net-SNMP provides process information. Install the extension before you select this option.
  • Device Dashboard. This field displays the device dashboard associated with the device class.
  • PowerPack. This field specifies whether or not this device class is included in a PowerPack.
  • Device Icon. The icon associated with the device class. To view the icon, click the picture icon ().
  • Discovery Identifier. An SNMP OID defined by the manufacturer. Usually, a hardware manufacturer specifies a SysObjectID for each different hardware model.
  • Subs. Specifies whether one or more devices are aligned with the device class. If so, the devices icon () appears in this column. To view the devices, click the devices icon in this column. The Subscribers modal, where you can view a list of devices that are aligned with the device class.
Creating Device Classes
The following sections describe how to create new device classes for:
Creating a New SNMP-Enabled Device Class
On the Device Class Editor page, you can define a new device class. Skylar One can then use this device class during discovery. You can assign this device class to devices.
You can use an existing device class as a template. Follow the steps in the Editing an SNMP-Enabled Device Class section, but enter a new name in the Device Class field. Then click Save As.
The Device Class Tier is no longer used for subscription billing. For more information on billing, see Viewing and Managing Subscription Data. If you create a custom device class, contact ScienceLogic Customer Support to define the Device Class Tier for the new device class. For more information, see Custom Device Class Process.
When you create an SNMP Enabled device class, you define a device class that uses the SNMP SysObjectID to identify member devices.
To create an SNMP Enabled device class:
  1. Click Reset to clear the fields in the Device Class Editor page.
  1. Select SNMP Enabled in the Device Type drop-down list. You can now define the value in the following fields:
  • Root Device. Select this checkbox to let this device have child devices. This setting includes root devices in auto-discovery.
  • Weight. If two device-class definitions are similar, a device might meet the criteria for both device classes. In this case, the Weight field tells Skylar One which device class to align with the device. Use the Weight field to define both detailed, non-SNMP device-class definitions and less detailed, catch-all device classes.
  • Skylar One aligns the device with the device-class definition with the lowest weight. If a device matches two device-class definitions, and both device classes have the same weight, Skylar One aligns the device with the device class that appears first in the alphabetical list of device classes.
    For example, you could define a detailed device class with a weight of "1" and a similar but less detailed device class with a weight of "10". Skylar One first tries to assign a discovered device to the device class with a weight of "1". If the device does not meet the criteria for that device class, Skylar One then tries to assign the discovered device to the device class with a weight of "10".
  • Device Class. The name of the manufacturer who created the device and/or agent. Can be any combination of alphanumeric characters, up to 48 characters in length.
  • Discovery Identifier (SysObjectID). The SNMP object identifier (OID), in numeric form, that is returned when querying the device's sysObjectID. Can be up to 64 characters in length. Refer to the appropriate Management Information Base (MIB) file to determine this value.
  • Discovery Qualifier (SNMP OID). Optional field. Secondary SNMP OID, in numeric form, used to further qualify device types. Can be up to 255 characters in length. If a device matches both the Discovery Identifier and responds to the Discovery Qualifier, the device is assigned to the device class.
  • Tabular. If you want to use a tabular value in the Discovery Qualifier field, select this checkbox. When you select this checkbox, Skylar One performs an SNMP walk of the Discovery Qualifier (as opposed to an SNMP "get" request) and then search for the value that matches the Qualifier Match field.
  • Qualifier Match. Optional field. String that must be present in returned value for the Discovery Qualifier OID. If a device matches the Discovery Identifier, responds to the Discovery Qualifier, and the response matches the Qualifier Match, the device is assigned to the device class. Can be up to 64 characters in length.
  • Description. The model name of the device. Can be any combination of alphanumeric characters, up to 48 characters in length. For ease of use, ScienceLogic recommends that you follow this convention: If you are creating a device class for an entire manufacturer, rather than for a specific product, enter "OEM" as the device description.
  • Device Icon. The icon used to display the device in the graphical interface. To view the available icons, click Icons. Select an icon from the drop-down list.
  • All in class. Select this checkbox to update the device icon for all existing members of the device class.
  • Device Category. A logical categorization of device by primary function. Use this field so that Skylar One groups related devices in reports and views. Select a value from the drop-down list.
  • All in class. Select this checkbox to update the device category for all existing members of the device class.
  • System Uptime OID. Specifies the OID to monitor to determine system uptime. Choices are:
  • sysUpTime (.1.3.6.1.2.1.1.3.0). Default. From the System group of MIB RFC 1213. Returns uptime of the device's SNMP Agent. The time (in hundredths of a second) since the network management portion of the system was last re-initialized.
  • hrSystemUptime (.1.3.6.1.2.1.25.1.1.0). From the HR-MIB. The amount of time since this host was last initialized.
  • Any additional OIDs defined on the System Uptime OIDs page (System > Customize > Uptime OIDs).
  • Correlation Method. Used for special topological correlation. Allows Skylar One to support event correlation and mapping for VMware and Microsoft hypervisors.
  • Collection Type. Specifies whether the device is a hardware-based device (physical) or a virtual device.
  • PDU Packing. If your managed network includes a large number of SNMP elements such as interfaces that you want to monitor, select this checkbox. PDU packing enables faster collection of large amounts of SNMP data. For more information, see the section on Additional Configuration for Concurrent Network Interface Collection in the Monitoring Device Infrastructure Health manual.
