Upgrading Skylar One Extended Architecture
This section provides detailed steps for performing an upgrade on the Skylar One Extended Architecture.
New installations of Skylar One Extended Architecture are available only on SaaS deployments.
Workflow
The following sections describe the steps to plan and deploy a Skylar One update.
If would like assistance planning an upgrade path that minimizes downtime, contact your Customer Success Manager.
The workflow for upgrading Skylar One is:
  1. Plan the update.
  3. Review pre-upgrade best practices for Skylar One.
  4. Back up SSL certificates.
  5. Set the timeout for PhoneHome Watchdog.
  6. Adjust the timeout for slow connections.
  7. Run the system status script on the Database Server or All-In-One before upgrading.
  8. Upgrade the Extended Architecture.
  9. Upgrade the Skylar One Distributed Architecture using the System Update tool (System > Tools > Updates).
  10. Remove Skylar One appliances from maintenance mode.
  11. Upgrade MariaDB, if needed.
  12. Reboot Skylar One appliances, if needed.
  13. Restore SSL certificates.
  14. Reset the timeout for PhoneHome Watchdog.
  15. Update the default PowerPacks.
  16. Configure Subscription Billing (one time only). For details, see the section on Subscription Billing.
For details on all steps in this list except step 10, see the section on Upgrading Skylar One.
Prerequisites
  • ScienceLogic recommends that for production systems, each Compute Cluster contains six (6) Compute Nodes. Lab systems can continue to use Compute  Clusters that include only three (3) Compute Nodes.
  • The Storage Cluster requires a (possibly additional) node to act as the Storage Manager.
  • Perform the installation steps in the Installation manual to install these additional nodes (for the Computer Cluster and the Storage Cluster) before upgrading your existing nodes.
  • Ensure that all nodes in the Skylar One Extended Architecture can access the internet.
  • You must use the same password for the em7admin account during ISO installation of the Database Server and ISO installation of the appliances in the Skylar One Extended Architecture.
To perform the upgrade, you must have a ScienceLogic customer account that allows you access to the Harbor repository page on the ScienceLogic Support Site. To verify your access, go to https://registry.scilo.tools/harbor/. For more information about obtaining Harbor login credentials, contact your Customer Success Manager.
Resizing the Disks on the Compute Node
The Kafka Messaging service requires additional disk space on each Compute Node. Before upgrading, ensure that each disk on each existing Compute Node in the Compute Node cluster is at least 350 GB.
If each disk on each existing Compute Node is not at least 350 GB, perform the following steps on each Compute Node:
  1. Resize the hard disk via your hypervisor to at least 350 GB.
  2. Note the name of the disk that you expanded in your hypervisor.
  3. Power on the virtual machine.
  4. Either go to the console of the Compute Node or use SSH to access the Compute Node.
  5. Open a shell session on the server.
  6. Log in with the system password for the Compute Node.
  7. At the shell prompt, enter:
  8. sudo lsblk | grep <disk_size>
    disk_size is your hard disk size from step #1.
  9. Note the name of the disk that you expanded in your hypervisor.
  10. At the shell prompt, enter:
  11. sudo fdisk /dev/<disk_name>
    disk_name is the name of the disk you want to expand.
  12. Enter p to print the partition table.
  13. Enter n to add a new partition.
  14. Enter p to make the new partition the primary partition.
  15. Select the default values for partition number, first sector, and last sector.
  16. Enter w to save these changes
  17. Restart the VM.
  18. At the shell prompt, enter:
  19. sudo fdisk -l
  20. Notice that now another partition is present.
  21. To initialize the new partition as a physical volume, enter the following at the shell prompt:
  22. sudo pvcreate <partition_name>
  23. To add the physical volume to the existing volume group, enter the following at the shell prompt:
  24. sudo vgextend em7vg <partition_name>
  25. To verify and confirm that the volume group has grown to the expected size, enter the following at the shell prompt:
  26. sudo vgdisplay | grep "VG Size"
Installing ORAS
If you have not already installed OCI Registry as Storage (ORAS), you will need to do so before you can upgrade the Skylar One Extended Architecture.
To do so:
  1. Use SSH to access the Management Node. Open a shell session on the server. Log in with the System Password you defined in the ISO menu.
