Managing Dynamic Applications
This section will describe how to manage Dynamic Applications.
Viewing the List of Dynamic Applications
The Dynamic Applications Manager page (System > Manage > Dynamic Applications) displays a list of all existing Dynamic Applications. For each Dynamic Application, the page displays the following:
To sort the list of Dynamic Applications, click on a column heading. The list will be sorted by the column value, in ascending order. To sort by descending order, click the column heading again. The Last Edit column sorts by descending order on the first click; to sort by ascending order, click the column heading again.
  • Dynamic Application Name. Name of the Dynamic Application, as defined in the Dynamic Applications Properties Editor page.
  • Poll Rate. Frequency, in minutes, at which SL1 will poll all devices that use this Dynamic Application.
NOTE: The Poll Rate column displays the default poll frequency for the Dynamic Application, as defined in the Dynamic Applications Properties Editor page. You can define a custom poll frequency for one or more devices in a device template. The poll frequency defined in the device template overrides the poll frequency defined for the Dynamic Application. Devices to which the device template is applied will use the poll frequency defined in the device template.
  • Type. Type of Dynamic Application. The choices are:
  • Bulk Snippet Configuration. A single instance of the Dynamic Application uses custom-written Python code to collect static configuration data from multiple devices. This is useful for systems that include a large number of component devices. For details on creating bulk snippet Dynamic Applications, see the Snippet Dynamic Application Development section.
  • Bulk Snippet Performance. A single instance of the Dynamic Application uses custom-written Python code to collect trendable performance data from multiple devices. This is useful for systems that include a large number of component devices. For details on creating bulk snippet Dynamic Applications, see the Snippet Dynamic Application Development section.
  • Database Configuration. The Dynamic Application retrieves configuration data from a database application. The Dynamic Application uses SQL queries. The queried device returns table data. For details on creating database Dynamic Applications, see the Database Dynamic Application Development section.
  • Database Performance. The Dynamic Application retrieves trendable performance data from a database application. The Dynamic Application uses SQL queries. The queried device returns table data. For details on creating database Dynamic Applications, see the Database Dynamic Application Development section.
  • Internal Collection Inventory. The Internal Collection Inventory Dynamic Application (ICDA) retrieves configuration data about filesystems and interface. For filesystem, an ICDA Inventory can retrieve data such as storage size, filesystem type, and storage used. These ICDAs can also collect configuration data about interfaces, such as physical address, operational status, and IP addresses. For details on creating ICDAs, see the Internal Collection Dynamic Application Development section.
  • Internal Collection Performance. The Internal Collection Performance Dynamic Application (ICDA) retrieves data about availability and latency, device information (system description, system uptime, system locale), filesystem performance, and interface performance. For details on creating ICDAs, see the Internal Collection Dynamic Application Development section.
  • IT Service. A special type of Dynamic Application that SL1 uses to monitor IT Services. When you create and edit an IT Service in the IT Service Editor page, SL1 will automatically create and maintain a Dynamic Application for that IT Service. Dynamic Applications for IT Services will appear in the Dynamic Applications Manager page. However, if you want to edit the settings for an IT Service, you should not edit the Dynamic Application for that IT Service. Instead, use the IT Service Editor page to edit IT Services. For details on creating IT Service policies, see the IT Services section.
  • PowerShell Configuration. The Dynamic Application uses PowerShell commands to collect static configuration data from a Windows device. For details on creating PowerShell Dynamic Applications, see the Dynamic Application Development - WMI and PowerShell section. For information on configuring SL1 and external systems to use PowerShell Dynamic Applications, see the Monitoring Windows Systems with PowerShell and Monitoring Windows with WMI sections.
  • PowerShell Performance. The Dynamic Application uses PowerShell commands to collect trendable performance data from a Windows device. For details on creating PowerShell Dynamic Applications, see the Dynamic Application Development - WMI and PowerShell section. For information on configuring SL1 and external systems to use PowerShell Dynamic Applications, see the Monitoring Windows Systems with PowerShell and Monitoring Windows with WMI sections.
  • Snippet Configuration. The Dynamic Application uses custom-written Python code to collect configuration data from a device. For details on creating snippet Dynamic Applications, see the Snippet Dynamic Application Development section.
  • Snippet Journal. The Dynamic Application uses custom-written Python code to collect data formatted as log entries from a device. For details on creating snippet Dynamic Applications, see the Snippet Dynamic Application Development section.
  • Snippet Performance. The Dynamic Application uses custom-written Python code to collect trendable performance data from a device. For details on creating snippet Dynamic Applications, see the Snippet Dynamic Application Development section.
  • SNMP Configuration. The Dynamic Application uses SNMP to retrieve static, configuration data from devices or applications. For details on creating SNMP Dynamic Applications, see the SNMP Dynamic Application Development section.
  • SNMP Performance. The Dynamic Application uses SNMP to retrieve trendable performance data from devices or applications. For details on creating SNMP Dynamic Applications, see the SNMP Dynamic Application Development section.
  • SOAP Configuration. The Dynamic Application uses XML and SOAP to retrieve static configuration data from a SOAP server. The queried device returns XML data. For details on creating SOAP  Dynamic Applications, see the SOAP Dynamic Application Development section.
  • SOAP Performance. The Dynamic Application uses XML and SOAP to retrieve trendable performance data from a SOAP server. The queried device returns XML data. For details on creating SOAP  Dynamic Applications, see the SOAP Dynamic Application Development section.
  • WMI Configuration. The Dynamic Application retrieves configuration information from either WMI or WBEM running on a managed device. WMI Dynamic Applications use a query format to request data from a managed device. WBEM Dynamic Applications use wbemcli and HTTP to request data from a managed device. For details on creating WMI Dynamic Applications, see the Dynamic Application Development - WMI and PowerShell section. For information on configuring SL1 and external systems to use PowerShell Dynamic Applications, see the Monitoring Windows Systems with PowerShell and Monitoring Windows with WMI sections.
