What is Scheduled Maintenance?
Scheduled maintenance is a date and time when a device enters maintenance mode. During maintenance mode, for the selected devices Skylar One generates only events with a severity less than the system-wide Maintenance Minimum Severity setting. By default, no events are generated during maintenance. You can choose to enable or disable polling during maintenance mode. Even if polling is enabled, Skylar One collects information from the selected devices but does not generate applicable events for the devices.
Skylar One includes tools that you can use to view, edit, and define scheduled maintenance for one or more devices. On the Schedule Manager page, you can schedule one-time and recurring maintenance tasks and downtime for a device. You can use the scheduled maintenance to:
- Specify a recurring downtime for routine maintenance (such as a database backup that occurs weekly every Tuesday at 3 AM).
- Specify a monthly schedule based on day of the week (such as a backup that occurs every third Sunday of the month at 11 PM).
- Specify one-time downtime (such as a specific day for upgrading software or hardware).
When a device is in maintenance, Skylar One generates only events with a severity less than the system-wide Maintenance Minimum Severity setting. By default, no events are generated during maintenance. You can choose to enable or disable polling during maintenance mode. Even if polling is enabled during maintenance, Skylar One collects information from the device but does not generate applicable events for the device.
You can specify a patch window within the larger maintenance period. A patch window allows Skylar One to limit event suppression to a short time frame within the larger maintenance window. For example:
Suppose you have to patch a server that Skylar One monitors. You plan to perform this task sometime between midnight and 6:00 AM. The actual patch process requires only 15 minutes of downtime for the server. In Skylar One, you define a maintenance window of 24:00 - 6:00 and a patch window of 15 minutes.
- At 24:00, Skylar One generates an event saying that the server is going into maintenance mode. Because you have defined a patch window, Skylar One continues to monitor this server as normal.
- At 3:00, you apply the patch to the server. The server reboots, and Skylar One generates an event saying that the server is offline. This first event within the larger maintenance window triggers the start of the patch maintenance window.
- Skylar One suppresses the event that triggered the patch maintenance window and instead generates an event "Patch Maintenance Window Opened".
- For the next 15 minutes, Skylar One suppresses all events for the device.
- At 3:15, Skylar One will generate an event for "Patch Maintenance Window Closed". This event clears the previous event "Patch Maintenance Window Opened".
- Skylar One will now generate events for the device, even though the maintenance window extends until 6:00.
If you apply the patch at 5:50, the server reboots, and Skylar One generates an event that the server is offline, the system suppresses events only until the maintenance window ends at 6:00, even though the patch window is 15 minutes.
If you disable an active maintenance schedule, the device leaves maintenance mode. If you re-enable the schedule during the scheduled time window, the device returns to maintenance mode.
What is User Maintenance?
User maintenance is an option that you use to manually put a device into maintenance mode. During maintenance mode, for the selected devices Skylar One will generate only events with a severity less than the system-wide Maintenance Minimum Severity setting. By default, no events are generated during maintenance. You can choose to enable or disable polling during maintenance mode. Even if polling is enabled, Skylar One will collect information from the selected devices but will not generate applicable events for the devices.
User maintenance mode is not scheduled. To put a device into this mode, you must manually enable user maintenance. To take the device out of this mode, you must manually disable user maintenance. User maintenance mode overrides scheduled maintenance for a device.
You can enable and disable user maintenance in the user interface or through the API. For more information, ask your ScienceLogic contact for access to the ScienceLogic API documentation.
The Maintenance Minimum Severity Setting
The global Maintenance Minimum Severity setting specifies the minimum severity required for an event to be suppressed during device maintenance and user maintenance. The default value is Healthy, which causes all events to be suppressed. To change this setting:
- On the Behavior Settings page, select a value in the Maintenance Minimum Severity drop-down list. The choices are Healthy, Notice, Minor, Major, or Critical.
- Click the button. Events with a severity lower than the severity you chose are now generated for all devices in scheduled maintenance mode and user maintenance mode.
