Device Toolbox
This section describes the Device Toolbox page in Skylar One.
What is the Device Toolbox?
On the Device Toolbox page, you can access common network tools. The list of tools available depends upon the type of device and the configuration of the device. From this page, you can also run diagnostics on a device and access the device without leaving it.
Accessing the Device Toolbox page
To access the Device Toolbox page:
  2. On the Device Manager page, find the device for which you want to access the Device Toolbox page and click its wrench icon (wrench icon).
  3. In the Device Administration panel, click the Toolbox tab.
  1. Depending on the device, the Device Toolbox page can display one or more of the following buttons. These tools run on the Data Collector that is currently monitoring the device unless otherwise noted:
  • FTP. Opens a new browser window and attempts to make an FTP connection to the current device. You start this tool from your computer. It does not run on a Data Collector. This tool appears only if the correct port (port 21) is detected as open by Skylar One.
  • SSH. Opens an SSH session on the device. You start this tool from your computer. It does not run on a Data Collector. This tool appears only if the correct port (port 22) is detected as open by Skylar One.
  • The SSH tool is not available for Skylar One systems that are configured as military unique systems.
  • Telnet. Opens a browser session or terminal session using the IP address of the current device and prompts you for the telnet username and password. You start this tool from your computer. It does not run on a Data Collector. This tool appears only if the correct port (port 23) is detected as open by Skylar One.
  • Terminal. Opens the Terminal Services Client Web Connection modal, where you can enter the login information for the terminal services session. You start this tool from your computer. It does not run on a Data Collector. This tool appears only if the correct port (port 3389) is detected as open by Skylar One.
  • Web. Opens a new browser window and attempts to make an http connection to the current device. You start this tool from your computer. It does not run on a Data Collector.
  • Secure Web. Opens a new browser window and attempts to make an HTTPS connection to the current device. You start this tool from your computer. It does not run on a Data Collector. This tool appears only if the correct port (port 443) is detected as open by Skylar One.
  • SNMP Walker. Opens the SNMP Walker modal, where you can perform an SNMP walk on the device. If the device has an IPv6 address, Skylar One uses the appropriate IPv6 SNMP command.
  • Port Scan. Leads to the Port Scan modal, where you can view a list of all open ports on the device at the time of the scan.
  • Deep Port Scan. Leads to the Deep Port Scan modal, where you can view a list of all open ports and view as much detail about each open port as the deep port scanner can retrieve.
  • Traceroute. Leads to the Traceroute modal, where you can view the network route between Skylar One and the device. If the device has an IPv6 address, Skylar One uses the appropriate IPv6 traceroute command. When running a traceroute, you can select whether it uses Internet Control Message Protocol (ICMP) or User Datagram Protocol (UDP).
  • Ping Tool. Leads to the Ping_Tool modal, where you can view the statistics returned by the ping tool. The ping tool sends a packet to the device's IP address (the one used by Skylar One to communicate with the device) and waits for a reply. Skylar One then displays the number of seconds it took to receive a reply from the device and the number of bytes returned from the device. If the device has an IPv6 address, Skylar One uses the appropriate IPv6 ping command.
  • Forward DIG. Leads to the Forward DIG modal, where you can view the output from the DIG utility. This tool automatically finds all available DNS information about the domain associated with the current device.
  • Reverse DIG. Leads to the Reverse DIG modal, where you can view the output from the reverse DIG utility. The reverse DIG tool retrieves the domain name that is associated with the device's IP.
  • ARIN Whois. Leads to the ARIN Whois modal, where you can view the output from the Whois utility. The Whois utility displays information about the device's IP, including the organization that registered the IP and contacts within that organization.
  • ARP Lookup. Leads to the ARP Lookup modal, where you can view the results from the ARP Lookup tool. The ARP Lookup tool displays a list of IP addresses for the device and the resolved Ethernet or Token Ring physical addresses (MAC addresses) for each IP address.
  • ARP Ping. Leads to the ARP Ping modal, where you can view the results from the ARP Ping tool. The ARP Ping tool is similar in function to ping, but it operates using ARP instead of ICMP. You can use the ARP Ping tool only on the local network.
  • SNMP Dump. Leads to the SNMP Dump modal, where you can view the results of the SNMP Dump. The SNMP Dump tool retrieves each OID and its corresponding value from the device.
  • Web Policy. Leads to the Web Policy modal, where you can manually run a web-content policy on the device. You start this tool from your computer. It does not run on the collector. This tool appears only if a Web Content Monitoring Policy has been configured for the device.
Viewing the Session Logs
After you run a tool on the Device Toolbox page, information about the session appears in the Toolbox Sessions Logs pane (at the bottom of the page).
For each session, you can view the following:
  • Device. Device associated with the session.
  • IP Address. IP address that was polled by the session.
  • Tool. Tool that was run.
  • Run Date. Date the session occurred.
  • Run User. User who initiated the session.
  • Session ID. Unique numeric identifier automatically assigned to the session by Skylar One.
From the Toolbox Sessions Logs pane, you can also:
  • View an SNMP Walk Session ().
  • View raw data from the session ().
  • Export raw data from the session to a file on the local computer ().
  • Delete a session from the Toolbox Sessions Logs pane ().