  • WMI Performance. The Dynamic Application retrieves trendable performance data from either WMI or WBEM running on a managed device. WMI Dynamic Applications use a query format to request data from a managed device. WBEM Dynamic Applications use wbemcli and HTTP to request data from a managed device.
  • XML Configuration. The Dynamic Application uses HTTP GET queries. The queried device returns static configuration data in XML format. For details on creating SOAP  Dynamic Applications, see the XML Dynamic Application Development section.
  • XML Performance. The Dynamic Application uses HTTP GET queries. The queried device returns trendable performance data in XML format. For details on creating SOAP  Dynamic Applications, see the XML Dynamic Application Development section.
  • XSLT Configuration. The Dynamic Application uses XML and SOAP to retrieve static configuration data from a SOAP server. The requests used to retrieve data are generated by performing an XSLT transformation on an XML document that contains data already collected by the Dynamic Application. The queried device returns XML data, which must be changed to a specific format by performing a second XSLT transformation. For details on creating SOAP  Dynamic Applications, see the XSLT Dynamic Application Development section.
  • XSLT Performance. The Dynamic Application uses XML and SOAP to retrieve trendable performance data from a SOAP server. The requests used to retrieve data are generated by performing an XSLT transformation on an XML document that contains data already collected by the Dynamic Application. The queried device returns XML data, which must be changed to a specific format by performing a second XSLT transformation. For details on creating SOAP  Dynamic Applications, see the XSLT Dynamic Application Development section.
  • State. Specifies whether the Dynamic Application is Enabled or Disabled.
  • Version. Version number to assign to the Dynamic Application. You can customize this value and increment it according to your change management policies.
  • ID. Unique application ID, assigned by SL1.
  • Subscribers. Number of devices on which the Dynamic Application is enabled to collect data. Clicking on the icon leads to the Application Subscribers modal, where you can view the list of devices and access other pages for each subscriber device. You can also access this page by selecting the wrench icon () for a Dynamic Application and selecting the Subscribers tab.
  • PowerPack. Specifies whether or not the Dynamic Application is included in a PowerPack.
  • Environment. The execution environment to which the Dynamic Application is aligned, if it is a snippet or internal collection Dynamic Application. If it is not a snippet or internal collection Dynamic Application, then this column displays "n/a".
  • Collects. Number of objects included in the Dynamic Application. Clicking on the icon () leads to the Collection Objects page, where you can view the list of collection objects and edit their properties.
  • Alerts. Number of custom alerts defined for the Dynamic Application. Clicking on the icon () leads to the Alert Objects page, where you can view and edit each alert defined for the Dynamic Application.
  • Events. Number of events associated with the Dynamic Application. Clicking on the icon () leads to the Event Policy Manager page, where you can view information about each event definition associated with the Dynamic Application definition and edit each event definition.
  • Thresh. Number of threshold objects defined for the Dynamic Application. Clicking on the icon () leads to the Threshold Objects page, where you can view and edit information about each threshold object defined for the Dynamic Application.
  • Edited By. Username of the person who created or last edited the Dynamic Application.
  • Last Edit. Date that the Dynamic Application was created or last edited.
Searching and Filtering the List of Dynamic Applications
  • Dynamic Application Name. You can enter text to match, including special characters, and the Dynamic Applications Manager page will display only Dynamic Applications that have a matching name.
  • Poll Rate. You can enter text to match, including special characters, and the Dynamic Applications Manager page will display only Dynamic Applications that have a matching polling rate.
  • Type. You can enter text to match, including special characters, , and the Dynamic Applications Manager page will display only Dynamic Applications that have a matching type.
  • State. You can enter text to match, including special characters, and the Dynamic Applications Manager page will display only Dynamic Applications that have a matching state.
  • Version. You can enter text to match, including special characters, and the Dynamic Applications Manager page will display only Dynamic Applications that have a matching version number.
  • ID. You can enter text to match, including special characters, and the Dynamic Applications Manager page will display only Dynamic Applications that have a matching ID number.
  • Subscribers. You can enter text to match, including special characters, and the Dynamic Applications Manager page will display only Dynamic Applications that have a matching number of subscribers.
  • PowerPack. You can enter text to match, including special characters, and the Dynamic Applications Manager page will display only Dynamic Applications that have a matching PowerPack.
  • Environment. You can enter text to match, including special characters, and the Dynamic Applications Manager page will display only Dynamic Applications that have a matching execution environment.
  • Collects. You can enter text to match, including special characters, and the Dynamic Applications Manager page will display only Dynamic Applications that have a matching number of collection objects.
  • Alerts. You can enter text to match, including special characters, and the Dynamic Applications Manager page will display only Dynamic Applications that have a matching number of alerts.
  • Events. You can enter text to match,including special characters, and the Dynamic Applications Manager page will display only Dynamic Applications that have a matching number of event policies.
  • Thresh. You can enter text to match, including special characters, and the Dynamic Applications Manager page will display only Dynamic Applications that have a matching number of thresholds.
  • Edited By. You can enter text to match, including special characters, and the Dynamic Applications Manager page will display only Dynamic Applications that were created or edited by a a matching user-name.
  • Last Edited. Only those Dynamic Applications that match all the previously selected fields and have the specified "last edited" date will be displayed. The choices are:
  • All. Display all Dynamic Applications that match the other filters.
  • Last Minute. Display only Dynamic Applications that have been modified within the last minute.
  • Last Hour. Display only Dynamic Applications that have been modified within the last hour.
  • Last Day. Display only Dynamic Applications that have been modified within the last day.
  • Last Week. Display only Dynamic Applications that have been modified within the last week.