Enabling and Disabling User Maintenance for a Single Device
You can enable and disable user maintenance mode on the Device Properties page.
To enable or disable user maintenance mode for a device:
- On the Device Manager page, find the device for which you want to enable or disable user maintenance. Click its wrench icon (
). The Device Properties page appears. - On the Device Properties page, edit the following fields:
- User Maintenance. Specifies whether the device is in user maintenance mode. During maintenance mode, for the selected devices Skylar One will generate only events with a severity less than the system-wide Maintenance Minimum Severity setting. By default, no events are generated during maintenance. You can choose to enable or disable polling during maintenance mode. Even if polling is enabled, Skylar One will collect information from the selected devices but will not generate applicable events for the devices. Choices are:
- Enabled. The device enters user maintenance mode. The device remains in this state until you or another user disables user maintenance mode.
- Disabled. User maintenance mode is disabled for this device.
- User Maintenance Collection. The drop-down list to the right of the User Maintenance field specifies whether Skylar One polls the device during user maintenance mode. Choices are:
- Enabled. The system polls the device during user maintenance mode.
- Disabled. The system does not poll the device during user maintenance mode.
Enabling and Disabling User Maintenance for One or More Devices
The Device Manager page contains a drop-down field in the lower right called Select Action. Use this field to apply an action to multiple devices at once. From the Select Action menu, you can enable or disable user maintenance mode for multiple devices simultaneously.
To enable or disable user maintenance mode for multiple devices:
- On the Device Manager page, select the checkbox for each device to which you want to apply the action. To select all checkboxes for all devices, select the checkbox at the top of the page.
- In the Select Action drop-down list, select one of the following:
- Change User Maintenance Mode: Enabled with Collection. This option puts the selected devices into user maintenance mode with collection enabled. The devices will remain in this state until you or another user disables user maintenance mode.
- Change User Maintenance Mode: Enabled without Collection. This option puts the selected devices into user maintenance mode with collection disabled. The devices will remain in this state until you or another user disables user maintenance mode.
- Change User Maintenance Mode: Disabled. This option disables user maintenance mode for the selected devices.
- The changes are applied to each selected device.
Scheduling Maintenance for a Single Device
You can schedule maintenance and downtime for a device on the tab of the Device Investigator (or on the Schedule Manager page in the Device Administration panel in the classic Skylar One user interface).
You can also view and manage all scheduled processes from the Schedule Manager page (Registry > Schedules > Schedule Manager). For more information, see the
Viewing the Schedule Manager
The tab of the Device Investigator (or the Schedule Manager page in the Device Administration panel in the classic Skylar One user interface) displays the following information about each scheduled or recurring device maintenance window:
- Event ID. Displays a unique, numeric ID for the scheduled process. Skylar One automatically creates this ID for each scheduled process.
- sch id. Displays a unique, numeric ID for the schedule. Skylar One automatically creates this ID for each schedule.
- Context. Displays the area of Skylar One on which the schedule works.
- Duration. Displays the duration of the scheduled process, in minutes.
To edit a scheduled or recurring device maintenance window, click its wrench icon (
) and update the settings as needed on the Schedule Editor modal. (For more information, see the section Defining a Scheduled or Recurring Device Maintenance Window for a Single Device.
You can schedule a device maintenance window in Skylar One from the tab of the Device Investigator (or the Schedule Manager page in the Device Administration panel in the classic Skylar One user interface). Skylar One automatically sets the status of the device to "maintenance" at the scheduled time.
To define a scheduled or recurring device maintenance window:
- Go to the tab of the Device Investigator. (Alternatively, in the classic Skylar One user interface, go to the Schedule Manager page (Devices > Classic Devices > wrench icon > Schedule, or Registry > Devices > Device Manager > wrench icon > Schedule in the classic user interface)).
- Click . The Schedule Editor modal appears.
