Hardware Specifications
For details about supported ScienceLogic Hardware Appliances, see the ScienceLogic Support Site. https://support.sciencelogic.com/s/system-requirements?tabset-e65a2=2
Prerequisites for SL1 Hardware Appliances
Perform the following steps to prepare an SL1 appliance for configuration:
- Install the SL1 appliance in a server rack and connect the power cables according to the instructions provided with the hardware.
- Connect the SL1 appliance to your network.
- Connect a monitor and keyboard to the SL1 appliance.
Initial Configuration for SL1 Hardware Appliances
You must perform the following tasks during initial configuration of an SL1 hardware appliance shipped by ScienceLogic:
- Change the password for the administrative user em7admin.
- Change the primary IP address of the appliance. You must have already allocated IP addresses for the SL1 appliances.
- Change the netmask for the primary IP address of the appliance.
- Change the IP address for the network gateway.
- Change the IP address for the primary Nameserver.
Changing the Password for em7admin
- Either go to the console of the SL1 appliance or use SSH to access the server.
- Log in as user em7admin with the appropriate password. The default password is em7admin.
At the shell prompt, type the following:
passwd
- When prompted, type and re-type the new password.
Changing Network Settings
To change the IP address, Netmask, Gateway address, and DNS Server for an appliance in the ifconfig file:
- Login as user em7admin with the appropriate password.
- Enter the following at the command line:
sudo ifconfig
- Your output will look like this:
ens32: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.64.68.20 netmask 255.255.255.0 broadcast 10.64.68.255
inet6 fe80::250:56ff:fe84:455f prefixlen 64 scopeid 0x20<link>
ether 00:50:56:84:45:5f txqueuelen 1000 (Ethernet)
RX packets 1774927 bytes 161985469 (154.4 MiB)
RX errors 0 dropped 861 overruns 0 frame 0
TX packets 1586042 bytes 158898786 (151.5 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 0 (Local Loopback)
RX packets 13406577 bytes 4201274223 (3.9 GiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 13406577 bytes 4201274223 (3.9 GiB)
- Examine the output, find the first interface in the output, and note its name.
- Use the vi editor to edit the settings for the interface. To do this, enter the following at the command line:
sudo vi /etc/sysconfig/network-scripts/ifcfg-interface name you noted in step #4
For example, from our output, we could enter:
sudo vi /etc/sysconfig/network-scripts/ifcfg-ens32
TYPE=Ethernet
BOOTPROTO=none
DNS1=10.64.20.33
DEFROUTE=yes
IPV4_FAILURE_FATAL=no
IPV6INIT=yes
IPV6_AUTOCONF=yes
IPV6_DEFROUTE=yes
IPV6_FAILURE_FATAL=no
NAME=ens32
UUID=d471435d-9adf-47c9-b3f3-32f61dccbad8
DEVICE=ens32
ONBOOT=yes
IPADDR=10.64.68.20
PREFIX=24
GATEWAY=10.64.68.1
IPV6_PEERDNS=yes
IPV6_PEERROUTES=yes
- You can edit one or more of the following settings:
- DNS1=IP address of the DNS server that will be used by the SL1 appliance.
- IPADDR=IP address of the SL1 appliance.
- PREFIX=netmask for the SL1 appliance.
- GATEWAY=IP address of the network gateway that will be used by the SL1 appliance.
- Save your changes and exit the file (:wq)
- At the command line, enter the following:
sudo service network restart
Ports for SL1 Hardware Appliances
See the