  • Last Month. Display only Dynamic Applications that have been modified within the last month.
  • Last Year. Display only Dynamic Applications that have been modified within the last year.
Special Characters
String and Numeric
String
"!^" would match null values.
"!$" would match null values.
Numeric
Examples
  • "*". Matches all text.
Performing Other Tasks in the Dynamic Application Manager Page
From the Dynamic Applications Manager page, you can also perform the following tasks:
  • Manually perform dynamic discovery for a Dynamic Application. In the Dynamic Applications Manager page, find the Dynamic Application you want to use for network-wide discovery and select its lightning bolt icon ().
  • Filter the list by application. Selecting the Filter on this Application icon () sets the Dynamic Applications Manager page to display only Dynamic Applications with the same name as the selected Dynamic Application.
  • Change an application's type. To change the type of one or more Dynamic Applications, select the checkbox () of each Dynamic Application you want to change. In the Select Action drop-down menu in the bottom right, scroll to the Change Type section and select a new type. Select the Go button. Each selected Dynamic Application will now be assigned the new type.
  • Change polling interval. To change the polling interval for one or more Dynamic Application, select the checkbox () of each Dynamic Application you want to change. In the Select Action drop-down menu in the bottom right, select a new polling interval for the Dynamic Application. Select the Go button. Each selected Dynamic Application will now be assigned the new polling interval.
  • Delete an Application. To delete one or more Dynamic Applications, select the checkbox () of each Dynamic Application you want to change. In the Select Action drop-down menu in the bottom right, select DELETE Application, and then select the Go button. Each selected Dynamic Application will be deleted.
  • Clear Application Data. To clear all historical data, including logs and reports, associated with one or more Dynamic Application, select the checkbox () for each Dynamic Application you want to change. In the Select Action drop-down menu in the bottom right, select CLEAR Application, and then select the Go button. The historical data for each selected Dynamic Application will be deleted.
  • Enable an Application. Enables the selected Dynamic Applications so that SL1 can collect the data for those applications. In the Select Action drop-down menu in the bottom right, select ENABLE Application, and then select the Go button.
  • Disable an Application. Disables the selected Dynamic Applications. In the Select Action drop-down menu in the bottom right, select DISABLE Application, and then select the Go button.
  • Discover Applications using the Select Action drop-down menu. To start the Dynamic Application discovery process on all managed devices, select the checkbox () for each Dynamic Application you want to use in the discovery process. In the Select Action drop-down menu in the bottom right, select DISCOVER Applications. Select the Go button. SL1starts the Dynamic Application discovery process on all devices in SL1 using the selected Dynamic Applications.
  • Validate and Repair Applications. For each selected Dynamic Application, ensures that the Dynamic Application includes the objects, thresholds, and alerts that are referenced in the Dynamic Application and in other parts of SL1. Also ensures that if an event that is associated with the Dynamic Application has an auto-clear event, that auto-clear event is also associated with the Dynamic Application. This tool will troubleshoot and then fix the database tables that reference the Dynamic Application's objects, presentations, thresholds and alerts.
  • Align a Device Dashboard. To align one or more Dynamic Applications with a Device Dashboard, select the checkbox () for each Dynamic Application you want to align with the Device Dashboard. In the Select Action drop-down menu in the bottom right, scroll to the Change Device Dashboard section and select a Device Dashboard. Select the Go button. For each device that subscribes to the selected Dynamic Application, the selected device dashboard will appear as an entry in the Device Dashboard field in the Device Summary page.
  • Align an Execution Environment. To align one or more Dynamic Applications with an execution environment, select the checkbox () for each Dynamic Application you want to align with the environment. In the Select Action drop-down menu in the bottom right, scroll to the Align Collection Environment section and select an execution environment, and then click the Go button.
Viewing the Dynamic Applications Associated with a Device
You can view the Dynamic Applications associated with a device from the Dynamic Application Collections page. The Dynamic Application Collections page also allows you to associate another Dynamic Application with a device, assign a credential to a Dynamic Application, or perform other administrative tasks for an aligned Dynamic Application.
To view the Dynamic Applications associated with a device:
  • In the Device Manager page, find the device for which you want to view Dynamic Applications. Select its wrench icon ().
  • In the Device Administration panel, select the Collections tab.
  • The Dynamic Application Collections page displays a list of all Dynamic Applications aligned with the current device. For each Dynamic Application, the Dynamic Application Collections page displays the following read-only information:
  • Plus Sign (). Clicking on this icon displays a list of all Presentation Objects included in Dynamic Applications of type "Performance" and "Journal" or a list of all Collection Objects included in Dynamic Applications of type "Configuration". You can click on the plus sign next to each Presentation Object to see all the Collection Objects included in the Presentation Object.
  • Minus Sign (). Collapses a Dynamic Application and hides the display of Presentation Objects and Collection Objects.
  • Dynamic Application. Name of the Dynamic Application.
  • ID. Numeric ID for the Dynamic Application.
  • Poll Frequency. Frequency at which SL1 will query the device to retrieve the data specified in the Dynamic Application. Each Dynamic Application includes a default frequency. From this page (Dynamic Application Collections), you can change the poll frequency for a Dynamic Application on the current device. This edited poll frequency will override the default frequency for the Dynamic Application and the poll frequency defined for a Dynamic Application in one or more device templates.
  • Type. The protocol used by the Dynamic Application (Database [SQL], Internal Collection Inventory or Internal Collection Performance (ICDA), Snippet [Python], SNMP, SOAP, WMI, XML, or XSLT) and the type of data collected by the Dynamic Application (Configuration, Performance, or Journal).
  • Credential. Name of the credential that SL1 uses to access the device and retrieve the data specified in the Dynamic Application.