  • Process Collection. Specifies how Skylar One retrieves process information for the device. Skylar Oneuses this method to gather information on the system processes. Choices are:
  • Host Resource. Specifies that the system uses the Host Resources MIB to collect information on processes.
  • Service Collection. Specifies how to collect information on services. Choices are:
  • n/a. This is not an applicable device class.
  • Windows Basic. Use the Windows MIB to gather information about Windows services.
  • WMI Informant. Use the WMI Informant MIB to gather information about Windows services.
  • L2 Topology. Select from the following Layer-2 topology options for the device class:
    • Disabled. Disables Layer-2 topology collection and processing for the device class. If this is selected, devices assigned to the device class inherit the system-wide topology settings that are set on the Behavior Settings page (System > Settings > Behavior). For more information, see the section on Global Settings for System Behavior.
    • Processing Enabled. Enables Layer-2 topology processing for the device class using the "Enterprise Database: Topology Crunch" process to determine Layer-2 topology relationships based on device category, with the purpose of connecting network devices to each other, but uses methods other than standard SNMP for collection.
    • Collection and Processing Enabled. Enables Layer-2 topology collection and processing for the device class using the standard SNMP collection methods and the "Enterprise Database: Topology Crunch" process to determine Layer-2 topology relationships based on device category, with the purpose of connecting network devices to each other.
    • Enhanced Processing Enabled. Enables more robust Layer-2 topology processing for the device class, but using methods other than standard SNMP for collection. This enhanced processing can form Layer-2 relationships between any devices that match a MAC address from the BRIDGE-MIB or sourced from Dynamic Applications, regardless of device category.
    • Collection and Enhanced Processing Enabled. Enables more robust Layer-2 topology processing and collection for the device class, using the standard SNMP collection methods. This enhanced processing can form Layer-2 relationships between any devices that match a MAC address from the BRIDGE-MIB or sourced from Dynamic Applications, regardless of device category.
  • L3 Topology. Select from the following Layer-3 topology options for the device class:
    • Disabled. Disables Layer-3 topology collection and processing for the device class. If this is selected, devices assigned to the device class inherit the system-wide topology settings that are set on the Behavior Settings page (System > Settings > Behavior). For more information, see the section on Global Settings for System Behavior.
    • Processing Enabled. Enables Layer-3 topology processing for the device class using the standard topology crunch process to determine Layer-3 topology relationships, but requires all the hops in a traceroute to respond and match devices within Skylar One in order to form the relationship.
    • Collection and Processing Enabled. Enables Layer-3 topology collection and processing for the device class using the standard topology crunch process to determine Layer-3 topology relationships, but requires all the hops in a traceroute to respond and match devices within Skylar One in order to form the relationship.
    • Enhanced Processing Enabled. Enables more robust Layer-3 topology processing for the device class, where the system forms relationships between any two hops that respond and match devices in Skylar One rather than discarding incomplete traceroutes or results that include unmatched hops.
    • Collection and Enhanced Processing Enabled. Enables more robust Layer-3 topology processing and collection for the device class, where the system forms relationships between any two hops that respond and match devices in Skylar One rather than discarding incomplete traceroutes or results that include unmatched hops.
  • LLDP Topology. Select from the following Link Layer Discovery Protocol (LLDP) topology options for the device class:
    • Disabled. Disables LLDP topology collection and processing for the device class. If this is selected, devices assigned to the device class inherit the system-wide topology settings that are set on the Behavior Settings page (System > Settings > Behavior). For more information, see the section on Global Settings for System Behavior.
    • Processing Enabled. Enables LLDP topology processing for the device class using the "Enterprise Database: Topology Crunch" process to determine LLDP topology relationships between two devices that both respond with LLDP neighbor data, show each other as a neighbor, and are managed devices in Skylar One, but uses methods other than standard SNMP for collection.
    • Collection and Processing Enabled. Enables LLDP topology collection and processing for the device class using standard SNMP collection methods and the "Enterprise Database: Topology Crunch" process to determine LLDP topology relationships between two devices that both respond with LLDP neighbor data, show each other as a neighbor, and are managed devices in Skylar One.
    • Enhanced Processing Enabled. Enables more robust LLDP topology processing for the device class, but using methods other than standard SNMP for collection. This enhanced processing can form LLDP relationships between two devices so long as at least one of those devices responds with LLDP neighbor data and is a managed device in Skylar One.
    • Collection and Enhanced Processing Enabled. Enables more robust LLDP topology processing and collection for the device class, using the standard SNMP collection methods. This enhanced processing can form LLDP relationships between two devices so long as at least one of those devices responds with LLDP neighbor data and is a managed device in Skylar One.
  • CDP Topology. Select from the following Cisco Discovery Protocol (CDP) topology options for the device class:
    • Disabled. Disables CDP topology collection and processing for the device class. If this is selected, devices assigned to the device class inherit the system-wide topology settings that are set on the Behavior Settings page (System > Settings > Behavior). For more information, see the section on Global Settings for System Behavior.
