Editing the Jira Service Management Action Policies
The Jira Service Management Automation Policies PowerPack includes two action policies that use the "Run Integration Service Application" action type to trigger the PowerFlow application that sends and receives data to Jira. You can specify the credential ID in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
). The Editing Action page appears:
- credential_id. Change the value to the credential ID that you noted earlier when creating a credential for your PowerFlow system. This parameter is required.