NOTE: Cache-consuming Dynamic Applications do not require a credential. If you aligned a cache-consuming Dynamic Application in the Dynamic Application Alignment modal page, the Credential field displays N/A and is grayed out. You do not have to select a credential in the Dynamic Application Alignment modal page.
  • Collector. Name of the specific Data Collector used to collect data from the Dynamic Application.
Based on the Dynamic Application's Collector Affinity settings, the Dynamic Application might be assigned to a different Data Collector than the Data Collector that is assigned to the device in the Device Properties page (Devices> Device Manager > wrench icon). In the Dynamic Application Collections page, hover your mouse over the Collector name for any of the Collection Objects to view a tooltip that explains why the Dynamic Application is assigned to its particular Data Collector. For more information about the Collector Affinity settings, see the Dynamic Application Settings section.
  • Run Dynamic Application (). Performs a test run of data collection for the selected Dynamic Application on the current device.
NOTE: If a device is currently unavailable, the lightning-bolt icon () will be grayed out for each Dynamic Application aligned with the device.
  • Checkbox (). Apply an action from the Select Action field to this instance of the Dynamic Application.
Viewing the Status of a Dynamic Application
For each device, SL1 maintains the collection status for each collection object in each Dynamic Application aligned with that device. The Dynamic Application Collections page displays the status of each collection object for a device as represented by two values: Found and Collect. The Dynamic Application Collections page also displays the Found and Collect values for each presentation object, which are derived from the status of each collection object used by the presentation object.
Found
The Found status for a collection object has two possible values:
  • Yes. Data has been successfully collected from this device for this object. Found is set to Yes the first time data is successfully collected from this device for this object.
  • No. Data has never been successfully collected from this device for this object. No is the initial value of Found for every object when a Dynamic Application is initially aligned with a device.
The Found status for a presentation object also has two possible values (Yes and No).
  • If the presentation object uses only one collection object, the presentation object always has the same default Found and default Collect values as that collection object.
  • If a presentation object uses multiple collection objects, the default Found value for the presentation object will be Yes only if all the collection objects used by the presentation object have a Found value of Yes.
After Found is set to Yes for an object, SL1 will never automatically change the value of Found for this object.
The value of Found is used by SL1 to determine whether icons, tabs, and Navbar links that lead to the Performance or Configs page where the collection object is used should be active.
Collect
The Collect status for a collection object has two possible values:
  • Yes. SL1 will attempt to collect data for this object when collection for this Dynamic Application occurs. Yes is the initial value for Collect for every object when a Dynamic Application is initially aligned with a device.
  • No. SL1 will not attempt to collect data for this object when collection for this Dynamic Application occurs. SL1 might set Collect to No automatically if no data has been collected.
  • If a collection object has a Collect value of No, all presentation objects that use that collection object will also have a Collect value of No.
For information about how SL1 determines the Collect status, see the section on How SL1 Manages the Collection Status for Dynamic Applications.
If you have the proper user permissions, you can enable or disable collection for certain collection objects. For more information, see the section on Enabling and Disabling Collection Objects.
The Collect status for a presentation object also has two possible values (Yes and No).
  • If a presentation object uses multiple collection objects, the default Collect value for the presentation object will be Yes only if all the collection objects used by the presentation object have a Collect value of Yes. If one or more collection objects used by the presentation object have a Collect value of No, the presentation object will also have a default Collect value of No.
  • The Collect status for a presentation object has no effect upon its collection objects. If you manually change the Collect status for a presentation object, the Collect status for the collection objects used by the presentation object will not change.
Before determining which collection objects defined in a Dynamic Application will be collected, SL1 determines whether the Dynamic Application itself should be collected. Dynamic Applications are not collected for devices that are unavailable (because of a failed availability check) or have collection disabled (either manually by a user or because of maintenance scheduled in SL1) regardless of the Collect value of the objects.
How SL1 Manages Collect Status
Stopping Collection
One of the ScienceLogic hourly maintenance tasks checks the last collection time for every collection object being collected from every device. If the last collection time for an object on a device is more than 24 hours ago, collection is stopped for that collection object on that device. SL1 will set the Collect status of that object to No.
NOTE: If a device is in maintenance mode, is unavailable, or has been manually disabled by a user, SL1 will not automatically set the Collect status of objects to No. SL1 will automatically set the Collect status of objects to No only if the device is up and running, but SL1 still cannot collect the object.
When SL1 sets the Collect status of that object to No, SL1 generates an event. The event will include the name of the device, the name of the Dynamic Application, the name of the collection object, and the collection object IDs. By default, this event is of severity "notice".
NOTE: For Dynamic Applications that have the Component Mapping checkbox selected in the Dynamic Applications Properties Editor page, SL1 will never automatically set the Collect status to No for any of the collection objects in the Dynamic Application.
NOTE: For Dynamic Applications that have the Caching fields set to either Cache Results or Consume cached results in the Dynamic Applications Properties Editor page, SL1 will never automatically set the Collect status to No for any of the collection objects in the Dynamic Application.
Starting Collection
For each object that has the Collect status of No, SL1 will attempt to re-collect the object once a day. If re-collection is successful, SL1 will automatically set the Collect value for that object to Yes.
NOTE: If a user manually sets the Collect status of a collection object or presentation object to No, SL1 will not attempt to re-collect the object once a day and will not set the Collect status to Yes.
Collection Objects that are Excluded from Maintenance
The Collect status of the following collection objects is never changed automatically:
  • Collection objects in Dynamic Applications that have the Component Mapping checkbox checked in the Dynamic Applications Properties Editor page.
  • Collection objects in Dynamic Applications that have the Caching fields set to either Cache Results or Consume cached results, in the Dynamic Applications Properties Editor page.
  • Collection objects that have the Disable Object Maintenance setting enabled.
  • Collection objects that have a Collect status defined by a user, i.e. collection objects that were manually enabled or disabled by a user.