    • Processing Enabled. Enables CDP topology processing for the device class using the "Enterprise Database: Topology Crunch" process to determine CDP topology relationships between two devices that both respond with CDP neighbor data, show each other as a neighbor, and are managed devices in Skylar One, but uses methods other than standard SNMP for collection.
    • Collection and Processing Enabled. Enables CDP topology collection and processing for the device class using standard SNMP collection methods and the "Enterprise Database: Topology Crunch" process to determine CDP topology relationships between two devices that both respond with CDP neighbor data, show each other as a neighbor, and are managed devices in Skylar One.
    • Enhanced Processing Enabled. Enables more robust CDP topology processing for the device class, but using methods other than standard SNMP for collection. This enhanced processing can form CDP relationships between two devices so long as at least one of those devices responds with CDP neighbor data and is a managed device in Skylar One.
    • Collection and Enhanced Processing Enabled. Enables more robust CDP topology processing and collection for the device class, using the standard SNMP collection methods. This enhanced processing can form CDP relationships between two devices so long as at least one of those devices responds with CDP neighbor data and is a managed device in Skylar One.
  • ARP Topology. Select from the following Address Resolution Protocol (ARP) topology options for the device class:
    • Disabled. Disables ARP topology collection and processing for the device class. If this is selected, devices assigned to the device class inherit the system-wide topology settings that are set on the Behavior Settings page (System > Settings > Behavior). For more information, see the section on Global Settings for System Behavior.
    • Processing Enabled. Enables ARP topology processing for the device class using the "Enterprise Database: Topology Crunch" process to determine ARP topology relationships between two devices that are routers or switches on the same local network, are managed devices in Skylar One, and include a device with an IP address and another with a physical MAC address.
    • Collection and Processing Enabled. Enables ARP topology collection and processing for the device class using standard SNMP collection methods and the "Enterprise Database: Topology Crunch" process to determine ARP topology relationships between two devices that are routers or switches on the same local network, are managed devices in Skylar One, and include a device with an IP address and another with a physical MAC address.
    • Enhanced Processing Enabled. Enables advanced ARP topology processing for the device class. This enhanced processing can form ARP relationships between two devices of any device class so long as at least one of those devices responds with ARP data and is a managed device in Skylar One.
    • Collection and Enhanced Processing Enabled. Enables advanced ARP topology processing and collection for the device class using standard SNMP collection methods. This enhanced processing can form ARP relationships between two devices of any device class so long as at least one of those devices responds with ARP data and is a managed device in Skylar One.
  • Agent Identifier 1 and Agent Identifier 2. These fields are used to align device classes to devices using the Skylar One agent. Device classes exist for every possible combination of values returned by the agent; you do not need to enter or change values in these fields when creating or editing a device class.
  • Device Dashboard. Select a device dashboard from a list of all device dashboards in Skylar One. For devices with this device class, the selected device dashboard appears as an option on the Device Summary page. This field is optional.
  • Interface Index Change Detection. On some devices, the SNMP index of an interface can change when the interface goes down and then comes back up. If you select this checkbox, Skylar One uses the combination of interface ID and ifPhysAddress to monitor interfaces on devices that use this device class and to align events with those interfaces.
  1. Click Save to save the new device class or click Save As to save your changes under a new device class name.
On the Device Class Editor page, you can edit a device class for a device that supports SNMP.
When you select SNMP Enabled, you define a device class that uses the SNMP SysObjectID to identify member devices.
To edit an existing device class:
  1. Go to the Device Class Editor page (System > Customize > Device Classes), or from the Device Properties page, click the pencil icon ().
  2. In the Device Class Register pane at the bottom of the page, find the device class you want to edit. Click its wrench icon (wrench icon).
  3. The fields in the top pane display the values from the selected device class. You can edit one or more of the fields described in the section Creating a New SNMP-Enabled Device Class.
  4. Click the Save button to save your changes to the device class or click the Save As button to save your changes under a new device class name.
Creating a New Device Class for a Device with Device Class "Generic | SNMP"
After discovery, Skylar One might discover devices and assign those devices to the device class Generic | SNMP. This means that Skylar One was able to retrieve a SysObjectID value from the device, but Skylar One does not include a Device Class for that SysObjectID.
The Device Class Tier is no longer used for subscription billing. For more information on billing, see Viewing and Managing Subscription Data. If you create a custom device class, please contact ScienceLogic Customer Support to define the Device Class Tier for the new device class. For more information, see Custom Device Class Process.
To create a new device class for a device with device class Generic | SNMP:
  2. On the Device Manager page, find the device with the device class Generic | SNMP. Click the wrench icon (wrench icon) for the device.
  3. In the Device Administration panel, click the Toolbox tab.
  4. On the Device Toolbox page, click the SNMP Walker icon.
  5. In the SNMP Walker modal, go to the drop-down menu in the upper left and select System MIB. Then click the Walk button.
  6. The second entry in the Returned Value column is the SysObjectID. For example, that value is 1.3.6.1.4.1.303.3.3.7.3. Copy this value and save it in a document or write down this value. You need it to create a new device class.
  7. Follow the directions in the section Creating a New SNMP-Enabled Device Class. In the Discovery Identifier field, enter the value of the SysObjectID from the SNMP Walker. Make sure there are no blank spaces before or after the SysObjectID value.
