CyberArk
CyberArk is not provided with Skylar One. You must purchase and manage the CyberArk Vault independently.
Skylar One can source credential data from external CyberArk vaults using a credential gateway service (CGS). This service allows you to download the CyberArk Credential Provider—sometimes referred to as the CyberArk Credential Agent—from your instance of CyberArk and install the agent on Skylar One Data Collectors. This agent syncs with credentials on the CyberArk vault server and uses those credentials to collect data from Skylar One-monitored devices when necessary. When a Skylar One system has been set up with the CyberArk Agent and the CGS, you can enter vault tags in any secret/encrypted credential field in Skylar One instead of entering the password or secret value itself.
CyberArk credentials are stored in the memory of the CyberArk Agent, not in Skylar One Data Collectors.
Installing the CyberArk Credential Agent on Every Collector
Install the CyberArk Credential Provider (Agent) by following the instructions outlined in CyberArk’s knowledge base article: Install the Credential Provider.
The CyberArk Agent must be installed on your Skylar One Data Collectors. These appliances retrieve credential data from the CyberArk vaults.
Reinstalling the CyberArk Credential Agent on a Rebuilt Data Collector
In cases where you need to rebuild your Data Collector, you will first need to remove the previous Data Collector from the CyberArk Credential Agent. After rebuilding the Data Collector, you will then need to reinstall the agent on that rebuilt appliance.
To reinstall the agent, follow the steps outlined in CyberArk's knowledge base article: Install the Credential Provider.
Defining a Custom CyberArk Delimiter
You can define a custom CyberArk delimiter when sourcing credential data from external CyberArk vaults. If you want to use a custom CyberArk delimiter, you must do so before starting the Credential Gateway Service:
Use the SSH protocol to connect to the Data Collector.
Enter the following commands
systemctl edit cgs
Add the following to the opened file, changing the '!' character if you wish to use a different delimiter:
[Service]
Environment="CYBERARK_DELIMITER='!'"
Save and exit the cgs file.
Starting the Credential Gateway Service on Every Data Collector
The Credential Gateway Service is the method Skylar One uses to interact with the CyberArk Credential Provider (Agent). You must complete the following steps for every Data Collector you are utilizing:
Enter the following command:
sudo systemctl start cgs
Check the status of the service by entering the following command and making sure it is listed as "active (running)":
sudo systemctl status cgs
Troubleshooting Credential Gateway Service Issues
If you are encountering Credential Gateway Service errors, perform the following actions:
Check sudo systemctl status cgs and sudo journalctl -u cgs for errors related to the cgs process or its runtime environment.
Check /var/log/sl1/cgs-error.log for additional error information and search for troubleshooting guidance.
Setting Up Vault Tags in Your Credential
When a Skylar One system has been set up with the CyberArk Credential Provider (Agent) and the Skylar One Credential Gateway service, you can enter vault tags in any secret/encrypted credential field instead of entering the password/secret itself. Any time you use the credential in discovery or collections, Skylar One will detect the vault tag, use the provided query string to retrieve a secret from the CyberArk credential provider, and then use it in this field.
You can set up vault tags only in the classic Skylar One user interface.
- Click the button and then select the type of credential you want to create. The Credential Editor modal appears.
- If there's a secret/encrypted credential field, enter the appropriate vault tag instead of entering the password/secret itself.
The vault tag entered should be in the following format: <vault id>:<appid>;<safe>;<object>
For example, a query string for an SNMP Credential might appear as the following: vault:123:appid=testappid;safe=Test;object=snmp_v2.
For CyberArk, the query string contains the following parameters:
- appid. The ID of the application registered in the CyberArk vault for Skylar One.
- safe. The ID of the safe in which the object resides.
- object. The ID of the object that holds the secret/encrypted data.
These parameters must be lowercase in the vault tag.
The vault ID value indicates which CyberArk vault Skylar One should check first for the credential information. For Skylar One 12.1.0, any numeric value can be entered for the vault ID.
Example: Vault Tags
In this example, any time the EM7 Default V2 Tag credential is used in the Profile Name field, Skylar One will retrieve the secret from the object snmp_v2 contained in the Test safe as application testappid, from the CyberArk credential provider. Then, this secret will be used for the SNMP Community (Read-Only) field value.