Status of Objects for Deviation
SL1 allows you to examine the value of an object and trigger an alert if that value falls outside the range of "normal" values for that object at the hour of the day on that day of the week. The deviation function allows you to define such alerts.
To use the deviation function, you must configure SL1 to store and calculate the mean values and standard deviation for an object. You do this by selecting the Enable Deviation Alerting field in the Collection Objects page. You then specify the minimum and maximum number of weeks to collect deviation data for the object. SL1 must have already collected at least the minimum number of weeks' worth of values for an object before SL1 can evaluate alert formulas that use the deviation function. To use the deviation function, you must specify a minimum value of at least two weeks.
If a Dynamic Application in the Dynamic Application Collections page contains one or more alerts that use the deviation function, the Dynamic Application Collections page displays the status of the collection objects.
For example, suppose an alert in a Dynamic Application will apply the deviation function to object "o_123". Suppose that you specified that SL1 must collect at least two weeks' worth of deviation data for this object. Suppose that SL1 contains only one weeks' worth of values for object "o_123". In this case, the Dynamic Application Collections page will display the following message:
Note: object 123 not ready for deviation alerting.
When SL1 contains at least two weeks worth of values for object "o_123", the Dynamic Application Collections page will display the following message:
All objects ready for deviation alerting.
Manually Associating a Dynamic Application with a Device
From the Dynamic Application Collections page, you can manually associate a new Dynamic Application with a device.
To manually associate a Dynamic Application with a device:
  1. In the Device Manager page, find the device you want to associate with a Dynamic Application. Click its wrench icon ().
  2. In the Device Administration panel, click the Collections tab.
  3. In the Dynamic Application Collections page, click the [Actions] menu and select Add Dynamic Application.
  1. The Dynamic Application Alignment modal page appears. To align a Dynamic Application with a device in this page:
  • Select the Dynamic Application you want to align with the device in the Dynamic Applications field. You can filter the list of Dynamic Applications using the search field above the Dynamic Applications field.
  • After selecting a Dynamic Application, you must select a credential. Select a credential in the Credentials field. You can filter the list of credentials using the search field above the Credentials field.
NOTE: Your organization membership(s) might affect the list of credentials you can see in the Credentials field.
NOTE: Cache-consuming Dynamic Applications do not require a credential. If you selected a cache-consuming Dynamic Application in the Dynamic Application Alignment modal page, the Credential field displays N/A and is grayed out. You do not have to select a credential in the Dynamic Application Alignment modal page.
  1. Click the [Save] button in the Dynamic Application Alignment modal page to align the Dynamic Application and the credential to the device.
  2. SL1 will associate the Dynamic Application with the device and immediately attempt to collect the data specified in the Dynamic Application using the selected credential.
  3. After the first, immediate collection, SL1 will collect the data at the frequency defined in the Polling Frequency field in the Application Configuration Editor page for the Dynamic Application.
Editing the Credential Associated with a Dynamic Application
From the Dynamic Application Collections page, you can change the credential associated with a Dynamic Application. This credential will be used by SL1 for this specific Dynamic Application associated with this specific device . For all other devices, SL1 will use the default credential associated with the device, or will use the credential defined in the Dynamic Application Collections page for each device.
NOTE: Cache-consuming Dynamic Applications do not require a credential. If you aligned a cache-consuming Dynamic Application with this device (you do this in the Dynamic Application Alignment modal page), the Credential field displays N/A and is grayed out.
To change the credential associated with a Dynamic Application for a device:
  2. In the Device Manager page, find the device for which you want to define a credential. Select its wrench icon ().
  3. In the Device Administration panel, select the Collections tab.
  4. In the Dynamic Application Collections page, find the Dynamic Application for which you want to change the credential. Select its checkbox (). To apply a credential to multiple Dynamic Applications, select the checkbox for each Dynamic Application.
  1. From the Select Action drop-down list, select the credential from the list of all credentials that you are allowed to use, and then select the [Go] button.
NOTE: Your organization membership(s) might affect the list of credentials you can see in the Select Action drop-down list.
NOTE: If this Dynamic Application has already been aligned with a credential to which you do not have access, the Credential column will display the value Restricted Credential. If you align the device with a different credential, you will not be able to re-align the device with the Restricted Credential.
  1. You should see your change reflected in the Credential column in the Dynamic Application Collections page.
Performing Other Administrative Tasks for an Aligned Dynamic Application
You can perform the following other administrative tasks for an aligned Dynamic Application in the Dynamic Application Collections page:
  • Enable or disable one or more collection objects or presentation objects.
  • Stop data collection for the whole Dynamic Application.
  • Reset the statistical data that has been stored for standard deviation alerting.
  • Reset persistent session objects that have been collected and stored for a Dynamic Application.
  • Test collection for a Dynamic Application.
  • Remove all data collected using the Dynamic Application and optionally unalign the Dynamic Application from the device.
To perform one of these tasks:
  1. In the Device Manager page, find the device for which you want to perform an administrative task. Select its wrench icon ().
  2. In the Device Administration panel, select the Collections tab.
  3. In the Dynamic Application Collections page, find the Dynamic Application for which you want to perform an administrative task. The following sections describe how to perform each task.
Enabling or Disabling Objects
From the Dynamic Application Collections page, you can customize the collection performed by the Dynamic Application for the current device. This customization will be used by SL1 only for this specific device. For all other devices, SL1 will use the default list of objects from the Dynamic Application's definition or will use the list of objects defined in the Dynamic Application Collections page for that device.
To enable or disable collection for one or more objects in a Dynamic Application:
  • To disable collection for one or more collection objects, unselect the checkbox for each object for which you want to disable collection.
  • For each unselected object, the Collect column should now display No.