  8. To assign the new device class to a device, follow the instructions in the section Manually Changing the Device Class for a Device.
  9. Alternatively, you can rediscover the device with the device class "Generic | SNMP". To rediscover the device, go to the Device Manager page (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface). Find the device you want to rediscover. Click its wrench icon (wrench icon). On the Device Properties page for the device, click the magnifying glass icon ().
  10. After you rediscover the device, it aligns with the new device class.
Creating a New Device Class for Devices That Do Not Support SNMP
Skylar One includes device classes for devices that are "pingable". By default, these devices are aligned with the device category of "pingable" and are placed in the device class "Ping | ICMP". To discover devices that have a device category of "pingable", you must select Discover Non-SNMP in the Discovery Session Editor page.
Devices with the device category of "pingable" are devices that meet one of the following criteria:
  • Device does not support SNMP.
  • Either no SNMP credential was provided in the discovery session or an incorrect SNMP credential was provided in the discovery session.
In some cases, you might want to discover a "pingable" device and use XML requests, XSLT requests, WMI requests, SOAP transactions, Python snippets, or SQL queries to gather information from the device. You can do this through Dynamic Applications.
You might also want to create a more descriptive device class for these types of devices and assign a device category other than "pingable". Skylar One can use the values returned by nmap (run during discovery) to match a "pingable" device to a descriptive device class.
You can use an existing device class as a template when defining a new device class. To do this, follow the steps in the Editing a Device Class That is Not SNMP-Enabled section, but supply a new name in the Device Class field and click Save As to save your changes.
When you create a Pingable device class, you define a device class that uses the XML values returned by nmap to identify member devices.
To create a new device class with a device category of "pingable":
  1. To discover details about devices that do not support SNMP, during discovery (System > Manage > Classic Discovery), select an Initial Scan Level of 5. Deep Discovery and select the checkbox for Discover Non-SNMP. Skylar One runs the following nmap command on each device during discovery:
nmap -sS -O --host-timeout=12000ms "-p 21,22,23,25,80" -A --version-all -oX full pathname of file in which to store XML output IP address of device
 Depending on your selections on the Discovery Session Editor page, Skylar One might use the -sU or -sT option instead of -sS. The value supplied to the host-timeout option will vary depending upon the list of ports specified in the Discovery Session Editor page. The list of ports supplied with the -p option will vary depending upon the list of ports specified in the Discovery Session Editor page. For more information on the nmap command, see the webpage http://nmap.org/book/man.html.
  1. Skylar One stores the output from the nmap command in an XML file. In the NMAP Report XPATH field (described later in this section), you specify a path in that XML file. That path specifies the location of a value in the XML file. Skylar One then examines the specified value and use the regular expression defined in the XPATH Match Regex field (described later in this section) to match devices to this device class.
  2. To begin gathering information to include in the device class, find a device for which you want to create a "pingable" device class. If you have already discovered this device, it might currently have a device class of "Ping | ICMP".
  1. You must now run nmap on the device. You can either log in directly to the device or log in to another device that can communicate with the device on which you want to run nmap. At the command prompt, enter the following:
nmap -sS -O -oX full pathname of file in which to store XML output -sV --version-all -A IP address of device
  1. Go to the XML file where you stored the output from the nmap command. Examine the output and find an XML element or attribute that you can use to uniquely identify a device class for the device. Note the XPATH to the element or attribute.
  1. The device data in the XML report generally uses the following element structure:
  • Information about nmap, including scan level and debugging level.
  • Information about each discovered host, including start-time and end-time for the nmap and the IP address, MAC address, and hardware vendor.
  • Specific information about each port, including the service running on the port, some stored as attributes of the Port element, some stored as child elements of the Port element.
  • Specific information about the operating system, including vendor and version number, stored as attributes of the OSClass element.
  • Information about uptime for the device.
  • Information about traceroute to the discovered device and round-trip time to the discovered device.
  • Performance data for this session of nmap.
  1. For example, to create a device class for each device that runs an Apache web server, run nmap on a device that runs Apache. The output might include the following elements and attributes under Host/Ports:
<port protocol="tcp" portid="80">
<state state="open" reason="syn-ack" reason_ttl="64"/>
<service name="http" product="Apache httpd" version="2.2.3" extrainfo="(CentOS)" method="probed" conf="10" />
<script id="html-title" output="Apache HTTP Server Test Page powered by CentOS" />
<script id="http-favicon" output="" />
</port>
The XPATH would be /nmaprun/host/ports/port/service/@product
  1. Go to the Device Class Editor page (System > Customize > Device Classes) to create a new device class. Click the Reset button to clear any values from the Device Class Editor page. Complete the following fields:
  • Device Type. Select Pingable.
  • Root Device. Specifies that this device can have children devices. Ensures that root devices are included in auto-discovery. Leave this checkbox unselected.
  • Weight. If two device-class definitions are similar, a device might meet the criteria for both device classes. In this case, the Weight field tells Skylar One which device class to align with the device. The Weight field allows you to define both detailed, non-SNMP device-class definitions, as well as less detailed, catch-all device classes.