  2. In the Management Node, navigate to the sl1x-deploy directory. To do this, enter the following at the shell prompt:
  3. cd sl1x-deploy
  4. Run the following commands:
  5. sudo su
    curl -LO https://github.com/oras-project/oras/releases/download/v0.12.0/oras_0.12.0_linux_amd64.tar.gz
    mkdir -p oras-install/
    tar -zxf oras_0.12.0_*.tar.gz -C oras-install/
    mv oras-install/oras /usr/bin/
    rm -rf oras_0.12.0_*.tar.gz oras-install/
    exit
Obtaining Your Harbor Credentials
You will need to know your Harbor username and CLI secret when you upgrade the Skylar One Extended Architecture. To obtain these credentials:
  1. Log in to Harbor at: https://registry.scilo.tools/harbor/sign-in?redirect_url=%2Fharbor%2Fprojects
  2. Click Login via OIDC Provider.
  3. Click Customer Login.
  4. Log in with the username and credentials that you use to access the ScienceLogic Support site (https://support.sciencelogic.com).
  5. Click the username in the upper right and select User Profile.
  6. On the User Profile page:
    • Note the username.
    • Click the pages icon next to the CLI secret field to copy the CLI secret to cache.
  7. Exit the browser session.
Upgrading to 12.3.x or Later
Before upgrading to Skylar One 12.3.0 or later, you must already be running Skylar One on Oracle Linux 8 (OL8). If you are on a version of Skylar One prior to 12.2.0 and running on OL7, you must first upgrade to Skylar One 12.1.1 or 12.1.2 and then migrate to OL8 before you can upgrade to Skylar One 12.3.x. For an overview of potential upgrade paths and their required steps, see the appropriate 12.3.x Skylar One release notes.
To upgrade the Skylar One Extended Architecture to 12.3.x or later, follow these steps:
  1. Complete preupgrade steps.
  2. Disable Scylla.
  3. Upgrade the Skylar One Extended Architecture.
  4. Upgrade the Skylar One Distributed Architecture.
Step 1: Preupgrade
  1. If you have not already done so, you must install ORAS and obtain your Harbor credentials, which you will need for step 4.
  2. Use SSH to access the Management Node. Open a shell session on the server. Log in with the system password you defined in the ISO menu.
  3. In the Management Node, navigate to the sl1x-deploy directory. To do this, enter the following at the shell prompt:
    cd sl1x-deploy
  4. Log in to Harbor repository:
    oras login registry.scilo.tools/sciencelogic/
  5. Exit out of the sl1x-deploy directory and download the deployment files:
    cd /home/em7admin/
    oras pull registry.scilo.tools/sciencelogic/sl1x-deploy:12.x.x
    cd sl1x-deploy
  6. Copy the inventory template file to the sl1x-inv.yml file:
    cp sl1x-inv-template.yml sl1x-inv.yml
  7. Edit the sl1x-inv.yml file to match your Skylar One Extended system:
    vi sl1x-inv.yml
    Do not remove colons when editing this file.
    • Make sure that the sl1_version value is sl1_version: 12.x.x.
    • Supply values in all the fields that are applicable. For details on the sl1x-inv.yml file, see the manual Installing Skylar One Extended Architecture, which can be obtained by contacting ScienceLogic Support.
    • Save your changes and exit the file (:wq).
  8. Pull the Docker image that is referenced in the docker-compose file:
    docker-compose -f docker-compose.external.yml pull
Step 2: Disable the Scylla Cluster
To disable the Scylla cluster:
  2. Open a text editor for the sl1x-inv.yml file:
    vi /home/em7admin/sl1x-deploy/sl1x-inv.yml
  3. Edit the file to add the following additional variables:
    all:
    vars:
    install_aiml: false
    enableNonScyllaPipeline: true
    enableLegacyScyllaPipeline: false
  4. Run the following command to remove services that used the previous configuration:
    docker-compose -f docker-compose.external.yml run --rm deploy app-purge
  5. In the sl1x-inv.yml file, remove the Storage Node and Storage Manager IP addresses from the list. For example, you would remove the following lines:
    sn:
    hosts:
    vars:
    scylla_admin_username: em7admin
    scylla_admin_password: <Scylla password>
    sm:
    hosts:
    vars:
    scylla_manager_db_user: em7admin
    scylla_manager_db_password: <Scylla password>
  6. Save your changes and exit the file (:wq).
Step 3: Upgrade the Skylar One Extended Architecture
To upgrade the Skylar One extended architecture:
  2. To upgrade the Management Node services, run the following script:
    sudo bash package-update.sh
  3. To upgrade RKE and Kubernetes on the Compute Nodes, run the following command:
    docker-compose -f docker-compose.external.yml run --rm deploy cn
  4. To update the Skylar One Extended Architecture system services, run the following command:
Step 4: Upgrade the Skylar One Distributed Architecture
Update your classic Skylar One appliances. For more information, see the section on Updating Skylar One.