  • To enable collection for one or more collection objects, select the checkbox for each object for which you want to enable collection.
  • For each selected object, the Collect column should now display Yes.
  • Select the [Save] button.
NOTE: If a user manually sets the Collect status of a collection object or presentation object to No, SL1 will not attempt to re-collect the object once a day and will not automatically set the Collect status to Yes.
Restarting Automatic Maintenance of Collection Objects
If a user manually sets the Collect status of a collection object or presentation object, SL1 will not automatically change the Collect status of that object as described in the How SL1 Manages Collect Status section.
If you want SL1 to restart automatic maintenance of the objects in a Dynamic Application, perform the following steps:
  1. In the Dynamic Application Collections page, select the checkbox () for the Dynamic Application for which you want to restart automatic collection maintenance. To restart automatic collection maintenance for multiple Dynamic Applications, select the checkbox for each Dynamic Application.
  2. From the Select Action drop-down list, select Restore System Control of Collection State and then select the [Go] button.
  3. Automatic collection maintenance for all objects in the Dynamic Application will now occur. The Collect status of the objects in the Dynamic Application will not change immediately.
Editing the Poll Frequency for a Dynamic Application on the Current Device
Poll Frequency is the frequency at which SL1 will query the device to retrieve the data specified in the Dynamic Application. Each Dynamic Application includes a default frequency.
From the Dynamic Application Collections page, you can change the poll frequency for a Dynamic Application on the current device. For the current device, the edited poll frequency will override:
  • the default frequency for the Dynamic Application.
  • the poll frequency defined for a Dynamic Application in one or more device templates.
To edit the poll frequency for a Dynamic Application on the current device:
  1. In the Dynamic Application Collections page, select the checkbox () for the Dynamic Application for which you want to change the poll frequency. To change the poll frequency for multiple Dynamic Applications, select the checkbox for each Dynamic Application.
  2. From the Select Action drop-down list, select Poll Frequency from the list of poll frequencies and then select the [Go] button.
  3. You should see your change reflected in the Poll Frequency column in the Dynamic Application Collections page.
Stopping Data Collection for a Dynamic Application
You can stop data collection for a Dynamic Application on the current device. This will affect collection only for this specific device. For all other subscriber devices, SL1 will continue to use this Dynamic Application to collect data.
To stop data collection for a Dynamic Application on this device:
  1. Select the checkbox () of each Dynamic Application for which you want to stop data collection.
  1. From the Select Action drop-down list, select the following:
  • Disable All Collection Objects. For all collection objects in the selected Dynamic Application(s), the Collect value will be set to No.
  1. Select the [Go] button.
Resetting Statistical Data for a Dynamic Application
SL1 allows you to examine the value of an object and trigger an alert if that value falls outside the range of "normal" values for that object at that hour of the day on that day of the week. The deviation function allows you to define such alerts.
To use the deviation function, you must configure SL1 to store and calculate the mean values and standard deviation for an object. You do this by selecting the Enable Deviation Alerting field in the Collection Objects page. You then specify the minimum and maximum number of weeks to collect deviation data for the object. SL1 must have already collected at least the minimum number of weeks' worth of values for an object before SL1 will evaluate alert formulas that use the deviation function. To use the deviation function, you must specify a minimum value of at least two weeks.
In some cases, you might want to delete all the collected statistics for an object and start over. This is useful if known circumstances change the value of an object, and you no longer want to use the old data to calculate the "normal" ranges. You can do this by "resetting" the statistical data for an object.
For example, suppose you were monitoring bandwidth usage with a standard deviation alert. Suppose your company previously ran on a 09:00 to 17:00 work schedule. Suppose your company has recently added a nightshift to the schedule. In this circumstance, you might want to reset the statistical data to determine the new "normal" usage patterns.
When you reset the statistical data for an object, you are telling SL1 to ignore all previously collected values and to use only values from today onward. When you reset the statistical data for an object, the Dynamic Application Collections page will again display a message like:
until enough data has been collected to again calculate standard deviation for the object. SL1 will again start collecting the minimum number of weeks of data for the object (as specified in the Enable Deviation Alerting field in the Collection Objects page) and calculating the "normal" ranges for those objects for each hour at each day of the week.
To delete all current statistical data for an object:
  1. In the Dynamic Application, find the object for which you want to reset data.
  1. In that Dynamic Application, find the object for which you want to reset data. Select its checkbox ().
  1. From the Select Action drop-down list, select the following option:
  • Reset Statistical Data. Removes all previously collected statistical data for the selected object. SL1 will again start collecting the minimum number of weeks of data for the object (as specified in the Enable Deviation Alerting field in the Collection Objects page) and calculating the "normal" ranges for those objects for each hour at each day of the week.
  1. Select the Go button.
  2. The Dynamic Application Collections page will display a message like:
Resetting Persistent Session Objects for a Dynamic Application
SOAP or XSLT Dynamic Applications can contain a collection object that stores a Session ID. The value for this collection object can be defined as a persistent value. If SL1 has already retrieved and stored a value in the collection object for the Session ID, SL1 will not collect a new value for the collection object until a SOAP fault occurs. You can force SL1 to re-collect a Session ID collection object by deleting the current persistent value.
To delete the current persistent value for a session object:
  • In the Dynamic Application, find the object for which you want to reset data. Select its checkbox ().
  • From the Select Action drop-down list, select the following option:
  • Reset Persistent Session Objects. Removes the stored value for collection objects of type SOAP/XSLT Session ID. SOAP/XSLT Session ID objects are persistent across collection periods; SL1 does not collect a SOAP/XSLT Session ID object if a collected value is available from a previous poll. After selecting this option, SL1 will delete the existing value for the object and collect a new value during the next collection.
  • Select the Go button.