  • NMAP Report XPATH. Specifies how the system parses the results of an nmap request (run during discovery) to determine whether the device aligns with this device class. If you select an Initial Scan Level of 5. Deep Discovery for a discovery session, Skylar One runs the following nmap command on each device during discovery. Skylar One includes the -A option, to retrieve as much information as possible and match pingable devices with custom device classes.
  • In the NMAP Report Path field, enter the XPATH for the element or attribute you want to use to identify member devices. That path specifies the location of a value in the XML file. Skylar One then examines the specified value and use the regular expression defined in the XPATH Match Regex field to match devices to this device class.
In Skylar One, the XPATH must always begin with /nmaprun/host. Using the example from step 7, enter an XPATH of:
In the NMAP Report Path field, enter the entire path to the attribute that you want to match, but do not filter on the attribute value. That is, enter /nmaprun/host/ports/port/service/@product instead of /nmaprun/host/ports/port/service/@product='Apache httpd'. When you include the value of the attribute in the XPATH, XPATH does not return the attribute value, but instead returns the entire element that includes the attribute. Because the element is not a text string, Skylar One cannot search the element using a regular expression.
  • XPATH Match Regex. In this field, specify a regular expression you want to use when examining the value returned by nmap. The location of the value returned by nmap is defined in the NMAP Report XPATH field. Skylar One aligns a device to a device class if the nmap response includes a value at the path specified in the NMAP Report XPATH and the value at that location matches the regular expression in the XPATH Match Regex field.
Using the example in step 7, enter the value Apache httpd.
  • Device Category. A logical categorization of device by primary function. Use this field to group related devices in reports and views. Select a value from the drop-down list.
  • All in class. Selecting this checkbox updates the device category for all existing members of the device class.
  • Weight. If two device-class definitions are very similar, a device might meet the criteria for both device classes. In this case, the Weight field tells which device class to align with the device. Skylar One aligns the device with the device-class definition with the lowest weight. If a device matches two device-class definitions, and both device classes have the same weight, Skylar One aligns the device with the device-class that appears first in the alphabetical list of device classes.
The Weight field allows you to define detailed non-SNMP device-class definitions and still have catch-all device-classes with less-specific criteria.
For example, you could define a detailed device class with a weight of "1" and a similar but less detailed catch-all device class with a weight of "10". Skylar One first tries to assign a discovered device to the device class with a weight of "1". If the device does not meet the criteria for that device class, Skylar One then tries to assign the discovered device to the device class with a weight of "10".
  • Device Dashboard. Select a device dashboard from a list of all device dashboards in Skylar One. For devices with this device class, the selected device dashboard appears as an option on the Device Class Editor page. This field is optional.
  1. Click the Save button to save your changes to the device class or click the Save As button to save your changes under a new device-class name.
Applying the New Device Class
To apply a new "pingable" device class during discovery:
  1. Go to the Discovery Control Panel page (System > Manage > Classic Discovery). If you are creating a new discovery session, click the Create button. If you are editing an existing discovery session, click its wrench icon (wrench icon).
  2. On the Discovery Session Editor page:
  • In the Initial Discovery Scan Level field, select 5. Deep Discovery.
You can also define Initial Discovery Scan Level field on the Behavior Settings page (System > Settings > Behavior). Because this discovery level is very compute-intensive, you might want to avoid setting this discovery level globally and instead choose this discovery level only for specific discovery sessions.
  • Select the Discover Non-SNMP checkbox.
  • Select the Model Device checkbox.
  1. Click the Save button.
  2. When you run the discovery session, Skylar One applies the new device class to discovered or rediscovered devices.
You can also apply a new "pingable" device class during auto-discovery. You can define Rediscovery Scan Level on the Behavior Settings page (System > Settings > Behavior) and select 5. Deep Discovery. However, because this auto-discovery level is very compute-intensive, you might not want to use this setting for global auto-discovery.
Maintaining the New Device Class During Auto-Discovery
If you applied a new "pingable" device class to a device, do the following to make sure that auto-discovery does not reset the device class to "Ping | ICMP":
Skylar One resets a pingable device's device class to "Ping | ICMP" if Deep Discovery is not enabled for auto-discovery. You can enable Deep Discovery for auto-discovery on the Behavior Settings page (System > Settings > Behavior). In the Rediscovery Scan Level field, select 5. Deep Discovery. However, because this auto-discovery level is very compute-intensive, you might not want to use this setting for global auto-discovery.
You can disable auto-discovery for each device that uses Deep Discovery. Instead of auto-discovery, you can create a scheduled discovery session that updates the device class. To disable auto-discovery for a device and create a scheduled discovery session:
  1. Go to the Device Properties page (Devices > Classic Devices > wrench icon).
  2. Clear the checkbox for Auto-Update.
  3. Click the Save button.
  4. Go to the Discovery Control Panel page (System > Manage > Classic Discovery). Create a discovery session for this device and for each device that uses Deep Discovery and that you want to update regularly. Use these settings:
  1. Define the new discovery session as a scheduled discovery session, so you can periodically update the device's data.
On the Device Class Editor page, you can edit the parameters of an existing device class.
When you do not select SNMP Enabled, you define a device class that does not use SNMP to identify member devices. Instead, the device class uses a value returned by nmap (run during discovery) to identify member devices.
You can use an existing device class as a template for a new device class. To do this, follow the steps in this section, but supply a new name in the Device Class field and click the Save As button to save your changes.
