Device Dashboards
A dashboard in Skylar One is a page that displays graphical reports. Each report, called a widget, appears in its own pane. To define a graphical report, you select from a list of predefined widgets and then customize the selected widget by supplying values in the configuration fields. The customized widget then generates a graph, chart, table, or other information in a pane in the dashboard. For more information on generating and viewing dashboards, see the section on Dashboards.
The Device Summary page, which appears when you click the graph icon () for a device in the classic Skylar One user interface, displays one or more dashboards similar to the dashboards available on the Dashboards tab.
The Device Summary page always displays dashboards for the current device. Typically, the widgets on a device dashboard are configured to read the device context. As a result, the widgets display data for the device being viewed.
The Device Dashboards page (System > Customize > Device Dashboards in the classic user interface only) displays a list of dashboards that can be displayed for a device on the Device Summary page. From the Device Dashboards page, you can create, edit, delete, and align device dashboards.
The Device Dashboards page (System > Customize > Device Dashboards in the classic Skylar One user interface only) displays a list of existing device dashboards. These dashboards include predefined device dashboards (which are installed with Skylar One or can be installed with a PowerPack) and any user-defined device dashboards.
For each device dashboard, the Device Dashboards page displays the following information:
  • Device Dashboard Name. Name of the device dashboard.
  • ID. Unique ID that Skylar One automatically assigns to each device dashboard.
  • Global Default. Specifies whether the device dashboard is the default device dashboard for all devices.
  • Categories. Specifies the number of device categories aligned with the device dashboard.
  • Classes. Specifies the number of device classes aligned with the device dashboard.
  • Devices. Specifies the number of devices that have been manually aligned with the device dashboard.
  • Dynamic Apps. Specifies the number of Dynamic Applications that are aligned with the device dashboard.
  • Edited By. ScienceLogic user who created or last edited the device dashboard.
  • Last Edited. Date and time the device dashboard was created or last edited.
By default, the cursor starts in the first filter field. You can press the Tab key or use your mouse to move through the fields.
Creating a Device Dashboard
To create a device dashboard:
  1. Go to the Device Dashboards page (System > Customize > Device Dashboards).
  2. On the Device Dashboards page, click the Create button. The Device Dashboard Editor page appears.
  • Device. Select a device to provide sample data while you create the dashboard. This device does not stay associated with the dashboard.
  • Adding Widgets. To add a widget, go to the big pane below the Device field. Left-click and drag with your mouse to draw a rectangle. This shape determines the initial size and position of the widget in your dashboard. When the Widget Configuration page appears, configure the widget as you would for a dashboard.
For maximum flexibility, when configuring a device-specific widget, ScienceLogic recommends that you select Contextual Device (Auto) in the Element field.
For more information on configuring widgets, see the section on Classic Dashboards.
  1. The new device dashboard saves automatically.
Aligning Device Dashboards
The device dashboard that is defined as the "Global Default" is the default dashboard that appears on the Device Summary page for each device.
Skylar One decides what to display on the Device Summary page as follows:
  • If the device is manually aligned with a device dashboard (on the Device Properties page), that dashboard appears on the Device Summary page for the device.
  • If the device is not manually aligned with a device dashboard, the device dashboard that is aligned with the Device Class is displayed.
  • If the device class is not aligned with a device dashboard, the device dashboard that is aligned with the Device Category is displayed.
  • If the device category is not aligned with a device dashboard, the device dashboard that is defined as the "Global Default" is displayed.
If the Prefer Global Device Summary Dashboard Over Category/Class checkbox is selected on the Behavior Settings page (System > Settings > Behavior) and a device is not manually aligned with a device dashboard, the dashboard that is defined as the "Global Default" is displayed.
Although you can align a device dashboard with a Dynamic Application, the device dashboards that are aligned with Dynamic Applications never appear on the Device Summary page as the default display. However, from the Device Summary page, you can select and view any device dashboards that are aligned with Dynamic Applications for the device.
You can manually align a device dashboard with a device. The device dashboard then appears as the default view on the Device Summary page.
From the Device Summary page, you can select and view any device dashboards that are associated with the device, its device class, its device category, its Dynamic Applications, and the Global Default.
  2. Find the device you want to align with a device dashboard. Click the wrench icon (wrench icon) for that device.
  3. On the Device Properties page, edit the Dashboard field to select a device dashboard. The selected device dashboard appears by default on the Device Summary page for this device.