Testing Data Collection for a Dynamic Application
On a single device, you can perform a test-run of collection with a single Dynamic Application. During this test run, SL1 displays details of each step of the collection process. This information can be very helpful for troubleshooting and debugging.
During a test run of a collection with a Dynamic Application, SL1 does not store the collected data or generate alerts. SL1 will continue to collect data and generate alerts using the selected Dynamic Application at the frequency defined in the Dynamic Application.
To execute a test run of collection with a single Dynamic Application:
  • Locate the device on which you want to test the Dynamic Application and click its wrench icon ().
  • Click the Collections tab.
  • Find the Dynamic Application for which you want to test collection and click its lightning bolt icon ().
NOTE: If a device is currently unavailable, the lightning bolt icon () will be grayed out for each Dynamic Application aligned with the device.
  1. SL1 displays a Session Logs modal that includes details about each step of the collection process and diagnostic details about alerts in the Dynamic Application. This information can be helpful during troubleshooting.
Removing Data Collected by a Dynamic Application
You can remove the data retrieved with a Dynamic Application from the current device. You have two options for removing Dynamic Application data associated with a device:
  • Remove all previously collected data, but continue to collect data at the specified polling frequency.
  • Remove all normalized data, but retain all raw collected data and continue to collect data at the specified polling frequency.
  • Remove all previously collected data and stop collecting data with this Dynamic Application. This unaligns the device from the Dynamic Application. The device will no longer be a subscriber to the Dynamic Application.
To remove Dynamic Application data associated with a device:
  • In the Dynamic Application Collections page, select the checkbox () of the Dynamic Application for which you want to remove data. To remove data for multiple Dynamic Applications, select the checkbox for each Dynamic Application.
  • From the Select Action drop-down list, select one of the following options:
  • Remove Data. Removes all previously collected data, but data will continue to collect at the specified polling frequency.
  • Remove Normalized Data. Removes all normalized data, but all raw collected data is retained and data will continue to collect at the specified polling frequency.
  • Stop Collection and Remove Data. Removes all previously collected data and stops collection of data with this Dynamic Application. This "unaligns" the device from the Dynamic Application. The device is no longer considered a subscriber to the Dynamic Application. If you perform this option and later want to subscribe to this Dynamic Application again, you must re-align the device with the Dynamic Application.
Bulk Un-aligning Dynamic Applications
The Application Subscribers page contains a drop-down field in the lower right called Select Action. This field allows you to un-align a Dynamic Application from one or more subscriber-devices.
To un-align a Dynamic Application from one or more devices:
  2. In the Dynamic Applications Manager page, find an application with a subscriber icon () in the Subscribers column. Clickt the icon.
  1. The Application Subscribers page appears.
  1. In the Application Subscribers page, select the checkbox for each device you want to apply the action to. To select all checkboxes for all devices, select the red checkbox () at the top of the page.
  2. In the Select Action drop-down list, select Unalign Device and Remove Collection Data. This option un-aligns the device from the Dynamic Application and deletes all data collected by the Dynamic Application from the device. The device is no longer considered a subscriber to the Dynamic Application. If you perform this option and later want to subscribe to this Dynamic Application again, you must re-align the device with the Dynamic Application.
  3. Click the Go button to apply the action to all selected devices.
Setting Thresholds for Dynamic Applications
If a Dynamic Application includes one or more thresholds, you can change the threshold value on a per-device basis. To change a Dynamic Application threshold for a device:
  • In the Device Manager page, find the device for which you want to define a threshold. Select its wrench icon ().
  • In the Device Administration panel, select the Thresholds tab.
  • The Device Thresholds page displays a list of thresholds defined for each Dynamic Application that is aligned to the device. To change a threshold, move the slider for that threshold or enter a value in the number field for that threshold:
  • After changing one or more thresholds, select the Save button to save your changes.
Changing a threshold in the Device Thresholds page affects only the current device. The threshold values defined in the Dynamic Application remain unchanged.
Dynamic Applications and Discovery
Discovery is the ScienceLogic tool that automatically discovers devices in your network. You supply the discovery tool with a range or list of IP addresses, and the discovery tool determines if a device exists at each IP address. The discovery tool also determines which (if any) Dynamic Applications to align with the device. If the discovery tool finds Dynamic Applications to align with the device, the discovery tool triggers collection for each aligned Dynamic Application.
To learn more about discovery, see the Discovery and Credentials manual.
How Does SL1 Align Dynamic Applications During Discovery?
Most Dynamic Applications include a discovery object. A discovery object enables SL1 to determine which devices to align with a Dynamic Application.
During discovery, SL1:
  1. If a Dynamic Application includes a discovery object, SL1 adds that Dynamic Application to the list of Dynamic Applications to try to align during discovery.
  2. For each Dynamic Application that includes a discovery object, SL1 checks the current discovery session for an appropriate credential. For example, for each database Dynamic Application, SL1 would look for one or more database credentials that have been selected for the discovery session.
  3. For each discovered device, both those that support SNMP and those that don't, discovery tries to determine which Dynamic Applications to align. For each discovered device, SL1 tries to align each Dynamic Application in the list of Dynamic Applications to try during discovery. For each Dynamic Application in the list, SL1 tries to connect to each device with each of the appropriate credentials (until SL1 finds a working credential) and then tries to find the discovery object. If SL1 is able to connect to a device with one of the credentials and can then retrieve the discovery object, SL1 will align the Dynamic Application with the device.
NOTE: SL1 also includes more sophisticated logic that allows you to define multiple discovery objects, validate the value of the discovery object, and to align the Dynamic Application if a discovery object is not available. However, the most common use of a discovery object is as described above (discovery object exists).