To edit an existing Device Class:
  4. On the Device Class Editor page, you can edit the parameters of an existing device class. If you do not select SNMP Enabled in the Device Type drop-down list, you can edit the value in one or more of the fields described in the section Creating a New Device Class for Devices That Do Not Support SNMP.
  5. Click the Save button to save your changes to the device class or click the Save As button to save your changes as a new device class. The newly selected device class is now associated with the device.
Creating a New Component Device Class
A component device is an entity that runs under the control of a management system on a physical device. For example, Skylar One can discover a VMware ESX Server (management system) and then discover the virtual machines (component devices) running on that VMware ESX Server.
Skylar One uses Dynamic Applications to retrieve data from a management system and discover each component device managed by that system. Skylar One then uses that retrieved data to create each component device.
Device classes for components are aligned with the Dynamic Applications that discover component devices. For example, you can create a Component device class for "Cisco Systems | UCS Chassis". You can align the Dynamic Application for "UCS Chassis Discovery" with this device class. When Skylar One runs the "UCS Chassis Discovery" Dynamic Application and discovers a component device, Skylar One assigns each discovered component device to the device class "Cisco Systems | UCS Chassis".
When you create a Component device class, you define a device class that uses an aligned Dynamic Application to identify the member devices.
To create a Component device class:
  2. Click [Reset] to clear the fields in the Device Class Editor page.
  3. Configure the device class as follows:
    • Device Type. Select "Component".
    • Device Class. Enter "ScienceLogic".
    • Device Category. Select "Servers" from the drop-down list. This field specifies a logical categorization of devices by primary function, so that Skylar One groups related devices in reports and views.
    • Root Device. Select this checkbox if this component device has additional tiers under it.
    • Description. Enter a description for the device.
    • Device Icon. Select an icon that you created or select a generic icon.
  4. Click Save to save your changes to the device class.
Editing a Component Device Class
To edit an existing component device class:
  • Go to System > Customize > Device Classes, or from the Device Properties page, click the pencil icon ().
  • In the Device Class Register pane at the bottom of the page, find the device class you want to edit. Click its wrench icon (wrench icon).
  • The fields in the top pane display the values from the selected device class.
  • You can edit the value in one or more of the fields. For more information on each field, see the section on Creating a New Component Device Class.
  • Click the Save button to save your changes to the device class or click the Save As button to save your changes under a new device-class name.
Managing Device Classes
Stopping Collection
One of the ScienceLogic hourly maintenance tasks checks the last collection time for every collection object being collected from every device. If the last collection time for an object on a device is more than 48 hours ago, collection is stopped for that collection object on that device. Skylar One sets the Collect status of that object to No.
If a device is in maintenance mode, is unavailable, or has been manually disabled by a user, Skylar One does not automatically set the Collect status of objects to No. Skylar One will automatically set the Collect status of objects to No only if the device is up and running, but Skylar One still cannot collect the object.
When Skylar One sets the Collect status of that object to No, Skylar One generates an event. The event includes the name of the device, the name of the Dynamic Application, the name of the collection object, and the collection object IDs. By default, this event is of severity "notice".
For Dynamic Applications that have the Component Mapping checkbox selected on the Dynamic Applications Properties Editor page, Skylar One will never automatically set the Collect status to No for any of the collection objects in the Dynamic Application.
For Dynamic Applications that have the Caching fields set to either Cache Results or Consume cached results in the Dynamic Applications Properties Editor page, Skylar One will never automatically set the Collect status to No for any of the collection objects in the Dynamic Application.
Starting Collection
For each object that has the Collect status of No, Skylar One attempts to re-collect the object once a day. If re-collection is successful, Skylar One will automatically set the Collect value for that object to Yes.
If a user manually sets the Collect status of a collection object or presentation object to No, Skylar One will not attempt to re-collect the object once a day and will not set the Collect status to Yes.
Collection Objects That Are Excluded From Maintenance
The Collect status of the following collection objects is never changed automatically:
  • Collection objects in Dynamic Applications that have the Component Mapping checkbox selected on the Dynamic Applications Properties Editor page.
  • Collection objects in Dynamic Applications that have the Caching fields set to either Cache Results or Consume cached results, on the Dynamic Applications Properties Editor page.
  • Collection objects that have the Disable Object Maintenance setting enabled.
  • Collection objects that have a Collect status defined by a user, that is, collection objects that were manually enabled or disabled by a user.
Manually Assigning a Device Class to a Device
To manually assign a device class to a device:
  1. Go to the Devices page. Select the device to which you want to assign a device class.
  2. On the Device Investigator, click Edit.
  3. Click the Info drop-down list and click the Device Class field. The Select a Device Class modal appears.
  1. The Select a Device Class window displays a searchable list of available device classes, and the category and type for each class.
    To use an advanced search to find a specific device class, click the gear icon () to the right of the Search field and select Advanced. For more information, see Performing an Advanced Search.
  2. Select the device class you want to assign and click the Set Class button.
  3. Click the Save button on the Device Investigator to save your changes.
Changing the Icon for a Device Class
You can customize the appearance of the devices that appear on the Devices page by assigning an icon to a device, device class, or device category.
