What are the Datacenter Advanced Enrichment Policies PowerPacks?
The set of Datacenter Advanced Enrichment Policies PowerPacks contain device-specific automation policies (and additional event policies not included in other ScienceLogic PowerPacks) that you can configure to collect additional diagnostic information when events occur. You can use this additional data about the event to provide instructions on how to troubleshoot and resolve that event.
You must install the Datacenter Advanced Enrichment Actions PowerPack before you can install and use any of the related Policies PowerPacks. For more information, see
Available Automation Policies and Event Policies
The following table lists the number of automation policies and event policies in each of the Datacenter Advanced Enrichment Policies PowerPacks:
Device Type | Number of Automation Policies | Number of Additional Event Policies |
Cisco Collaboration | 3 | 0 |
Cisco CSP | 1 | 0 |
Cisco IOS | 73 | 180 |
Cisco IOS-XE | 32 | 72 |
Cisco IOS-XR | 35 | 58 |
Cisco Networking | 27 | 20 |
Cisco NX-OS | 2 | 2 |
Cisco Unified Communication Manager | 20 | 34 |
Cisco UCS | 17 | 0 |
Cisco UCS C-Series | 17 | 125 |
Cisco Wireless | 18 | 28 |
Citrix NetScaler | 10 | 17 |
F5 Big-IP | 21 | 0 |
Juniper JunOS | 2 | 0 |
NetApp | 3 | 0 |
Installing Datacenter Advanced Enrichment Policies PowerPacks
The Datacenter Advanced Enrichment Policies PowerPacks require SL1 version 8.10.0 or later. For details on upgrading SL1, see the appropriate SL1 Release Notes.
Download the PowerPack from the ScienceLogic Support Site at https://support.sciencelogic.com/s/powerpacks.
Go to the PowerPack Manager page (System > Manage > PowerPacks).
In the PowerPack Manager page, click the button, then select Import PowerPack. The Import PowerPack dialog box appears:
Click the [Browse] button and navigate to the PowerPack file.
When the PowerPack Installer modal appears, click the button to install the PowerPack.
Unsupported Configurations
The following configurations are not supported by the Datacenter Advanced Enrichment Policies PowerPacks:
- The PowerPacks cannot be used on systems where the Military Unique Deployment (MUD) configurations have been applied.
- Customer-created automation actions that build command lists to be executed by the "Enrichment: Util: Collect Enrichment Data" automaton action are not supported without prior authorization from ScienceLogic.
- Modifications of any kind to the code supplied in the Datacenter Advanced Enrichment Policies PowerPacks are not supported without prior authorization from ScienceLogic.