- On the Schedule Editor modal, enter values in the following fields:
Basic Settings
- Schedule Name. Enter a name for the scheduled process.
- Preserve Schedule. Select this checkbox to keep the system from pruning this schedule after it expires.
- Description. Enter a description of the scheduled process.
Time Settings
If you want Skylar One to automatically adjust for daylight savings time (if applicable), then you must select a named region (such as America/New York) in the Time Zone field. If you select a specific time zone (such as EST) or a specific time offset (such as GMT-5), then Skylar One does not automatically adjust for daylight saving time. In addition, if you select a specific time zone, such as EST, that does not exist during daylight saving time, the system saves your schedules but runs them at unexpected times.
- Every Xth day of the Week. The scheduled process occurs at a monthly interval based on a day of the week. The day of the week displayed in this option matches the day selected in the Start Time field. For example, if you set the Start Time to Thursday, August 5th and that day is the first Thursday of the month, then the recurrence option will be Every 1st Thursday, and the scheduled process will occur monthly on the first Thursday of the month.
- If you specify "3 Months" the scheduled process recurs every three months, on the same day of the month as the Start Time.
Action Settings
- Collection Polling. Specifies whether Skylar One performs collection on the device during the scheduled maintenance. Choices are:
Enabled. During scheduled maintenance, Skylar One collects data from the device but does not trigger events for the device.
Disabled. During scheduled maintenance, Skylar One does not collect data from the device and does not trigger events for the device.
- Patch Window. You can specify a patch window within the larger maintenance period. A patch window allows Skylar One to limit the suppression of events to a short time frame within the larger maintenance window. Your choices are:
- None
Suppose you have to apply a patch to a server that is monitored by Skylar One. Suppose you know you will perform this task sometime between midnight and 6:00 AM. Suppose you know that the actual patch process requires only 15 minutes of downtime for the server. In Skylar One, you would define a maintenance window of 24:00 - 6:00 and a patch window of 15 minutes. In this scenario:
- At 3:00, you apply the patch to the server. The server reboots, and Skylar One generates an event saying that the server is offline. The first event that both matches or exceeds the Patch Maintenance Minimum Severity on the Behavior Settings page (System > Settings > Behavior) and occurs within the larger maintenance window triggers the start of the patch window.
If the patch was applied at 5:50, the server was rebooted, and Skylar One generated an event saying that the server is offline, events would be suppressed only until the end of the maintenance window, 6:00, even though the patch window is 15 minutes.
Scheduling Maintenance for One or More Devices
The Device Manager page contains a drop-down field in the lower right called Select Action. Use this field to apply an action to multiple devices at once. From the Select Action menu, you can schedule maintenance for multiple devices, simultaneously.
To schedule maintenance for multiple devices:
- On the Device Manager page, select the checkbox for each device for which you want to schedule maintenance. To select all checkboxes for all devices, select the checkbox at the top of the page.
- In the Select Action drop-down list, select Schedule Maintenance, and then click . The Schedule Editor modal appears.
- To schedule maintenance for the selected devices, follow the steps in the section on Defining a Scheduled or Recurring Device Maintenance Window for a Single Device. The system applies the values you supply in the Schedule Editor modal are applied to each selected device.
Enabling or Disabling Scheduled Maintenance for One or More Devices
You can enable or disable one or more scheduled or recurring device maintenance windows from the tab of the Device Investigator (or the Schedule Manager page in the Device Administration panel in the classic Skylar One user interface).
To enable or disable device maintenance windows:
- Select the checkbox for each scheduled process you want to enable or disable.
- Click the Select Action menu and select Enable Schedules or Disable Schedules.
Deleting Scheduled Maintenance for One or More Devices
You can delete one or more scheduled or recurring device maintenance windows from the tab of the Device Investigator (or the Schedule Manager page in the Device Administration panel in the classic Skylar One user interface).
To delete maintenance windows:
- Select the checkbox for each scheduled process you want to delete.
- Click the Select Action menu and select Delete Schedules.