  2. Click the actions icon (actions icon) for that item and select Assign Icon. The Select an Icon modal appears.
  3. In the Select an Icon window, do one of the following:
    • To use an existing icon, proceed to step 7.
    • To upload a new icon from your local drive, make sure that the image file meets the following criteria, then proceed to step 4:
    • The image file must be in SVG format.
    • The file must not be larger than 40 KB.
    • The file must not be animated.
    • The file must not contain bitmaps.
  1. To start the upload process, click the Add Icon button. The Add an Icon modal appears.
  2. Complete the following fields in the Add an Icon modal:
    • In the Icon name field, enter a name for the icon you want to upload.
    • In the Add Tags field, type a short descriptor for the icon, without spaces. You can use this tag for searching later.
    • You can click the Browse or Drop area to browse for and select the icon, or you can drag and drop the icon file onto the Add an Icon modal.
  3. Click the Add Icon button. The icon appears in the Select an Icon modal.
  4. Select the icon from the list of icons and click the Select Icon button. The system assigns the icon to the device, device class, or device category.
    You can use the Search field to search for a specific icon or narrow down the list of icons.
Managing Device Classes in the Classic Skylar One User Interface
The following sections describe:
Manually Changing the Device Class for a Device in the Classic Skylar One User Interface
During discovery, Skylar One automatically assigns a device class to each discovered device. For example, Skylar One assigns the device class "Ping" to devices that do not support SNMP. You might want to manually change the device class for such a device after discovery.
On the Device Properties page, you can assign a different device class to the device.
To assign a different device class to the device:
  2. Find the device you want to edit. Click its wrench icon (wrench icon).
  3. On the Device Properties page, find the Device Class field. Click the toolbox icon ().
  4. In the Select New Device Class modal, select a device class.
  5. There are two other ways to align devices with the device class:
  • You can re-run discovery for a single device. To rediscover a device, go to Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface. Find the device you want to rediscover. Click its wrench icon (wrench icon). On the Device Properties page for the device, click the magnifying glass icon (). After you rediscover the device, it aligns with the appropriate device class. You can repeat this process for each device you want to align with the new or edited device class.
  • If you re-run one or more discovery sessions (System > Manage > Classic Discovery), Skylar One automatically applies the new or edited device class to those devices that match the criteria. Remember that to discover details about "pingable" devices, you must select the checkbox Discover Non-SNMP. Optionally, to retrieve details about "pingable" devices, in the field Initial Scan Level, you can also select 5. Deep Discovery.
Changing the Icon for a Device Class in the Classic Skylar One User Interface
You can select a new icon for a device class or import your own image as an icon. To change the icon for a device class:
  3. The fields in the top pane display the values from the selected device class. To edit the icon associated with the selected device class, edit the value of the Device Icon field. The icon you select becomes the icon for the device class.
  • To view the list of icon names and icon images, click the Icon button in the upper right of the page.
  • The Device Icon Browser modal displays a list of all icons for device classes.
  • To import an image to use as an icon, click the Import button. In the Device Icon Browser modal, you can import a .png image for use as an icon in Skylar One.
  1. Click the Save button to save the changes to the device class.
Aligning One or More Device Classes with a Device Dashboard
From the Device Class Editor page, you can align one or more device classes with a device dashboard. You can manually align a device dashboard with a device class. For devices that do not have a device dashboard defined on the Device Properties page, the device dashboard associated with the device class appears as the default view on the Device Summary page.
From the Device Summary page, you can select and view any device dashboards that are associated with the device, the device's device class, the device's device category, the device's Dynamic Applications, and the Global Default.
  1. To align a device dashboard with one or more device classes:
  2. Go to the Device Class Editor page (System > Customize > Device Classes).
  3. In the Device Class Register pane at the bottom of the page, find the device classes you want to align. Select their checkboxes.
  4. In the Select Action drop-down list in the lower right, select a device dashboard in the Align Device Dashboard section. Click the Go button.
  5. Each selected device class is now aligned with the selected device dashboard. For devices that do not have a device dashboard defined on the Device Properties page, the device dashboard associated with the device class appears as the default view on the Device Summary page.
Deleting One or More Device Classes
From the Device Class Editor page, you can delete one or more device classes.
You cannot delete a device class if it is aligned to a device. To delete a device class that has devices aligned to it, first realign any member devices to a different device class.
To delete one or more device classes:
  1. In the Device Class Register pane at the bottom of the page, find the device classes you want to delete. Select their checkboxes.
  2. In the Select Action drop-down list in the lower right, select DELETE Device Classes. Click the Go button.
  3. Each selected device class is deleted from Skylar One.
Device Categories
A device category is a logical categorization of a device by primary function, such as "server", "switch", or "router". Skylar One uses device categories to group related devices in reports and views.
Device categories work with device classes to organize and describe discovered devices. Device class usually describes the manufacturer. Device category describes the function of the hardware. Each device class can include a device category.
"Reserved" device categories are those device categories required by Skylar One. You cannot edit or delete these device categories. If a device category does not display the delete icon (), the device category is a reserved device category and cannot be deleted.
"Pingable" Device Category
  • SNMP is disabled on the device.
  • An incorrect credential was provided during discovery, and you selected the Discover Non-SNMP checkbox for the discovery session.