  4. Click the Save button.
You can manually align a device dashboard with a device class. For devices that do not have a device dashboard defined on the Device Properties page, the device dashboard associated with the device class appears as the default view on the Device Summary page.
From the Device Summary page, the user can select and view any device dashboards that are associated with the device, the device's device class, the device's device category, the device's Dynamic Applications, and the Global Default.
  2. In the Device Class Register pane, find the device class you want to align with a device dashboard. Click the wrench icon (wrench icon) for that device class.
  3. On the Device Class Editor page, edit the Dashboard field to select a device dashboard. The selected device dashboard is associated with all devices that use this device class and appears as an option on the Device Summary page.
If a PowerPack updates one or more device classes, Skylar One does not overwrite the alignment between device dashboards and any updated device classes.
Aligning a Device Dashboard with a Device Category
You can manually align a device dashboard with a device category. For devices that do not have a device dashboard defined on the Device Properties page or a device dashboard defined on the Device Class Editor page, the device dashboard associated with the device category appears as the default view on the Device Summary page.
  1. Go to the Device Category Editor page (System > Customize > Device Categories).
  2. In the Register pane, find the device category you want to align with a device dashboard. Click the wrench icon (wrench icon) for that device category.
  3. In the Editor pane, edit the Device Dashboard field to select a device dashboard. The selected device dashboard is associated with all devices that use this device category and appears as an option on the Device Summary page.
If a PowerPack updates one or more device categories, Skylar One does not overwrite the alignment between device dashboards and any updated device categories.
Aligning a Device Dashboard with a Dynamic Application
You can manually align a device dashboard with a Dynamic Application. For each device that subscribes to the Dynamic Application, the aligned device dashboard appears as an option on the Device Summary page.
  2. Find the Dynamic Application you want to align with a device dashboard. Click the wrench icon (wrench icon) for that Dynamic Application.
  3. On the Dynamic Applications Properties Editor page, edit the Device Dashboard field to select a device dashboard. The selected device dashboard will be associated with all devices that subscribe to this Dynamic Application and appears as an option on the Device Summary page.
If a PowerPack updates one or more Dynamic Applications, Skylar One does not overwrite the alignment between device dashboards and any updated Dynamic Applications.
Editing a Device Dashboard
To edit a device dashboard:
  2. On the Device Dashboards page, find the device dashboard you want to edit. Click its wrench icon (wrench icon).
  3. The Device Dashboard Editor page appears. Edit one or more fields and/or the dashboard widgets.
  4. Skylar One automatically saves your changes.
Deleting a Device Dashboard
  2. On the Device Dashboards page, select the checkbox for each dashboard you want to delete.
  3. In the Select Action drop-down list, select Delete Dashboards.
  4. Click the Go button. The selected device dashboards no longer appear on this page and are no longer accessible on the Device Summary page.
You cannot delete a device dashboard that is defined as the Global Default.
Copying a Device Dashboard
  2. On the Device Dashboards page, select the checkbox for each dashboard you want to copy.
  3. In the Select Action drop-down list, select Copy Dashboards.
  4. Click the Go button. One or more new device dashboards appear on this page with names that start with "Copy of".
  2. On the Device Dashboards page, select the checkbox for the dashboard you want to define as the Global Default.
  3. In the Select Action drop-down list, select Set Global Default Device Dashboard.
  4. Click the Go button. In the Global Default field for the selected device dashboard, the value "Yes" appears.
Unaligning a Device Dashboard
If you no longer want a device dashboard to appear as an option on the Device Summary page for any devices, you can remove all alignments for that device dashboard. To unalign a device dashboard:
  2. On the Device Dashboards page, select the checkbox for the dashboard you want to remove from the Device Summary page.
  3. In the Select Action drop-down list, select Unalign Device Dashboard(s).
  5. The selected dashboards are no longer aligned with device categories, device classes, devices, or Dynamic Applications. The selected dashboards no longer appear as an option on the Device Summary page for any devices.
You can move all alignments from one device dashboard to another. The source device dashboard then has no alignments. To move alignments from one device dashboard to another:
  2. On the Device Dashboards page, select the checkbox for the dashboard that you want to receive the alignments.
  3. In the Select Action drop-down list, select Replace Dashboard Alignments with and then select the device dashboard that you want to move alignments from.
  5. The Device Dashboards page shows that the alignments have been removed from the device dashboard that you chose in the Select Action drop-down list. On the Device Dashboards page, the device dashboard for which you selected the checkbox now displays all the alignments that you moved from the other device dashboard.