  1. If discovery aligns a Dynamic Application with a device, immediately after discovery completes SL1 will start the first collection from that device using the aligned Dynamic Application. This step is not performed for Dynamic Applications that meet all of the following three criteria:
NOTE: During discovery, SL1 tries each SNMP credential specified in the discovery session on each discovered device, to determine if SL1 can collect SNMP details from the device. Later in the discovery session, during alignment of Dynamic Applications, discovery again tries each SNMP credential specified in the discovery session. If one of the SNMP credentials times out three times without any response, discovery will stop trying to use that SNMP credential to align SNMP Dynamic Applications. Note that "no response" means that a device did not respond at all. Note that if a device reports that "no OID was found" or "the end of the OID tree was reached", these are considered a legitimate response and would not cause SL1 to abandon the credential.
Queuing Discovery from the Dynamic Applications Manager Page
From the Dynamic Applications Manager page, you can manually run the Dynamic Application alignment portion of discovery for all devices in the system using one or more selected Dynamic Applications.
To manually queue discovery from the Dynamic Applications Manager page:
  • In the Dynamic Applications Manager page, select the checkbox for each Dynamic Application you want to use for discovery.
  • In the Select Action drop-down list, select Discover Applications. Select the Go button.
  • You can also run the Dynamic Application alignment portion of discovery for all devices in the system using a single Dynamic Application. To do this, select the lightning bolt icon () for that Dynamic Application.
System Settings That Affect Dynamic Application Discovery
Some of the parameters in the Behavior Settings page affect how SL1 aligns Dynamic Applications during discovery (discovery, auto-discovery, and re-discovery).
To define or edit the settings that affect discovery in the Behavior Settings page:
  2. In the Behavior Settings page, edit the values in one or more of the following fields:
  • Initial Discovery Scan Level. Specifies the data to be gathered during the initial discovery session. The options are:
NOTE: You can override this setting for a single discovery session in the Discovery Session Editor modal page.
  • 0. Model Device Only. Discovery tool will discover if device is up and running and if so, collect the make and model of the device. SL1 will then generate a device ID for the device, so it can be managed by SL1.
  • 1. Initial Population of Apps. Discovery tool will search for Dynamic Applications to associate with the device. Discovery tool will attempt to collect data for the aligned Dynamic Applications. Discovery will also perform 0. Model Device Only discovery.
  • 2. Discover SSL Certificates. Discovery tool will search for SSL certificates and retrieve SSL data. Discovery tool will also perform 1. Initial Population of Apps and 0. Model Device Only.
  • 3. Discover Open Ports. Discovery tool will search for open ports. Discovery tool will also perform 2. Discover SSL Certificates, 1. Initial Population of Apps, and 0. Model Device Only.
NOTE: If your system includes a firewall and you select 3. Discover Open Ports, discovery might be blocked and/or might be taxing to your network.
  • 4. Advanced Port Discovery. Discovery tool will search for open ports, using a faster TCP/IP connection method. Discovery tool will also perform 2. Discover SSL Certificates, 1. Initial Population of Apps, and 0. Model Device Only.
NOTE: If your system includes a firewall and you select 4. Advanced Port Discovery, some auto-discovered devices might remain in a pending state (purple icon) for some time after discovery. These devices will achieve a healthy status, but this might take several hours.
  • 5. Deep Discovery. Discovery tool will use nmap to retrieve operating system name and version. Discovery will also scan for services running on each open port and can use this information to match devices to device classes. Discovery tool will search for open ports, using a faster TCP/IP connection method. Discovery tool will also perform 2. Discover SSL Certificates, 1. Initial Population of Apps, and 0. Model Device Only.
NOTE: For devices that don't support SNMP, option 5. Deep Discovery allows you to discover devices that don't support SNMP and then align those devices with a device class other than "pingable".
Option 5. Deep Discovery is compute-intensive and might significantly tax your network if used as the default setting. ScienceLogic recommends that you use this option on a per-discovery basis by selecting it in the Discovery Session Editor page.
  • Rediscovery Scan Level (Nightly). Specifies the data to be gathered/updated each night during auto-discovery. The auto-discovery process will find any changes to previously discovered devices and will also find any new devices added to the network. The options are the same as for Initial Discovery Scan Level.
ScienceLogic recommends that you delete all unused PowerPacks from your SL1 system to improve the performance of the nightly auto-discovery process. For more information about deleting PowerPacks, see the section on Deleting One or More PowerPacks.
  • Discovery Scan Throttle. Specifies the amount of time a discovery process should pause between each IP address or hostname in a discovery session. (You specify the list of IP addresses or hostnames for a discovery session in the IP Address/Hostname Discovery List field in the Discovery Session Editor page.) Pausing discovery processes between IP addresses or hostnames spreads the amount of network traffic generated by discovery over a longer period of time. The choices are:
  • Port Scan All IPs. Specifies whether SL1 should scan all IP addresses on a device for open ports. The choices are:
  • NOTE: You can override this setting for a single discovery session in the Discovery Session Editor modal page.
  • 0. Disabled. SL1 will scan only the primary IP address (the one used to communicate with SL1) for open ports.
  • 1. Enabled. SL1 will scan all discovered IP addresses for open ports.
  • Port Scan Timeout. Length of time, in milliseconds, after which SL1 should stop trying to scan an IP address for open ports and begin scanning the next IP address (if applicable). Choices are between 60,000 and 1,800,000 milliseconds.
  • Hostname Precedence. Specifies which name SL1 will use for each discovered device. Choices are:
  • 0. SNMP System Name. Use the device name specified in the device's MIB.
  • 1. DNS Reverse Lookup. Use the device name specified in the device's reverse-lookup record.
  • DNS Hostnames. Specifies which DNS name SL1 will use for each discovered device. Choices are:
  • 0. Strip Device Name. SL1 will use the DNS hostname as the device name for each device.
  • 1. Use Full Domain Name (FQD). SL1 will use the fully-qualified domain name as the device name for each device.