Viewing the List of Device Categories
On the Device Categories page (Devices > Device Categories), if you have the proper permissions, you can view a list of existing device categories, create and edit device categories, and duplicate device categories.
You can also assign an icon to a specific device category, and those icons appear on the Device Categories page. The icons also appear on Maps as well as Device Investigator and Service Investigator pages.
Image of the Device Categories page
If you are looking for a very specific set of device categories, click the gear icon () to the right of the Search field and select Advanced. In this mode you can create an advanced search using "AND" or "OR" for multiple search criteria. For more information, see Performing an Advanced Search.
For each device category, the Device Categories page displays the following information:
  • Category Name. The name of the device category.
  • Last Edited By. The name of the user who created or last edited the device category.
  • Last Edited. The date and time at which the device category was created or last edited.
Creating a New Device Category
To create a new device category:
  1. On the Device Categories page (Devices > Device Categories), click the Create Device Category button. The Add New Category modal appears.
Image of the Add New Category page
  1. In the Category Name field, enter a name for the new device category.
  2. To add an icon for the new category, click the Browse area to select an existing icon from the Select an Icon window.
  1. On the Add New Category modal, click the Save Category button. The new category appears on the Device Categories page.
Editing a Device Category
To edit a device category:
  1. On the Device Categories page, locate the device category that you want to edit.
  2. Click the name of the device category to open the category details page.
  3. You can edit the Category Name and Icon. When you are finished making changes, click the Save Category button.
Duplicating a Device Category
To duplicate a device category:
  1. On the Device Categories page, locate the device category that you want to duplicate.
  2. Click the Actions button () for that device category and select Duplicate.
  3. A duplicate of that device category appears with the word "copy" added to the original name. Click the name of the device category to edit the category name.
Assigning an Icon to a Device Category
Managing Device Categories in the Classic Skylar One User Interface
This section describes how to view, define, and manage device categories using the Device Category Editor page in the classic Skylar One user interface.
Viewing the List of Device Categories in the Classic Skylar One User Interface
The Device Category Editor page displays a list of all existing device categories. To view this page:
  1. Go to the Device Category Editor page (System > Customize > Device Categories).
  2. For each device category, the Device Category Editor page displays the following:
  • Map Icon. Pathname of the image used as an icon for the device category.
  • Device Dashboard. This field displays the device dashboard associated with the device category.
  • ID. A unique numeric identifier for the device category, automatically assigned by Skylar One.
  • Edit User. User who created or last edited the device category.
  • Edit Date. Date and time the device category was created or last edited.
Creating a New Device Category in the Classic Skylar One User Interface
From the Device Category Editor page, you can create a new device category. To create a new device category:
  2. Click the Reset button to clear any values from the fields in the editor pane.
  3. In the editor pane at the top of the page, supply values in each of the following fields:
  • Category Name. Enter a name for the new device category. This name can be any combination of alphanumeric characters, up to 32 characters in length. The Skylar One naming convention is to start names with one of the following prefixes:
  • Environmental for environmental-monitoring devices.
  • Network for networking hardware like routers, switches, and firewalls.
  • Office for office equipment.
  • Server for server hardware.
  • System for networked hardware like servers and network stores.
  • Telephony for telephone hardware.
  • Wireless for wireless network hardware.
However, you are not required to follow this convention.
  • Map Icon. Select an icon to be associated with this device category. You can select from a list of all possible icons for device categories. The selected icon represents members of the device category in network maps.
  • Device Dashboard. Select a device dashboard from a list of all device dashboards in Skylar One. For devices with this device category, the selected device dashboard appears as an option on the Device Summary page. This field is optional.
  2. The new device category appears in the list of device categories on this page and in the Device Category drop-down list on the Device Class Editor page.
Editing a Device Category in the Classic Skylar One User Interface
On the Device Category Editor page, you can edit the parameters of an existing device category. To edit a device category:
  2. In the register pane at the bottom of the page, find the device category you want to edit. Click its wrench icon (wrench icon).
  3. The fields in the top pane display the values from the selected device category. You can edit the value in one or more of the fields.
  4. For more information on each field, see the section on Creating a New Device Category.
Deleting a Device Category
From the Device Category Editor page, you can delete an existing device category.
Do not delete device categories that are being used by managed devices. If you delete a device category to which devices have been assigned, you risk losing data from the device.
To delete a device category:
  2. Find the device category you want to delete. Click its delete icon ().
  3. The device category is deleted from Skylar One.
Aligning One or More Device Categories with a Device Dashboard
From the Device Category Editor page, you can align one or more device categories with a device dashboard. For devices that do not have a device dashboard defined on the Device Properties page or on the Device Class Editor page, the device dashboard associated with the device category appears as the default view on the Device Summary page.
To align a device dashboard with one or more device categories:
  1. Go to the Device Category Editor page (System > Customize > Device Categories ).
  2. Find the device categories you want to align. Select their checkboxes ().
  3. In the Select Action drop-down list in the lower right, select a device dashboard under the Align Device Dashboard section. Click the Go button.
  4. Each selected device category is now aligned with the selected device dashboard. For devices that do not have a device dashboard defined on the Device Properties page or on the Device Class Editor page, the device dashboard associated with the device category appears as the default view on the Device Summary page.
