NOTE: Monitoring with the SL1 Agent is available only on SL1 Extended.
The following video explains how to run PowerShell Dynamic Apps with the SL1 Agent:
The following sections provide an overview of local Agent execution on Windows devices with PowerShell:
What is an SL1 Agent?
The SL1 agent is a program that you can install on a device monitored by SL1. The SL1 agent collects data from the device and pushes that data back to SL1.
Similar to a Data Collector or Message Collector, the SL1 Agent collects data about infrastructure and applications.
The agent can be configured to communicate with either the Message Collector or the Compute Cluster.
For more information, see the Monitoring with the SL1 Agent
Agent-Compatible PowerPacks
The following PowerPacks include the SL1 Agent PowerShell Default credential and SL1 Agent device template, which you can use to execute the SL1 Agent on Windows devices with PowerShell:
- Microsoft: Windows Server
- SL1 Agent Templates for Microsoft PowerPacks, which includes templates for the following:
- Microsoft: DHCP Server
- Microsoft: DNS Server
- Microsoft: Exchange Server
- Microsoft: IIS Server
- Microsoft: Lync Server
- Microsoft: SharePoint Server
- Microsoft: SQL Server
The Credential for the SL1 Agent
The "SL1 Agent PowerShell Default" credential does not need to be configured and can be used as-is. You can find the credential in the Credentials page (Manage > Credentials), or the Credential Management page (System > Manage > Credentials) in the SL1 classic user interface:
Configuring the SL1 Agent Device Templates
A device template allows you to save a device configuration and apply it to multiple devices. Windows PowerPacks include a device template for executing the SL1 Agent with PowerShell. If you apply this device template during discovery, SL1 aligns the appropriate Dynamic Applications to the discovered PowerShell device.
This device template does not need to be edited and will work as-is, unless you would like to remove a Dynamic Application from the template. To remove any Dynamic Applications you may not need:
- Go to the Configuration Templates page (Devices > Templates, or Registry > Devices > Templates in the SL1 classic user interface).
- Locate the SL1 Agent template (for example, "SL1 Agent for Microsoft: Windows Server Template") and click its wrench icon (
). The Device Template Editor page appears.
- Click the Editing Dynamic Application Subtemplates page appears: tab. The
- Modify the Template Name field, as you will not want to overwrite the sample template.
- To remove a Dynamic Application listed in the Subtemplate Selection section on the left side of the page, click it's bomb icon (
) and then click when asked to confirm.
